Register to reply
Multiplicity of an einstein solid
by zezima1
Tags: einstein, multiplicity, solid
Share this thread:
zezima1
#1
Mar30-12, 02:41 PM
P: 123
Okay, I am not sure if this is the right subforum, but here goes:
An einstein solid is a solid composed of N quantum harmonic oscillators, which can store evenly spaced energy units q.
Now suppose we have an einstein solid of N oscillators with q energy units, where q>>N. My book wants to derive an expression for the multiplicity of this solid, but I can't quite follow the approximations leading to the final expression:
We have in general that that the multiplicity, Ω, of an einstein solid is given by the binomial:
Ω = C(q+N-1,q) , where C() is the binomial coefficient. I wont verify this expression, because it is the approximations of it that bother me:
In general we have from the definition of the binomial coefficient:
Ω = C(q+N-1,q) = (q+N-1)!/((N-1)!*q!)
My book approximates this to:
Ω = (q+N)!/(q!*N!)
with the argument that: "The ratio of N! to (N-1)! is only a large factor (N).
I dont see what this has to do with the approximation. The multiplicity above gets far bigger with the approximation because it all depends on q.
For instance, say q=100 and N=2. Then you get:
Ωreal = 101!/100! = 101
Ωapprox = 102!/2! ≈ 50*Ωreal
or i general for N=2:
Ωapprox = q/2 * Ωapprox
So in general how is this approximation valid? Am I plugging the numbers in the wrong way?
Phys.Org News Partner Physics news on Phys.org
Technique simplifies the creation of high-tech crystals
Working group explores the 'frustration' of spin glasses
New analysis of oxide glass structures could guide the forecasting of melt formation in planetary interiors
Philip Wood
#2
Mar30-12, 05:07 PM
PF Gold
P: 936
In the cases we're usually interested in, it's not just the number, q, of quanta that is huge, but the number, N, of oscillators as well. That's why it's permissible not to worry about the '1'.
aaaa202
#3
Mar30-12, 08:08 PM
P: 1,005
hmm yes but the approximation assumes that q>>N. So even though N is large wont the factor still be quite large because q is very large?
Philip Wood
#4
Mar31-12, 03:13 AM
PF Gold
P: 936
(1) Where is the assumption made that q>>N?
(2) Omitting a factor of N doesn't matter, as long as the percentage difference made to ln Ω is negligible which it will be, if N is huge. The use of Stirling's formula, for both N! and q! is also justified by this criterion, provided N and q are both huge. There is no need, as far as I know, for q>>N.
aaaa202
#5
Mar31-12, 06:57 AM
P: 1,005
This is just the first part of the approximation. The next part exactly uses that q>>N to simplify further. But indeed you are right that while q is a VERY LARGE NUMBER N is also just a large number. What difference does it make? Maybe your are actually dividing q/N! so is that why it becomes negligible?
I just don't understand the explanation:
"The ratio of N! to (N-1)! is only a large factor (N)."
haruspex
#6
Mar31-12, 11:39 PM
Homework
Sci Advisor
HW Helper
Thanks ∞
P: 9,645
As Philip pointed out, what you're eventually interested in is ln(Ω), and even this is going to be a large number. Large, in fact, compared with ln(q) and ln(N).
A factor N in Ω turns into an addition of ln(N) on ln(Ω), and the effect of that is small.
aaaa202
#7
Apr1-12, 08:02 AM
P: 1,005
Quote Quote by haruspex View Post
ITS NOT JUST A FACTOR OF N :( Try for q=100 and N=2 and for q=1000 and N=2. The factor is q/N and that is a very large number, because q>>N.
Philip Wood
#8
Apr1-12, 09:02 AM
PF Gold
P: 936
Can't quite see what you're driving at here.
(1) Still can't see why you think the ratio q/N is important. You say your book goes on to make this assumption, but it isn't required in order to neglect the 1, nor to apply Stirling's formula.
(2) All approximations fail hopelessly if you take N as 2. The approximations start to become plausible (in my opinion) for N greater than 50 (and q greater than 50), though with N and q as large as they usually are in the cases we deal with, the approximations are hardly approximations at all.
See attached sheet for more detail.
aaaa202
#9
Apr1-12, 12:07 PM
P: 1,005
hmm... I definately must be making some kind of basic mistake, because I can't get the approximation to make sense. So let us try to do it for two large numbers for q and N and you can point out what I do wrong:
We have:
Ωreal = (q+N-1)!/((N-1)!*q!)
Ωapprox = (q+N)!/(N!*q!)
Let N=1023and q=10100. These are both large numbers with q>>N.
Now plug in to the two expressions:
Ωreal = (10100+1023-1)!/((1023-1)!*10100!)
Ωapprox = (10100+1023)!/((1023)!*10100!) = 10100/1023 * (10100+1023-1)!/((1023-1)!*10100!) = 1077 * Ωreal
How is this factor just a negligible term? And what has this term got to do with the reason ""The ratio of N! to (N-1)! is only a large factor (N).", which is how the author of my book defends the approximation..?
Philip Wood
#10
Apr1-12, 01:29 PM
PF Gold
P: 936
Thank you for explaining the problem so clearly. The answer, I'm afraid is still more or less the same as before, but at least you've enabled me to explain it better...
You might think that [itex]10^{77}[/itex] is a large number. Compared to Ω it is tiny.
The easiest way to see this is by taking logs. Taking logs is important anyway, because it turns out that ln Ω is what matters in statistical mechanics.
Because your q is so vastly larger than N (I still don't know why you insist on this, but I'll just live with it!) we need to do some preliminary work on your top factorial. Can you see that since q>>N, then [itex](N+q)! = (q^N) q![/itex] to a very good approximation?
This means that your approximate Ω becomes [itex]\frac{q^N}{N!}[/itex]
Using stirling's formula, the log your approximate Ω is
[tex]ln \Omega =N ln q N ln N + N = 10^{23} (230 53 + 1) [/tex]
This is very much larger than ln 1077, which is a mere 177. [I almost put an exclamation mark at the end of the last sentence!]
aaaa202
#11
Apr1-12, 03:47 PM
P: 1,005
Hmm yes, I see it now :) Thanks...
Let me ask you something else though:
You say ln are what matters in statistical mechanics. And indeed entropy etc. are defined as lnΩ etc., which was kind of odd in the beginning and still is. Are these definitions merely made because ln is much easier to work with or is there more to it?
Philip Wood
#12
Apr1-12, 04:05 PM
PF Gold
P: 936
There's more to it; the ln function arises naturally in considering thermal equilibrium. [I do sometimes catch myself wondering how nature knows about the log function, but this is probably a pretty silly worry.]
Mandl ('Statistical Physics') sets out the framework of statistical mechanics cleanly and clearly, though there are plenty of other books to choose from!
zezima1
#13
Apr1-12, 04:19 PM
P: 123
It arises naturally? I can't see why at this point:
If we say that we define something call entropy to make it easier to work with the multiplicity then so far:
S = klnΩ
In thermal equilibrium of two systems we want ∂S/∂U to be the same for the highest multiplicity. This allows us to define the temperature:
1/T = ∂S/∂U
But all these are definitions, so what comes naturally? I admit the k is kind of weird, I never understood that. Also I have heard people say S = klnΩ is a postulate but I don't see why it can't just be a definition.
Either way I guess Ima go check if the library at uni has that book.
haruspex
#14
Apr1-12, 06:05 PM
Homework
Sci Advisor
HW Helper
Thanks ∞
P: 9,645
Quote Quote by aaaa202 View Post
Sure, but it's the same argument. Multiplying Ω by q/N is equivalent to adding ln(q/N) to ln(Ω), and ln(q/N) is much smaller than ln(Ω).
George Jones
#15
Apr1-12, 09:46 PM
Mentor
George Jones's Avatar
P: 6,226
Entropy is extensive and additive.
atyy
#16
Apr2-12, 01:58 AM
Sci Advisor
P: 8,331
p(A,B)=p(A)p(B|A)
Independence p(A,B)=p(A)p(B)
Logs convert multiplication to addition
log(pA.pB)=log(pA)+log(pB)
http://en.wikipedia.org/wiki/R%C3%A9nyi_entropy
http://www.cnel.ufl.edu/courses/EEL6...is_entropy.pdf
aaaa202
#17
Apr2-12, 08:06 AM
P: 1,005
But are all the following formulas definition because additivity and small numbers are practical:
S = klnΩ
1/T = ∂S/∂U
P = T ∂S/∂V
or do they arise naturally? I think your individual answers are kind of talking against each other. Also can someone tell me what the k in front of lnΩ is supposed to mean?
DrDu
#18
Apr2-12, 08:15 AM
Sci Advisor
P: 3,554
S = klnΩ
1/T = ∂S/∂U
P = T ∂S/∂V
Entropy, internal energy, temperature and the like had all been defined long before the advent of statistical mechanics.
Also the second and third formula was known before.
The factor k in the first equation is just a conversion factor for statistical entropy to have the same units as thermodynamical entropy.
Register to reply
Related Discussions
An einstein solid Atomic, Solid State, Comp. Physics 2
Einstein solid? Atomic, Solid State, Comp. Physics 2
Multiplicity of a Large einstein solid Advanced Physics Homework 1
Multiplicity of a Einstein Solid, Low Temperature Limit Advanced Physics Homework 4
Einstein Solid Resemblence. Classical Physics 0
