| New Reply |
Equation of a Circle with a Center and Tangent Point |
Share Thread | Thread Tools |
| Jul30-12, 09:23 PM | #1 |
What is the equation of the circle with a center point of (10, -14) when the circle is tangent to x=13?
D = √(13-10)^2 + (0-(14))^2 D = √(3)^2 + (14))^2 D = √9+196 D = √205 Radius = √205 (x-10)^2 + (y-(-14))^2 = √205^2 (x-10)^2 + (y+14)^2 = 205 But how am I suppose to graph this? |
| Jul30-12, 09:31 PM | #2 |
Before we can help you, you need to show us what you have tried already.
| Jul30-12, 09:48 PM | #3 |
Recognitions:
The problem is actually very simple. You're given that the circle is tangent to x=13, which is a vertical line. You know the centre has an x-coordinate of 10. So what can you say about the radius? |
| Jul30-12, 09:53 PM | #4 |
I meant D to be the distance. I'm not sure how you solve this problem without graph paper.
| Jul30-12, 09:54 PM | #5 |
Recognitions:
There's no need for graph paper. All you need is a reasonable sketch. Remember the general equation for the circle and what the terms represent. |
| Jul30-12, 09:58 PM | #6 |
The distance from the center point to the tangent line to find the radius.
| Jul30-12, 10:08 PM | #7 |
Mentor
What is the issue with graphing? it is a circle, you know the center and radius. What else do you want?
| Jul30-12, 10:19 PM | #8 |
Recognitions:
Also, what you calculated was the distance between the points (10,-14) and (13,0). This is NOT the same as the (shortest) distance between (10,-14) and the line x = 13. Do you see why? Just do a sketch. Do you see why the radius is simply 13 - 10 = 3? (As a final point, there was an error in your working in the first post. The distance should've been [itex][(13 - 10)^2 + (0 - (-14))^2]^\frac{1}{2}[/itex]. Note the sign in the y-term. But the squaring masked your error.) |
| Jul31-12, 07:00 AM | #9 |
I suspect that the real difficulty is that xxmeqxx is thinking, incorrectly, that "x= 13" means the point on the x-axis with x-component 13 rather than, as every here is telling him, the line of all points whose x-component is 13, (13, y). |
| Jul31-12, 07:13 AM | #10 |
Recognitions:
| New Reply |
| Thread Tools | |
Similar Threads for: Equation of a Circle with a Center and Tangent Point
| Thread | Forum | Replies | ||
| Center of circle from two points and a tangent angle | Calculus | 1 | ||
| Find the coordinates of a point on a circle without knowing the center point. | General Math | 2 | ||
| Equation of a tangent line to a given circle from an external point - Stuck! | Precalculus Mathematics Homework | 4 | ||
| How can I find the equation of tangent lines from a circle to point A? | Calculus & Beyond Homework | 21 | ||
| Tangent to y axis with center(-3,4) whats the eqn of circle? | Introductory Physics Homework | 5 | ||
