New Reply
Hard integration by parts question, need help
Share Thread
Jun23-12, 11:21 PM   #1
1. The problem statement, all variables and given/known data
Integral, from 4 to 6, 1/(t^2-9) dt
2. Relevant equations
please use my approach to solve it, like with cosh and whatnot
3. The attempt at a solution
so I multiplied the top and bottom by square root of 9.
which got me square root of (t/3)^2 - 1 in the denominator.
so I got integrated that into arccosh (t/3) - arccosh (t/3) from 4 to 6
after some solving, it came down to square root of 9 times ((ln(2)+squareroot3))-(ln(4/3)+squareroo… And that is where I got stuck. If I distribute in the square root 9,it should be (3 ln(2) + square root 3) - (3 ln (4/3) + square root (7/9)), which results in (ln 8 + 3*square root 3) - (ln (4/3)^3 + 3*square root (7)). But when I distribute the square root 9 in and when it multiplies with ln(2), for example, it should be ln 2^3 and not ln 2*3 based on the multiplication rule of natural log. But by doing the wrong way, it perfectly leads to the answer, which is ln(6+3*square root 3)/(3+square root 7)
Please help
Thankssss
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Jun24-12, 12:28 AM   #2
I'm a bit confused as to the approach you're taking. If you split that given fraction to get partial fractions, you can integrate each term easily, for which will you get log functions, substitute the values and then you're done.
Jun24-12, 02:36 AM   #3
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Retired Staff Staff Emeritus
You might want to learn how to write equations here.
http://www.physicsforums.com/showthread.php?t=546968
Jun25-12, 12:24 PM   #4
[itex]t^2-9=(t-3)(t+3)[/itex]. Partial fractions, and you're done.
Jun25-12, 03:41 PM   #5
Recognitions:
Quote by limelightdevo View Post
$$\int_4^6 \frac{1}{t^2-9}\,dt$$
Also known as 3.
What you've said so far doesn't make sense. This is what you said you did:
$$\int_4^6 \frac{1}{t^2-9}\,dt = \int_4^6 \frac{3}{3(t^2-9)}\,dt \ne \int_4^6 \frac{1}{\sqrt{(t/3)^2-1}}\,dt$$ The rest of what you did follows from this mistake, so it's all wrong. What I think you meant was that you factored 9 out of the denominator:
$$\int_4^6 \frac{1}{t^2-9}\,dt = \int_4^6 \frac{1}{9[(t/3)^2-1]}\,dt$$ Still, the square root wouldn't appear out of nowhere. Or perhaps you mistyped the original problem here, and what you did was
$$\int_4^6 \frac{1}{\sqrt{t^2-9}}\,dt = \int_4^6 \frac{1}{\sqrt{9[(t/3)^2-1]}}\,dt = \int_4^6 \frac{1}{3\sqrt{(t/3)^2-1}}\,dt$$ because that would be okay so far.
Please help
Jun25-12, 08:19 PM   #6
Think you forgot to put a square root in your question, or you wouldn't have got the answer you got. I used a sec substitution and got ##\displaystyle\ln\left(\frac{6+3\sqrt{3}}{4+\sqrt{7}}\right)##, which is slightly different to your answer.
New Reply
Similar discussions for: Hard integration by parts question, need help
Thread Forum Replies
integration by parts question Calculus & Beyond Homework 4
Tricky integration by parts question Calculus & Beyond Homework 5
quick question on integration by parts Calculus & Beyond Homework 7
integration by parts question Calculus & Beyond Homework 10
[SOLVED] integration by parts question Calculus & Beyond Homework 3
