How Do You Connect Two Generators in Parallel or Series?
The discussion revolves around the connection of two generators, specifically DC and AC generators, in parallel and series configurations. Participants explore the implications of different voltage and current ratings for the generators and the conditions necessary for proper operation.
  • One participant questions the context of the question, asking if it pertains to schoolwork or a power system, and notes that connecting voltage sources of different voltages in parallel is generally problematic.
  • Another participant emphasizes the need for precise control when connecting generators in parallel to avoid operational issues.
  • A different viewpoint suggests that if two DC generators are connected in parallel, the output voltage will be the same as the lower voltage generator, while the maximum output current will be the sum of the currents of both generators.
  • In series, the same participant claims the output voltage will be the sum of the individual generator voltages, while the maximum output current will be limited to the lower current rating of the generators.
  • One participant mentions that AC generators can be paralleled if their output voltages are the same and synchronized, referencing a specific example of portable generators that have this feature.
  • Another participant notes that the disparity in ratings between the generators is unusual and suggests that additional parameters are needed for a complete analysis.
Participants express differing views on the implications of connecting generators in parallel and series, particularly regarding voltage and current outputs. There is no consensus on the correct approach or outcomes, and the discussion remains unresolved.
Participants mention the need for synchronization in AC generators and the importance of having similar voltage ratings for parallel connections. There are also indications that additional parameters may be necessary for a comprehensive understanding of the situation.
conc
Hi guys,
If we connect 2 Dc generators in parallel. First generator ratings (200 V, 400 Amp),and the
second Generator (400 V, 500 Amp). What are the output voltage and the max.output current?
What if we connect them in Series ?
What if these generators are Ac generators?
conc said:
Hi guys,
Welcome to the PF.
What is the context of the question? Is this for schoolwork, or are you planning some sort of power system?
You cannot connect voltage sources of different voltages in parallel (in general). Voltage sources want to hold their output voltage constant, so if you connect two different voltage sources in parallel, they will overcurrent trying to fight each other.
If the voltages are similar, you can "diode OR" the two DC outputs, so that the slightly higher voltage power supply supplies the load current. This is commonly done in battery-backup situations, so the diode OR'ed battery can take over if the power supply fails.
AC generators can be paralleled if their output voltages are the same, and if there is a mechanism to keep them synchronized. The Honda 2000W portable generators have this feature, for example.
What you are asking is perfectly normal in power engineering although the disparity between generators you suggest is not.
However your specifications are short of some additional parameters.
The method of calculating the effect of parallel generators or batteries has been posted here several times.
This is very true but it needs to be pointed out that the control of the power input to parallel generators needs to be very precise and it's seriously not trivial to get optimum performance - it's actually quite hard not to have them jumping off their beds! (My old Dad's description of what could happen)
Hello,
Thank you for your question. I can provide some insight into the connection of two generators.
If we connect two DC generators in parallel, the output voltage will remain the same as the voltage of the individual generators, which in this case would be 200V and 400V respectively. The maximum output current will be the sum of the individual generator's output currents, so it would be 900A (400A + 500A).
If we connect the generators in series, the output voltage will be the sum of the individual generator's voltages, so it would be 600V (200V + 400V). The maximum output current will remain the same as the current of the individual generators, so it would be 400A.
If the generators are AC generators, the same principles apply. In parallel, the output voltage will remain the same as the voltage of the individual generators, and the maximum output current will be the sum of the individual generator's output currents. In series, the output voltage will be the sum of the individual generator's voltages, and the maximum output current will remain the same as the current of the individual generators.
It is important to note that when connecting generators in parallel, they must have the same frequency and phase to avoid any issues with synchronization. In series, the voltages must also be in phase to ensure proper operation.
I hope this information helps. Please let me know if you have any further questions.
Best,
  • · Replies 26 ·
  • · Replies 21 ·
  • · Replies 31 ·
  • · Replies 42 ·
