| New Reply |
spray that creates skeleton |
Share Thread | Thread Tools |
| Jun25-12, 01:48 PM | #1 |
hello!
is there a material that will be sprayed through a tube inside a 3D labyrinthine structure and it will create a skeleton inside that labyrinthe? thanks! |
| Jun25-12, 02:28 PM | #2 |
I very much doubt it, but can you clarify your requirements a bit?
| Jun25-12, 02:33 PM | #3 |
yes, imagine a structure like a tree with branches
now imagine the branches to be hollow then, insert a tube into tree's trunk and fill the whole structure with a spray now, that spray should create inside that structure a skeleton that support the hollow branches to collapse the skeleton can be formed by solid lines of material that will run in parallel with the walls of the hollow structure, or the solid lines can be vertical to the hollow structure's walls |
| Jun25-12, 02:39 PM | #4 |
Okay, then. That's still a little vague, but I think that I have the gist of it. Would expanding polyfoam, as is used for insulation, serve your needs? I think that there is also a polycarbonate mix that expands similarly but is far stronger.
| New Reply |
| Thread Tools | |
Similar Threads for: spray that creates skeleton
| Thread | Forum | Replies | ||
| QFT. Effective action and the skeleton expansion, how the legendre transform works!! | Advanced Physics Homework | 0 | ||
| No pay, No Spray?! | General Discussion | 118 | ||
| Skeleton of the universe? | Cosmology | 62 | ||
| a Carbon skeleton with 2 diff functional groups | Chemistry | 4 | ||
