Magnetic fields - which direction
The discussion revolves around the effects of magnetic fields on a flat wire carrying current, specifically in relation to the direction of the magnetic field and its perpendicularity to the current. Participants explore how the orientation of the magnetic field affects the induced magnetic force and electromotive force (emf) in various scenarios.
  • Participants discuss the conditions under which maximum magnetic force is experienced, questioning whether the plane of the magnetic field matters as long as it is perpendicular to the current. They also consider how the shape of the wire influences the magnetic field direction and its effects.
The discussion is ongoing, with participants raising questions about the implications of wire orientation and the specific conditions needed to achieve maximum emf. Some guidance has been offered regarding the relationship between the wire's shape and the magnetic field, but clarity on certain aspects remains elusive.
Participants note the potential for ambiguity in exam questions regarding the direction of the magnetic field, as well as the importance of understanding the geometry of the wire and its orientation in relation to the magnetic field.
jsmith613
If a flat wire lies in a north-south direction will the MAXIMUM magnetic force be felt if the field lies either in a east-west direction OR an up-down direction (i.e: ppd to the direction of the current?)??
I know that the maximum magnetic force is felt when the current and field are perpendicular
BUT does it matter which plane the magnetic field is in so long as it is perpendicular?
Also, in exams will it be clear which direction the field is in
(e.g: they might say it acts at a 40 degree angle to the horizontal)
therefore if the current is straight ahead I calculate the component perpendicular to the direction of the current to find the force??
I think the key to this question is the use of the word "flat" in describing the current-carrying wire. That shape should make the maximum B-field happen in only one of the two choices given...
so you're saying that if I had some height as well then it would exclude the up-down direction?
so a block facing in an east west direction would need a mag field in a south-north direction??
also what would happen with an aerial
it has height but basically no depth.
"a car with a vertical aerial 1.2m is moving at 35 m/s. The horizontal componenet of the Earth's magnetic field is 22 * 10-6T. Find the emf induced"
they give me the horizontal compoenent but surely I could also use the forward backward componenet as that too is ppd to the aerial?
Sorry, I'm not understanding what you are saying.
What I was saying was that if you draw a flat wire of some width, going in the N-S direction, then at the same radius R away from the wire, you will get a slightly different B field if you are out at the side (say on the East side, where the B field points up and down), or up towards you (where the B field points East and West).
well what I was trying to understand was how the direction of the mag field is important
going back to this question:
would the MAXIMUM EMF only be possible if I was traveling ppd to the horizontal compoenent of the Earth's mag field (assuming this was the ONLY component)
therefore could I either be traveling straight ahead OR upwards to achieve this maximum EMF??
  • · Replies 21 ·
