New Reply
Breit Wigner Formula
Share Thread Thread Tools
May28-12, 10:44 AM   #1
Hey guys!
Breit Wigner Formula describes the cross section for interactions that proceed dominantly via a intermediate particle (O*) A+B → O* → C + D:
[tex]σ = \frac{2\Pi}{k^{2}}\frac{Γ_{i}Γ_{f}}{(E-E_{o})^{2} + (Γ/2)^{2}}[/tex]
A short question: Does the formula apply to situations when the intermediate particle is actually virtual?
For example, in positron electron annihilation, they form a photon which might eventually decay into another two particles. Can we calculate the resonant cross section for this process with the Breit Wigner Formula as well? If it is possible, what should we put in for [itex]E_{0}[/itex], which is supposed to be the rest mass of the intermediate particle?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
May28-12, 10:56 AM   #2
I think that the Breit-Wigner formula applies to reactions going through the s-channel (because E describes the CM energy, which is [itex]\sqrt{s}[/itex]).
The tree level diagram for e--e+ annihilation ([itex]e^{-
}e^{+} \rightarrow \gamma \gamma[/itex]) is the following:
As you can see, this is a t-, or a u- channel process, so the formula does not apply. Also the intermediate particle is a fermion, not a photon.
May28-12, 11:13 AM   #3
Recognitions:
There's a recent thread on this exact same question. I argued that the Breit-Wigner formula does apply, just put E0 = Γ = 0.
The intermediate particle is always virtual, how could it not be??
May28-12, 11:20 AM   #4
mfb
Mentor
For processes like [itex]e^+ e^- \to \gamma \to \mu^+ \mu^-[/itex], I think you can use your formula. E0 for a photon is 0.
May28-12, 05:07 PM   #5
Thank you for your replies guys!
Bill_K and mfb:
I agree with you guys that this formula should apply. However, if [itex]E_{0}[/itex] = 0, this would suggests that the resonance would happen when [itex]E_{CM} = 0[/itex] for all positron electron annihilation reactions.
In particular, if you like at
http://pdg.lbl.gov/2011/hadronic-xse...crpp_page6.pdf
The graphs shows that resonance (the red lines) happen at E_CM differ from 0. Those red lines actually correspond to the production energy for the corresponding mesons. In other words, if we are allowed to apply this formula to the problem, [itex]E_{0}[/itex] should not zero. So the new question would be, how should we determine [itex]E_{0}[/itex]?
May29-12, 10:53 AM   #6
mfb
Mentor
The resonances are usually due to particles produced from the photon, with the Z as exception. The whole energy range is far away from 0 (and has to be, as you have at least 2 electron masses), therefore you cannot see this resonance as a peak.
May29-12, 04:35 PM   #7
Thank you for your reply mfb!
And then can we use the Breit Wigner Formula to understand the non-zero energy resonances in http://pdg.lbl.gov/2011/hadronic-xse...crpp_page6.pdf?
May30-12, 08:53 AM   #8
mfb
Mentor
Should be possible, if you use the parameters for the different particles there.
J/psi, psi(2s) and the Upsilon particles are quite long-living (small Gamma), which gives them narrow peaks. In contrast, particles like Z and omega are short-living, they have broad peaks.
New Reply
Thread Tools
Similar Threads for: Breit Wigner Formula
Thread Forum Replies
Breit Wigner for photon intermediates High Energy, Nuclear, Particle Physics 4
(urgent) Can someone help me understand the factors in the Breit-Wigner formula? High Energy, Nuclear, Particle Physics 7
Breit-Wigner formula High Energy, Nuclear, Particle Physics 6
Breit-Wigner Formula High Energy, Nuclear, Particle Physics 1
Breit-Wigner Cross section High Energy, Nuclear, Particle Physics 1
