| New Reply |
Why does length contraction only occur parallel to the direction of motion? |
Share Thread | Thread Tools |
| Aug4-12, 02:23 PM | #1 |
why does space time not contract uniformly in every direction around a fast moving object?
| Aug4-12, 03:00 PM | #2 |
I guess the real question is "why would you think it should contract in all directions?" The fact that there is contraction at all is an unexpected (by classical physics) result that is forced on us by experimental results. And those experimental results show a contraction only in the direction of motion.
The simplest answer to your question is that velocity is a vector quantity. Any contraction due to velocity couldn't very well be perpendicular to the velocity because there is no velocity in that direction. |
| Aug4-12, 05:05 PM | #3 |
The reason length contraction occurs in the first place is to preserve a constant speed of light for all inertial frames of reference. If an observer says that you're moving in only the x direction, then lengths only need to contract along that direction for you to preserve the speed of light. Since you have no motion in the y or z direction, no length contraction is needed in the perpendicular directions.
| Aug4-12, 05:20 PM | #4 |
Mentor
There's also a very simple thought experiment that can be used to show that length contraction can't happen in directions perpendicular to the direction of motion.
Suppose a train is moving alongside a vertical wall that has a blue horizontal line painted on it. The blue line is painted to be at the (rest) height of the centres of the train's windows, as measured the in wall frame. (Let's say we have an observer at rest in the wall's frame who drew the blue line in advance based on what the train's blueprints said the height of the windows was). An observer on the train has a paint brush and a can of red paint. He sticks his hand out the centre of a window and touches the brush to the wall, so that a red horizontal line is drawn as the train moves forward. Suppose length contraction in the vertical direction *did* happen? Then the train observer claims that the wall is in motion, and would see vertical distances on the wall as being shorter than they appear to the wall observer. As a result, the blue line, which according to the wall observer, is as high as the centreline of the windows, would appear lower than this height to the train observer. So, the prediction is that the red line drawn by the train observer would be parallel to, but above the blue line that was drawn by an observer stationary w.r.t. to the wall. But if we repeat this reasoning using the logic of the wall observer, we get a different answer. The wall observer claims that the train is in motion, and therefore vertical distances on the train appear shortened to him. In particular, the vertical height of the centreline of the moving train's windows appears shorter to him than what was claimed in the train's blueprints. So, this observer predicts that the red line drawn by the train observer will be parallel to, but below the blue line. So, we have a logical contradiction, one that no amount of juggling of reference frames can resolve. At the end of the day, either the red line has to be above the blue line, or the blue line has to be above the red line. The only way to resolve this paradox is if the amount of vertical length contraction is 0, and therefore the red line lies directly on top of the blue line, according to both observers. |
| Aug4-12, 06:43 PM | #5 |
I like cepheid's argument, because it's rigorous and also conceptually simple. My only minor criticism is that it depends on a symmetry principle that wasn't invoked explicitly in #4. A's velocity relative to B and B's velocity relative to A point in opposite directions. It's possible that one of these directions produces contraction, and one expansion. To rule this out, we need to assume that space is isotropic.
I would have to look more carefully, but cepheid's argument may be the same as the "nails on rulers" argument given here: http://www.physicsforums.com/showthr...96#post2108296 Another argument is the following. In 1+1 dimensions, one can prove straightforwardly that Lorentz transformations must preserve area. (For a proof, see http://www.lightandmatter.com/html_b...tml#Section7.2 , caption to figure j.) By a similar argument, Lorentz transformations in 2+1 dimensions must preserve volume. The only way that both of these can be true is if lengths in the transverse direction are preserved. |
| Aug4-12, 07:35 PM | #6 |
Mentor
Hmmm, interesting. I don't think I have any problem with Einstein's original axiomatization, but even with his original axiomatization, it seems that MarkM's argument is backwards as you suggest (no offence intended), because the constancy of the speed of light is assumed, and then length contraction is derived as a consequence of it, not the other way around. |
| Aug4-12, 11:55 PM | #7 |
| Aug5-12, 06:13 AM | #8 |
| Aug5-12, 09:16 AM | #9 |
I mean, yeah, you can keep calling the electric field a vector, but then you keep having to remember, well, the ways that it isn't one. Just calling a rabbit a rabbit in the first place is cleaner than calling it a duck first.
| Aug5-12, 09:54 AM | #10 |
Another point to make about #3 is that most people these days are introduced to SR through the pedagogical device of the light clock. In the light clock argument, a necessary assumption is that there is no transverse length contraction. If we admit the possibility of transverse length contraction, then the result of the light-clock argument is underdetermined. You really need some other argument, such as #4, to make the light clock derivation logically complete. |
| Aug6-12, 12:13 AM | #11 |
You can look here - http://www.physicsforums.com/showthread.php?t=544580 |
| Aug6-12, 12:29 AM | #12 |
Isotropy means all directions in spacetime are equivalent. It captures both the principle of relativity and the usual idea that in space alone there is no preferred direction. (In spacetime, a "direction" can also mean a timelike direction, so the two concepts are unified into one.) Isotropy means that (in SR) we live in a vector space in which we are free to choose a basis, and any choice of basis should give equivalent results to all others.
Homogeneity is a related concept, but it means that there is no preferred origin or center of spacetime. This tells us that only intervals between spacetime locations (or quantities derived from such intervals) are physically meaningful, so while we can choose a coordinate origin, this choice should not have physical consequences. It can only be a matter of convenience. Isotropy can give some insight into boosts. Isotropy is what gives us the ability to rotate and boost coordinate systems without changing physically significant quantities. Pick any plane in spacetime, and we are free thanks to isotropy to choose any two basis vectors in that plane and any two basis vectors out of that plane. Isotropy gives us the freedom to reselect the basis vectors in that plane without affecting the ones out of the plane. When that plane is, say, the tx-plane, this means we change the time and x-coordinates of events without changing the y- and z-coordinates, for instance. So, we see that any change of basis whose effects can be confined to a plane can only change components of vectors (i.e. 4-vectors) in that plane and not components out of the plane. I don't presume to say isotropy is the natural or best starting point, but the relationship between isotropy and the ability to freely choose a basis is one I find compelling. It is a symmetry, and with every symmetry comes freedom. This is something worth reiterating throughout physics, regardless of the exact topic at hand. |
| Aug6-12, 10:12 AM | #13 |
| Aug6-12, 10:19 AM | #14 |
Mentor
| Aug7-12, 04:04 PM | #15 |
2. The em fields are weaker by 1/λ in the direction of motion and any transverse direction due to lower frequency of interactions, i.e. time dilation. 3. This allows mass particles to compress in the direction of motion during acceleration. If light speed added vectorially to object speeds, step 1 and the remaining sequence would not occur. |
| Aug8-12, 10:51 AM | #16 |
This is the same as asking why the universe does not have 4 spatial dimensions.
Because it does not. When you ask a question like "why is x this way", you're asking for a decomposition of the fact into other facts that you can readily accept. For example, why do we fall? Because the earth exerts a force on us. Here, the fact that masses exert forces on other masses is the "other fact". |
| Aug11-12, 04:43 PM | #17 |
It is very simple.just read the Lorenz transformations.
| New Reply |
| Thread Tools | |
Similar Threads for: Why does length contraction only occur parallel to the direction of motion?
| Thread | Forum | Replies | ||
| does length contraction occur in gravitational fields | Introductory Physics Homework | 1 | ||
| Why does length contraction happen only in the direction of motion? | Special & General Relativity | 5 | ||
| Length Contraction of the Universe Surpassing Length of Moving Object? | Special & General Relativity | 7 | ||
| Length contraction and the direction of motion | Special & General Relativity | 7 | ||
| In what direction does length contraction occur? | Special & General Relativity | 7 | ||
