New Reply
How do i build a electronic wire strippers?
Share Thread Thread Tools
Aug6-12, 05:12 PM   #18
i live in Mechanicsburg pa :)
Aug6-12, 05:45 PM   #19
Recognitions:
Gold Membership Gold Member
Quote by slee95 View Post
Oops. For some reason, your posts led me to think that you were in a different demographic.
Aug6-12, 07:00 PM   #20
demographic? whats that?
Aug7-12, 01:10 PM   #21
Recognitions:
Sorry; that just means a segment of society. When you mentioned finding things in the street, I thought that perhaps you were in an area with lax disposal protocols such as in parts of Asia.
Aug7-12, 05:32 PM   #22
Recognitions:
If you're pulling it through a die, why not just add a knife blade or two to slit the jacketing / insulation? If you wind the stripped wire to one spool, and the jacket / insulation to another, I'd think that'd result in separated wire with minimal mess (compared to sand-blasting or nitrogen freezing and shattering). Unfortunately, it'd probably only be worthwhile if you have long lengths of cable.
Aug8-12, 05:59 AM   #23
just recently i was given 3 spools of wire and it looks like two much for me to strip and one spool is tv wire and that's a pain to strip :(
Aug8-12, 09:32 AM   #24
Some coatings on wires might not be worth stripping (other than with a fire).
You might try a hot knife, http://www.amainhobbies.com/product_...FfADtgod9EUAlw
Pull the wire over a tight radius wheel, and have the hot knife cutting down to the copper. Use a revise tight radius wheel and a mechanical edge to remove the now split jacket.
A word of caution, DO NOT burn off any Teflon jackets, the fumes are toxic.
Aug8-12, 02:28 PM   #25
Recognitions:
Do you mean twin-lead or coax? The latter is probably worth a lot more intact.
Aug8-12, 02:48 PM   #26
The tv cable is the type that screws onto the back it has the single copper lead in the middle.
Aug8-12, 04:57 PM   #27
Recognitions:
That's coaxial. I don't know about in the US, but here it's quite expensive. You can probably sell it for more as it is than for the metal contained in it.
New Reply
Thread Tools
Similar Threads for: How do i build a electronic wire strippers?
Thread Forum Replies
a good place to learn and build electronic circuit? Electrical Engineering 9
What Types of Engineering to Build an Electronic Device? General Engineering 3
Total charge through point on wire due to changing current on other wire Advanced Physics Homework 1
0.5V across 1.5m tungsten wire w/cross-sect. area 0.6 mm^2 - Find wire current Introductory Physics Homework 3
If you had the chance to build anything, i would build a... General Discussion 14
