Does Rotting Food Have a Direct Impact on Its Half Life?
The discussion centers on the relationship between the rotting of food and the concept of half-life, particularly whether the decomposition of organic materials is directly related to the half-life of their components. Participants explore various aspects of decay, including biological processes and the applicability of half-life in different contexts.
  • Some participants assert that rotting food is not directly related to the half-life of its components, emphasizing that decomposition occurs at a cellular level due to bacterial action.
  • Others propose that organic material could decompose even in a bacteria-free environment, suggesting that cellular leakage and fluid mixing contribute to decay.
  • A participant questions whether the concept of half-life could be applied to predict when organic matter becomes unconsumable under specific conditions.
  • There is a discussion about the term "half-life" being applicable beyond radioactive decay, with some participants noting that it can refer to any kind of exponential decay.
  • One participant highlights that food is not significantly radioactive, suggesting that radioactive half-life does not play a role in food decay.
  • Another participant mentions browning as an example of food degradation that occurs without the involvement of bacteria or fungi.
Participants generally disagree on the relationship between rotting food and half-life, with multiple competing views on the mechanisms of decay and the applicability of half-life concepts. The discussion remains unresolved regarding the specific connections between these ideas.
There are limitations in the discussion regarding the definitions of half-life and the assumptions about the conditions under which organic matter decomposes. The applicability of half-life to non-radioactive decay remains a point of contention.
cesaruelas
Is the process of rotting food or any organic material directly related to the half life of its components?
Chemistry news on Phys.org
No. Rotting food occurs at a cellular level. Bacteria attack the organics and break them down.
Organic material in an ideally bacteria-free environment would never decompose? or only then would its decomposition be linked to the half life of its components? BTW, thank you for answering.
It would. Bacteria and fungus are a major source, but the organic material will decompose on its own as well. Cells leak. Fluids mix. Components lose integrity.
If you can find any evidence suggesting a link between normal food rotting and radioactive decay, I would be quite surprised.
The notion of half life is not limited to radioactive decay.
Then perhaps the OP should be explicit.
My point is, can you, under certain conditions (bacteria free, certain temperature, etc.) predict when will organic matter be "unconsumable" for a human being given you only know the halflife of its components and the concentration of each in the material to analize?
Do you mean radioactive half life or some other kind?
I originally meant radioactive half life (since I was not aware the term was used to refer to any other type of half life). Is it linked to that half life or is there an equivalent concept for decomposition of organic molecules (proteins, carbohidrates, etc)? Thanks for your answers.
The term can be used to describe any kind of exponential decay - for example, basketball team lifespan in a tournament.
However, for your question: our food is not significantly radioactive, so radioactive half life plays no role whatsoever in its decay as a food source.
Not rotting in the exact sense, but may pertain to this thread as an example of degradation of food items without bacteria or fungi: Browning (food process).
  • · Replies 20 ·
