How does special relativity account for the time on a single moving clock?
The discussion revolves around the relationship between clocks and time in the context of special relativity, exploring how time is measured and understood in different frames of reference. Participants engage with the implications of synchronization conventions and the philosophical aspects of time, while also referencing empirical evidence and historical context.
  • Historical
  • Some participants argue that clocks and time are fundamentally different, with time being a natural property observable through changes, while clocks are man-made devices that measure time.
  • Others propose that synchronization conventions, such as Einstein's, are arbitrary choices that do not reflect a fundamental property of time, suggesting alternatives like slow clock transport.
  • A participant emphasizes the importance of empirical evidence in understanding Einstein's theory, particularly the light postulate and its implications for measuring time.
  • There is a contention regarding the philosophical implications of time measurement, with some asserting that discussions about the nature of time belong in philosophical contexts rather than scientific ones.
  • Some participants express frustration with the philosophical debate, advocating for a focus on measurable behaviors of clocks and their relation to empirical science.
  • Historical references are made to Lorentz's explanations of the Michelson-Morley experiment, highlighting the evolution of thought leading to Einstein's theory.
Participants exhibit a mix of agreement and disagreement, particularly regarding the nature of time and the implications of synchronization conventions. While some acknowledge the arbitrary nature of these conventions, others defend the validity of Einstein's approach. The discussion remains unresolved with multiple competing views present.
Participants note that the debate over the nature of time and clocks involves assumptions about definitions and the philosophical implications of measurement, which may not have experimentally testable consequences.
  • #121
I know this is an early post, but it seems relavent now.
DaleSpam said:
I don't know why you would claim that. Isn't t the time according to clocks in the moving frame?
Clocks do only what they are told. The theory says that the time of the moving frame is given by c t' = gamma(c t - v x / c ). This means that the moving clock is instructed ( or built ) to accept t, x, and v/c as inputs and to display the result as t'. Thus the moving clock has no initiative of its own to decide what time to display, but must display what the stationary frame tells it to.
JM
  • #122
Clocks measure proper time. If something doesn't measure proper time then it isn't a clock.
Proper time doesn't need any reference to a mythical "stationary" frame.
  • #123
ghwellsjr said:
I don't know what you mean by a linked frame and I see no advantage or need for an accelerating frame when any inertial frame will do everything that needs to be done and so much more simply. So I'm not the one to ask about other types of frames but I see DaleSpam has provided an answer. It's a good bet to trust what he says.
Refer to 1905 section 4: "It is at once apparent that this result still holds good if the clock moves from A to B in any polygonal line, and also when the points A and B coincide."
It is not apparent to me. If it is to you,can you explain it to me?
Where are the points A and B in terms of x,y,z,t, and where is the polygonal line? The theory of section 3 refers to clocks moving parallel to x, so how to make a polygon out of that? The picture that sentence suggests to me is a series of stationary frames, each one aligned along one segment of the polygonal line, with an accompanying moving frame. The change of direction from one segment to another implies an acceleration of the clock. I don't see anything in section 3 about that. If one clock is on the equator and the other is at the pole then their positions will never coincide. So what is the explanation?
I'm sorry, I can't figure out what you mean here. What are the moving clock's roots in the stationary frame and what 'events' are you talking about?
See the posts on page one of this thread, and the one just above.
I thought we resolved that the confusion was over Taylor and Wheeler's restrictive definition of a 'proper clock' and you were fine (post #107) with the fact that any moving clock, inertial or not, will tick more slowly than the co-ordinate clocks in the frame in which it is moving
The confusion was about the meaning of the phrase 'moving clocks run slow'. It was cleared up with the qualifier that proper clocks run slow, not arbitrary coordinate clocks. We didn't get to what a correct definition of a proper clock is. I am fine with inertial clocks being slow, but not non-inertial ones. As I noted above, I don't see how the inertial analysis of section 3 applies to non-inertial clocks.
The link to the book was provided by harrylin in post #18 and quoted by you in post #23 so I thought you had taken a look at it.
I have that book, and I have read it. I don't recall anything about clocks moving in various directions, or all clocks being proper. I was hoping that you could suggest a text better than Taylor.
Thanks again for your efforts.
JM
  • #124
In section 3, the clocks were moving parallel to x because it is conventional in the standard configuration of the Lorentz Transformation to align the axes so that the motion is along the x-axis. It doesn't matter physically which direction the motion is in, we just assign the two co-ordinate systems so that the relative motion between them is along the x-axis. Remember, all frames are equally valid, including ones where the only difference is the orientation of their axes.
So once Einstein establishes that any clock that moves in a reference frame along the x-axis will tick at a slower rate than the co-ordinate clocks of that reference frame, he generalizes the concept to include any clock moving in any direction and he says to pick any two additional clocks, one at any point A and one at any other point B, not necessarily aligned along the x-axis, which had previously been synchronized with each other when at relative rest, and move the one at A to the position of the one at B at some relatively slow velocity v, then when it gets there, it will be slow by ½tv2/c2 compared to the clock at B. (Note that this formula is approximate and only applies to a slow-moving clock.)
Then he says that we can repeat the process, moving the A clock from the first B position to another B position in any other direction and we will get the same additional difference in clock time when it gets there. We can repeat the process as many times and in as many directions as we want, even to the point where we eventually return the A clock to its original location and the same formula applies if we take the total time t for the clock to make its round trip. This is what he means by the A and B points coinciding.
You can do the analysis with multiple additional frames if you want, but it is just more complicated with no additional increase in knowledge.
Prior to space travel (or sustained air travel), this was the only way to carry out the experiment. And it still would work, neglecting any effects from gravity, even if the clocks don't ever come to the same location because we are considering just one inertial rest frame, that of the clock at the pole. But of course nowadays, we just have the moving clock take off in a spaceship (or airplane, which has been done).
Don't be confused by the oft-repeated statement that clocks have to be co-located at the start and end of the journey of one of them to compare times. All frames will show that there is a difference in accumulated times, even if they don't agree on the absolute times on the two clocks (because of simultaneity issues).
JM said:
ghwellsjr said:
I'm sorry, I can't figure out what you mean here. What are the moving clock's roots in the stationary frame and what 'events' are you talking about.
You repeated several times that man-made clocks do what we tell them to do but let's assume that they all have one thing in common, they tick once per second. Then the only issue is how many ticks have transpired between point A and point B, agreed? In this sense, we can treat them as stop watches, even if they actually display time as hours, minutes, and seconds or if they count backwards.
But the point is that no one makes a clock that is designed to tick slowly when it is traveling with respect to some rest frame--how in the world would they do that? And you overlook that fact that two identical clocks in inertial relative motion would each tick more slowly compared to its own tick rate. How do you design clocks to do that? No, it happens independently of any purposeful design, in fact if you tried to make it happen, it wouldn't be reciprocal.
It wasn't cleared up by the qualifier that only "proper clocks" run slow and we did get to the correct definition of a "proper clock". But it is not a generally acknowledged definition. It is what I would call a private definition made by Taylor and Wheeler on page 10 of their book which you pointed out. No one else talks about a "proper clock". Instead, we keep repeating that all clocks keep track of "proper time". This applies to inertial clocks and non-inertial clocks, moving clocks, stationary clocks, accelerating clocks and co-ordinate clocks. All clocks keep track of their own proper time. They don't have any choice. Of course we are talking about carefully designed clocks that aren't affected by environmental effects, such as a pendulum clock.
Well, I hope you can see it now.
JM
Here is the link to Einstein's 1920 book: http://www.bartleby.com/173/.
Now if you look at the end of chapter 12, you will see this statement:
As a consequence of its motion the clock goes more slowly than when at rest.
Then if you look at chapter 23, you will see where Einstein once again discusses a clock moving in a circle with respect to a stationary clock.
  • #125
All moving clocks run slow, not just proper clocks. See the formula I posted above. It applies to all clocks, inertial or non inertial.
What is a coordinate clock? That is also a non standard term. Is it defined somewhere or are you just making things up?
  • #126
JM said:
So, what is your definition of proper time?
The accepted definition of proper time is the Lorentzian ( or proper) length of a segment of a worldline. Consider a piece of string. The length of the string is independent of its shape because we use the Euclidean definition ,
Length = √( x2+y2+z2)
But worldlines are 4-dimensional and the proper length is given by the Lorentzian length,
L = √( c2t2-x2-y2-z2) or T = √( t2-x2/c2-y2/c2-z2/c2)
with this definition of length, the strings length depends on its shape. A twisty bent piece of string is shorter than it would be if measured stretched out.
This is why the traveling twin is younger than the stay at home twin
OK, so where do I find out about these things?
JM
Read, ask and listen. You could start here
http://en.wikipedia.org/wiki/Proper_time
  • #127
OK.
..., he generalizes the concept to include any clock moving in any direction and he says to pick any two additional clocks, one at any point A and one at any other point B, not necessarily aligned along the x-axis, which had previously been synchronized with each other when at relative rest, and move the one at A to the position of the one at B...
Suppose that A is at (x,y,z) = (0,0,0) and B is at (x,y,z) = ( 1,1,0). Within section 3, where all clocks move parallel to x, there is no clock that passes through these two points. One option is to add an extra clock that is not at rest in either K', moving or in K, stationary. But would that clock follow the same 'slow clock' formula? Another option is to align the axes of the moving frame with the line passing through these two points. For this option the moving frame must then be re-aligned again to get the clock to the second point B. This is the option that I refer to. Do you see another option?
In general,OK. But let's examine the idea that they all tick once per second. The clocks of K, stationary, can be considered as reference clocks and ,for convenience, assumed to be adjusted to match the day-night cycle of the earth( on average). This is what I call everyday time. But what about the moving clocks? Are you saying that the moving clocks also are adjusted to everyday time? i.e. that one second on a moving clock is the same as one second on a statioinary clock? The transform equations seem to demand this; if t is entered in seconds then the resulting t' must be also measured in the same seconds. Also, section 3 asserts that ' the clocks are in all respects alike'. But if this is so, then all clocks are running at the same rate, so how can a moving clock be said to run slow? Could it be a matter of terminology (or translation), with the meaning actually being that an interval between two events is different as measured by moving clocks than by stationary clocks, even thouth both clocks are running at the same rate? This seems to me to be a better view, because when comparing two things it is necessary to use the same units, if the clocks are running at different rates then the measurements are meaningless.
Can I infer from this that your definition of proper time is simply the time of any clock? With no need for any 'events' for the clock to mark?
I have checked and my book has the same statements in the same places, so we're talking about the same book. Aren't the items you refer to just re-statements of the same things as presented in 1905?
I am still puzzled by your, and DaleSpams, reluctance to identify published sources for your ideas. Surely there must be some, what gives? The responses to my posts suggest that there is a line of theory that is not wholly included in Einsteins works. I have heard of world lines, maybe in French, and Taylor hints at a different viewpoint. Us old timers prefer paper books to internet, maybe because of editing and reviewing.
I can see that you have put much effort into this conversation, and I appreciate it.
JM
  • #128
Don't these definitions mean that a line between two points connected by a light ray has zero length? Does that make sense?
[/QUOTE]http://en.wikipedia.org/wiki/Proper_time[/QUOTE]
Thanks for the reference, I'll look into it.
JM
  • #129
I don't understand this comment at all. I posted the Wikipedia link on proper time back in post 30-something when I first joined this thread. Please start there, it will be the best resource for an introduction, and is entirely sufficient for this conversation.
Once you understand the Wikipedia page then you can search for "spacetime interval" or "line element" or "spacetime metric" or "Riemannian metric" for more information, but most of that will be too advanced until you have mastered the material on the Wikipedia page.
If you specifically want paper-published sources then any introductory SR textbook will include material on proper time although it may be called "spacetime interval", or "invariant interval". You have some textbooks already, just start in the index there if you don't like Wikipedia.
  • #130
Yes. Such lines are called "null" or "lightlike".
  • #131
JM said:
OK.
Since Einstein was living in an era where fast space travel was not possible, he was merely simplifying the analysis by using the 'slow clock' formula but the exact formula will still work and should be used where the difference between the two answers would be significant. So this option is perfectly viable.
This is the option I put in bold above.
I don't see the need for another option, do you?
There was a time, many decades ago, when the rotation of the Earth was the most stable standard for a second, but now that we can make atomic clocks that are more stable, it would be meaningless to continue with that standard and so now we use atomic clocks as a standard to define what a second means. But that presents the problem that you are asking about. Not only will moving clocks tick at different rates (as analyzed by Special Relativity) but clocks at different altitudes will also (as analyzed by General Relativity). So it is a real problem that has to be dealt with and fortunately we have very smart people who have come up with a solution to provide us with a coordinated everyday time which is called "Coordinated Universal Time". The clocks on board GPS satellites are examples of moving clocks that have to be adjusted to everyday time and our GPS devices take care of the problem so that we can all make it to our meetings at the same agreed upon time. But if you were doing physics experiments, such as measuring the speed of light, you would not use the time standard provided by GPS because you will get the wrong answer. Instead, you have to use your own atomic clock to provide you with the measurement of time.
We can't ignore the issue of moving clocks ticking at different rates and rather than saying it is all meaningless, we have agreed upon conventions to make the best sense out of the situation.
Yes, except it's not my definition, it was promoted by Minkowski in 1908. Einstein apparently didn't see the need to have a special term for something that applies to all clocks. But in terms of talking about the time between two arbitrary events, there is no single answer to that question because two clocks traveling in different ways between those two events can have a different answer. The term "proper clock" was coined to apply to an inertial clock that travels unaccelerated between those two events.
Yes, that was my point.
JM
I think you are referring to Minkowski's re-interpretation and re-statement of Einstein's ideas. Einstein gave passing mention of his work in chapter 17 and near the end of his 1920 book. It is basically a graphical presentation of the Lorentz Transform and served as an important graphical aid in an era in which calculators and computers and videos were not available. But it is of necessity limited to one dimension of space. Nowadays, two-dimensional animated presentations are readily available to communicate the same ideas much more effectively. I never bothered to study Minkowski's work so I don't know what would be a good reference but I'm sure there are plenty.
  • #132
When Mentz says "length", he means "spacetime interval" which can physically be either a spatial length or a time period, depending on the two events.
If an inertial clock can be present at the two events, then the spacetime interval is "timelike" and is the accumulated time on the clock. This is Taylor and Wheeler's definition of a "proper clock". There is an inertial frame in which the clock is at rest.
If the two events are so far apart that a physical clock could not get from the first event to the second event, then the spacetime interval is "spacelike" and is measured with an inertial ruler spanning between the two events and in a frame in which it is at rest. Taylor and Wheeler did not call this a "proper ruler" but they could have.
Since light rays don't have rest frames, the concept of a spacetime interval is meaningless for events that a light ray is present at both of them.
  • #133
I wouldn't agree that a null spacetime interval is entirely meaningless. It lies on the boundary between spacelike and timelike intervals, is called a "lightlike" interval and the events can be causally connected and is very useful for a lot of calculations.
  • #134
I looked at that Wike page and it looked like just a list of formulas, with no supporting theoretical foundation. Where is the foundation?
Yes, I have textbooks, but they don't answer the questions that I've asked in this thread, if they did I wouldn't have asked.
So, can you recommend a specific ' introductory SR textbook' , or not?
JM
  • #135
Well, George, we seem to be out of synch again.
I still don't see the principles or math that justify the generalization from clocks moving along x to clocks moving in arbitrary directions.
At one point you seemed to say that all clocks (did you mean both moving and stationary?)tick at the same rate, ie one tick per second. I cited reasons to believe this. Then, above, you say that moving clocks tick at a different rate. So, which is it?
So you don't read Minkowski, don't like Taylor, and don't have a suggested text. Then where do you get your ideas about SR?
JM
  • #136
Wikipedia always puts a list of references and external links down at the bottom. In this case, the theoretical foundation is pretty simple so there are only a couple of references. The rest is a more practical introduction, which I found very helpful.
I cannot recommend an introductory SR textbook, mine was terrible and I found Wikipedia much better. I would recommend starting with chapter 1 of Sean Carroll's lecture notes on GR:
http://arxiv.org/abs/gr-qc/9712019
Chapter 1 is just SR, and he introduces the spacetime interval on page 3 and makes the connection to proper time on page 26.
  • #137
Then that must be because there is a relative speed between us.
Well, it's simple. The direction of the x-axis is arbitrary. So once we establish that a clock moving along the x-axis in our arbitrarily defined Frame of Reference ticks slower than the coordinate clocks in that Frame of Reference we certainly don't want to conclude that if it moved in some other direction, it would not also tick slower, would we? If that bothers you, then just do the arithmetic to rotate the frame and show that the same thing happens in the rotated frame.
All clocks that are stationary in a given Frame of Reference tick at the same rate. All clocks that are moving in that Frame of Reference tick slower than the clocks that are stationary.
JM
From Einstein's 1905 paper and his 1902 book.
JM, I think your confusion stems from the fact that when we define a Frame of Reference, we establish a time coordinate that extends spatially infinitely in all directions so that we can say that all the clocks read zero when the clock at the origin reads zero and then when discussing the Lorentz Transform we talk about a second Frame of Reference moving with respect to the first one and having their two origins coincide so that all the clocks in that second Frame of Reference are also zero everywhere and this leads you to the conclusion that all the clocks in both frames are synchronized to each other at time zero. But this is not true. At every location there are two clocks, one for each frame and except for the single pair at their common origin which both read zero, all the other pairs of colocated clocks read different times from each other. Do you understand this?
  • #138
I meant, of course, his 1920 book, as mentioned earlier:
ghwellsjr said:
Einstein's 1905 paper develops everything you need to know about Special Relativity although some of his other writings are also helpful, such as his 1920 book.
  • #139
Thanks for the reference. I've downloaded it for later study.
Out of curiosity, I wonder what your intro text was. Maybe I've read it.
Do you accept a single moving clock, not at rest in either the stationary frame K or the moving frame k', as a valid element in a SR analysis? From some of your posts I would think so, but to be sure. So, suppose there is K, k' moving at v, and a single clock moving at speed u along the x axis. What is the time on the single clock and how would you find it?
JM
  • #140
Good one. But did we both start at zero at post 1?
George, I think the following is appropriate, even if it doesn't directly answer your points.
Regarding the axis rotation, re. the 'twins': Suppose the stationary frame K, and another stationary frame rotated to pass through the points mentioned before, and a moving fraame aligned with the rotated frame. I can see the relation between the rotated frames being the same as the relation between K and k'. But I don't see the details of the relation between the rotated moving frame and the original frame K.
I think that the 'tick rate' needs explanation. The time transform and the slow clock formula both demand that t and t' are measured in the same units. In 1920 chapt 12, the discussion seems to support this idea. So if t and t' are in seconds, and tick rate is defined as one tick per second then the tick rate is the same for both. But ch 12 does something different. It calculates the time elapsed by t during the time between ticks of t'. Consider the slow clock for v/c = 0.8: t' = 0.6 t. If the tick rate of t' is defined as the time elapsed by t' between two ticks of t, then the moving clock ticks at a different rate than than the stationary.
Re your last point: If t = 0 then ct' = -mvx/c. So the distant stationary clock reads 0, while the distant 'moving' clock doesn't.
You asked what I meant by the 'roots of t' '. Consider section 4, 1905, where it is stated that x= v t. This statement identifies the locations of points wrt K that transform to the point x' = 0 of k'. The analysis process, though not explicitly stated, is as follows:
1.Identify the position of a clock wrt k'. For the above x' = 0.
2.Enter this value in the space transform, x' = m(x-vt). This leads to x = vt.
3. Enter this value into the 'time' transform, ct' = m(c t -vx/c). This leads to t' = t/m.
Thus the time t' depends on the values of x and t. ie the 'roots' of t' in K ( when viewing from K ). Without the values of x and t how would t' be found?
This process can be used in other cases.
1. Let t' = 0. From the 'time' transform ct = vx/c. Enter this value in the 'space' transform, to get x' = x/m, the 'space contraction' formula.
JM
  • #141
The expression that all clocks tick at at a rate of one second per second relates to a comparison of one ideal clock to another ideal clock that are adjacent to each other and stationary with respect to each other. When clocks are moving relative to each other then they can experience different tick rates relative to each other and accumulate different times when reunited. For example consider a clock (A) that is transported from Earth to Mars by an inertial rocket. Another clock (B) leaves Earth at exactly the same time (Earth time) as clock A, but takes the scenic route to Mars via Jupiter and arrives at Mars at exactly the same time (Earth time) as clock B. Clock B takes the longer route so of necessity the rocket that transports clock B has to travel faster than the rocket that transports clock A. If clocks A and B were synchronised just before they left Earth, then clock B would show less elapsed time than clock A when they both arrive at Mars. Do you agree that clock B must have been ticking slower than clock A?
The elapsed (proper) times recorded by both clock A and B are in turn less than the time recorded by the clocks at rest with respect to Earth and Mars. The latter time interval is a coordinate time interval as is a calculated time rather than a time measured by a single clock that is present at all events. The times measured by clocks A and B are proper time intervals as they are measured by single clocks present at both events. Note that clock B is a non inertial clock, but it nevertheless records a proper time interval that all other observers can agree on. The proper time interval is not necessarily the same as the invariant time interval which only applies to the inertially moving clock and this interval is always the longest proper time recorded by a single clock present at both events. Also note that while people here state that coordinate clocks record proper time, that the coordinate time interval between the two events can be longer than the invariant interval. The important concept here is that while individual "coordinate clocks" that are at rest in given reference frame record proper time just like any other ideal clock, coordinate time intervals are calculated using multiple clocks or radar measurements and are not proper time intervals.
JM
Except in some weird coordinate systems, clocks are assumed to run naturally and are not built to run at different rates in different reference frames. Any difference in clock rates is completely natural. For example the "clock" could be a lump of radioactive material which records time by measuring how much un-decayed material is left.
I think it is clear that most people here are not happy to use the terms "proper clock" or "coordinate clock". Perhaps for the sake of this thread we should stick to terms like "proper time interval", "invariant time interval" and "coordinate time interval", that hopefully most of can live with.
As for the expression "moving clocks run slow", I think it would be better to expand that to "in a given inertial reference frame, moving clocks run slower than stationary clocks".
Hi Dale, it seems that you now accept there is such a thing as a proper clock and it is defined as a single inertial clock that is present at both events, but I would agree is it a non standard term.
Yes, this a non standard term and I guess they mean a stationary synchronised clock in a given inertial reference frame. However, being non standard its use is open to interpretation. I think a better term is "coordinate time interval". I think you would agree that while all clocks record proper time, that the coordinate time interval between two events is observer dependent and can be longer than the invariant time interval. Without being an expert on terminology, I think we need a term that conveys the measurement of a time interval between two events that is not a proper time interval, even though all clocks measure proper time.
  • #142
My intro text was Serway.
Yes, SR can easily handle a single moving clock.
I would find it using the proper time formula that I posted earlier. As I have repeated multiple times that is the formula for any clock undergoing any motion in any frame.
  • #143
JM
Pauli's textbook on SR and Minkowski's EM (plus the basics of GR) is pretty decent IMO. Though it is oriented towards serious physics or engineering students. It's inexpensive and was written in the 1920's so it doesn't have newer, more abstract, more exotic developments in the field.
  • #144
Where are the points A and B in terms of x,y,z,t, and where is the polygonal line? The theory of section 3 refers to clocks moving parallel to x, so how to make a polygon out of that? The picture that sentence suggests to me is a series of stationary frames, each one aligned along one segment of the polygonal line, with an accompanying moving frame. The change of direction from one segment to another implies an acceleration of the clock. I don't see anything in section 3 about that. If one clock is on the equator and the other is at the pole then their positions will never coincide. So what is the explanation?[..]
Without following that discussion, I saw a later post by you from which it appears that it's still not clear to you. Maybe useful if someone else gives a try?
- A and B are different "stationary" points (xA, yA, zA) and (xB, yB, zB).
- the straight constant speed trajectory AB is one line of the polygon.
- the straight same constant speed trajectory BC is another line of the polygon. The Lorentz transformation relating "time" in a co-moving frame along AB is identical to that along BC: x is by definition the direction of motion. And obviously from point B the clock has to continue its counting from where it was the moment before - that's just common sense.
- A polygon implies in practice a high acceleration during a very short time. Einstein was writing for physicists who know that such quick changes of direction have only a small effect on common clocks compared to the clock count over long straight trajectories. So, if that's an issue for you: yes obviously he neglected that as well as the other common things that are commonly neglected in physics as they are usually small as well as clock dependent, and instead he did an "ideal" clock calculation. The transformation relationships also have zero memory effect.
Thus he compared an implicit classical calculation according to which "ideal" clocks are unaffected by such a trajectory with the prediction of the new theory.
- What you didn't ask, is why he wrote "If we assume that the result proved for a polygonal line is also valid for a continuously curved line"; but that implicitly answered one of your questions. For in that case we cannot assume that we may neglect the effect of acceleration because of the very short duration, since there is a constant acceleration over the whole trajectory. However, clocks can be made to be insensitive to acceleration according to classical mechanics and SR predicts no effect from acceleration itself, so he merely assumed no effect from that. Note that SR ignores the effect from gravitation and if he suspected a possible effect from that then he overlooked the non-round shape of the earth, but that's another topic.
- The Lorentz transformations impose corrections to classical laws; and exactly there, in that passage, Einstein concluded what consists of a law - the law of "time dilation" or "clock retardation". That law should be valid for clocks anywhere - for example at the equator and at the pole. You can also relate it back to transformations if you remember that all ideal stationary clocks are supposed to remain in synch, so that according to SR a clock at the pole will remain in synch with a clock at the equator which does not participate in the rotation of the earth. And you can then compare that clock with the one that is rotating with the earth.
Does that help?
  • #145
I use the term "coordinate clock" all the time. I never realized that it doesn't have a formal definition but it seems to me that everyone would understand that it is referring to the clocks Einstein described at the end of section 1 of his 1905 paper introducing Special Relativity:
It is essential to have time defined by means of stationary clocks in the stationary system, and the time now defined being appropriate to the stationary system we call it “the time of the stationary system.”
The term was in use on this forum before I signed on in Sept 2010, for example this one from Feb 2010:
JesseM said:
Proper time is just the amount of time elapsed on a physical clock. If a clock is moving inertially, then the proper time between two events on its worldline is the same as the coordinate time between those events in the clock's own rest frame (remember, coordinate time in an inertial frame is defined in terms of the readings on a set of clocks at rest in that frame, so if the clock whose proper time you're interested is also at rest in some frame then it'll be at rest right next to one of these coordinate clocks, so naturally both keep time with one another). Likewise, if a clock is moving inertially, then in a frame where the clock is moving at velocity v, if the coordinate time between two events on its worldline is t then the proper time the clock experiences between those events is t*squareroot(1 - v2/c2), that's the physical meaning of the time dilation equation. But again, proper time is more general than either of these descriptions since you can talk about proper time for a non-inertial clock too.
I don't recall if this is where I picked up the use of the term but I just thought it was one of those things that was in such wide general use that everyone would know what it meant even if it wasn't specifically defined somewhere.
  • #146
I use the terms coordinate time and proper time, but I don't think that i have ever used the terms coordinate clock or proper clock. I don't like either of those terms. A clock is an object which marks proper time along its worldline. If an object does that then it is a clock, if not then it isn't. I don't see the need to add additional qualifiers, nor the benefit of doing so.
Also, you get into problems in coordinate systems where the time coordinate is non-uniform. E.g. you might have a coordinate system where 1 s of coordinate time was equal to 3 s of proper time for a clock at rest in the coordinate system. So would a "coordinate clock" mark 1 s or 3 s in such a case? The distinction doesn't add any clarity.
  • #147
I agree with regard to the term "proper clock", as I told JM back in post #112:
ghwellsjr said:
"Proper clocks" is a very simple subject once you know what Taylor and Wheeler mean by them. This term was brought up by you and you brought up the Taylor and Wheeler reference. I don't like their approach nor their confusing, non-standard, "proper clocks" term. I would advise that you just forget about them as a bad experience.
But since Einstein repeatedly used the term "stationary clock" and I often used the term "stationary coordinate clock" in this thread to mean exactly the same thing that Einstein meant, I don't see the problem with sometimes using "coordinate clock" in the same context. We are talking about the inertial clocks that have been previously synchronized to establish an inertial coordinate system, as Einstein said:
Thus with the help of certain imaginary physical experiments we have settled what is to be understood by synchronous stationary clocks located at different places, and have evidently obtained a definition of “simultaneous,” or “synchronous,” and of “time.” The “time” of an event is that which is given simultaneously with the event by a stationary clock located at the place of the event, this clock being synchronous, and indeed synchronous for all time determinations, with a specified stationary clock.
I have no idea what you are talking about here but I don't think it can be related to what Einstein said with regard to inertial coordinate systems in Special Relativity, which is what this thread is about.
  • #148
You are correct. It is just that, for pedagogical reasons, I do not like to introduce non-standard terminology, particularly when it provides little or no present benefit and may cause future problems.
  • #149
What would you call the clocks in the latticework described by Kip Thorne on page 3 of his upcoming http://www.pma.caltech.edu/Courses/ph136/yr2011/1102.2.K.pdf?
  • #150
Serway is one I haven't seen.
My answer is t' = [1/m + v2/c2 - uv/c2t.
Whats yours?
JM
  • · Replies 22 ·
  • · Replies 33 ·
  • · Replies 54 ·
  • · Replies 29 ·
  • · Replies 20 ·
  • · Replies 21 ·
  • · Replies 20 ·
