| New Reply |
Properties of Cathode Rays |
Share Thread |
| May24-12, 02:47 AM | #1 |
Why are cathode rays able to penetrate very thin metal films?
| May24-12, 04:49 PM | #2 |
because thin metal films are mostly empty space
| May24-12, 07:02 PM | #3 |
Is this the empty space within the atom (ie the space between the nucleus and the electrons) or the space between the atoms in the metal lattice?
Thanks |
| May24-12, 08:27 PM | #4 |
It seems as if you have a picture in your mind of the lattice as being the same as the common figure given as atoms being points connected by lines, with a whole lot of empty space. . Or is it the other common picture as atoms being hard balls to show the packing structure with empty space between the spheres.
Both are just geometrical representations. A whole bunch of nucleii in specific locations surrounded by electron clouds in the 'space' between is short and sweet, and hopefully answers your question and does not cause the ire of most physicists as lacking detail, which is evident. |
| May25-12, 02:18 AM | #5 |
Thanks for the reply
I was thinking of the structure where the atoms are represented as hard balls, in order to show the packing structure of the unit cell of the lattice. Based on the type of unit cell (eg face centred cubic or body centred cubic), it is possible to calculate the percentage of empty space in the unit cell of a lattice. However, such a representation is an oversimplficiation as it does not take into account the difficulty in defining the volume occupied by the electron cloud. If electron clouds are considered, is there actually any spaces between the atoms (or more correctly ions) in the metallic lattice? If there is no space between atoms, then the cathode rays are really passing through the empty space within the atom, rather than spaces between the atoms. This is what I am trying to clarify. Thanks |
| May25-12, 02:28 AM | #6 |
| May25-12, 02:36 AM | #7 |
So Drakkith, are you saying that the space between atoms is actually the space between the nucleus and the electrons in an atom because the volume of space in which an electron could be is cannot be exactly be defined (we only know regions where electrons are most likely to be found).
Thanks |
| May25-12, 02:45 AM | #8 |
| New Reply |
Similar discussions for: Properties of Cathode Rays
| Thread | Forum | Replies | ||
| To which extent cathode rays can be considered as current in a wire | Classical Physics | 6 | ||
| Cathode Rays | General Physics | 1 | ||
| Low Pressure and high voltage in cathode rays experiment | General Physics | 14 | ||
| Cathode Rays Experiment.. some missunderstood parts | Classical Physics | 2 | ||
| Exam Question: Relativity/Cathode Rays | Introductory Physics Homework | 5 | ||
