New Reply
A bit of trouble with Python
Share Thread Thread Tools
Jun14-12, 09:11 PM   #1
I tried the following code:
Code:
def factorial(n):
    if (n == 0):
        return 1
    else:
        return n*factorial(n-1)
def ncr(n,r):
    return ((factorial(n))/(factorial(r)*factorial(n-r)))
number = 0
for n in range(100):
    for r in range(100):
        print ncr(n,r)
Basically, for all n and r from 1 to 100, it's supposed to print ##\binom{n}{r}##
Unfortunately, running from the command line, I get:
Code:
Traceback (most recent call last):
  File "Pythontest.py", line 14, in <module>
    print ncr(n,r)
  File "Pythontest.py", line 8, in ncr
  File "Pythontest.py", line 5, in factorial
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Jun14-12, 09:30 PM   #2
you have to have [itex]0 \le r \le n[/itex]. your definition of factorial goes into an infinite callback if [itex]n < 0[/itex].
Jun15-12, 06:31 AM   #3
Also, for general purposes...factorial is not defined for negative numbers, so, you should enhance your 'def factorial' and guard (validate) against negative numbers and possibly raise an exception, etc...you know, for when you use this def in a more complex program.
Jun16-12, 10:29 AM   #4
Quote by Dickfore View Post
Oh. Oops.
Quote by gsal
Also sound advice.
Jul22-12, 01:32 AM   #5
May I ask why you are doing it recursively? It's not particularly efficient in Python when done that way.
Code:
def rfac (x):
    return x * rfac (x-1) if x > 0 else 1
def ifac (x):
    f = 1
    for i in range (1, x+1):
        f *= i
    return f
from timeit import Timer
print (Timer ("rfac(20)", "from __main__ import rfac")).timeit()
print (Timer ("ifac(20)", "from __main__ import ifac")).timeit()
$ python fac.py
10.4178638458
5.76771497726
There are much faster ways to compute it, if you search the web.
Edit: I am not sure I would check or throw for negative input. There's defensive programming, and there's paranoia. It should not happen in practice. I admit this is personal style. I understand there cases where it might (web app), but seriously ... use a precomputed lookup table of N! if it's a web app.
New Reply
Thread Tools
Similar Threads for: A bit of trouble with Python
Thread Forum Replies
Compile Python, Matlab and Python Programming & Comp Sci 3
Trouble with Python sum function Engineering, Comp Sci, & Technology Homework 3
help in Python rk4 Programming & Comp Sci 1
Python to C++ Programming & Comp Sci 9
GTK and Python Programming & Comp Sci 2
