DC vs AC Parameters: Understanding the Difference
  • Thread starter Thread starter Godwin Kessy
    Ac Dc Parameters
The discussion centers on the differences between DC and AC resistance in diode systems, exploring the concepts of bulk resistance and dynamic resistance as they relate to current-voltage (I-V) characteristics. Participants examine the implications of these resistances in both theoretical and practical contexts, including small signal AC amplifiers.
  • Some participants express confusion regarding the distinction between DC and AC resistance, particularly in diode systems, noting that DC resistance is derived from specific I-V points while AC resistance involves changes in current and voltage.
  • One participant explains that DC resistance is calculated as R = V/I at a specific operating point, while AC resistance is defined by the slope of the I-V curve, indicating how the diode responds to small changes in current.
  • Another participant highlights that resistance is not constant and varies with applied voltage and temperature, suggesting that algebraic expressions may clarify these relationships better than verbal explanations.
  • Some participants question why DC resistance does not approximate AC resistance closely, noting that different methods (approximation for DC and calculus for AC) are used in their derivations.
  • Clarifications are made regarding the "third approximation" of diodes, which treats the diode as a switch and resistor above a certain threshold voltage, affecting the understanding of bulk resistance.
Participants generally agree on the definitions and implications of DC and AC resistance but express differing views on the relationship between the two and the methods used to derive them. The discussion remains unresolved regarding the extent to which DC resistance can approximate AC resistance.
Limitations include the dependence on specific operating points for DC resistance and the assumptions made in approximating diode behavior. The discussion also highlights the complexity of I-V characteristics in non-linear devices.
Godwin Kessy
Hello... The concept that resistance can be for a dc supply only and not for the ac supply coupled or superimposed to the same circuit, is something i don't understand to this moment... I first realized this in diode systems... where i saw bulk resistance for DC and dynamic resistance for AC... This doesn't get into mind at all.. they were both derived from the same I-V characteristic curve but bulk resistance utilized the curve made to diodes third approximation, while that of AC was obtained from the normal real curve nature of diode I-V characteristics...
Help on this...??
I didn't get "the curve made to diodes third approximation". Could you clarify...
I have met this when dealing with diode curves of I against V. To get a particular current,I, requires a particular voltage,V. and it is logical to use this V and I to specify a resistance R = V/I, this is called DC resistance. Because the graph is a curve this value of resistance is only meaningful for the values of I and V given.
If the diode is operating at this point and the current changes by a small amount, ΔI, this will produce a small change, ΔV, in the voltage. The 'resistance' specified by ΔV/ΔI shows how the diode responds to a 'changing' I or V and the resistance is given by the gradient (or 1/gradient of I against Vgraph). This is called the 'AC' resistance because it shows what happens when changes are concerned.
You could meet it whenever the graph of I against V is not a straight line such as transistor characteristics and thermistor curves.
seems to me you explained it pretty well in your last post.
Resistance is not constant , as with normal linear reststors.
It varies with applied voltage and with temperature, too. Even normal resistors have a temperature coefficient.
diode: i = e ^(qv/kt))
so r = v/ (e ^(qv/kt)) which is a logarithmic function of voltage not a linear one
Which means you really need to specify at what voltage you assigned a value to r. Or at what current.
algebra will serve you better than words on this one.
Perhaps your difficulty stems from unfamiliarity with small signal AC amplifiers? They operate on small changes in signal , with DC typically blocked by capacitors. So it is the 'AC resistance' that's of interest .
old jim
On the strength that a picture is worth a thousand words here is what I have met when the terms DC resistance and AC resistance have a meaning.
Strictly speaking it is not AC, it is fluctuating DC but the principle is the thing.
It's the graph that, approximated the diode as a switch, plus a resistor, which assumes the diode to be an open circuit until the voltage across is above the knee voltage... And at this voltage greater than the knee voltage... the diode acts as a normal resistance( the one called bulk resistance) for a diode...
Okay.. thanks guys, but why we find that the dc resistance is not even an approximate of the ac resistance, from the graph and derivation it's clear that, we use some approximation with DC(Assuming straight line instead of a curve), but for AC we even utilize calculus, these values where supposed to be close to one another... Am i wrong??
  • · Replies 20 ·
11K
  • · Replies 63 ·
