Why does Binomial dist. converge in distribution to Poisson dist. ?
The discussion revolves around the convergence of the Binomial distribution to the Poisson distribution in terms of distribution theory. Participants explore the implications of convergence in probability density functions (PDFs) and cumulative distribution functions (CDFs), questioning the conditions under which such convergence occurs.
  • One participant questions why convergence in the Binomial PDF indicates convergence in distribution to the Poisson distribution, noting the requirement for CDF convergence.
  • Another participant suggests that considering an infinite number of events in a non-overlapping interval is key to understanding the convergence.
  • Several participants discuss the relationship between convergence of PDFs and CDFs, with one asserting that the CDF is uniquely determined by the PDF.
  • There is mention of different types of convergence for sequences of functions and random variables, indicating that clarity on the type of convergence is necessary for the discussion.
  • A reference to Scheffe's Theorem is made, which is claimed to relate pointwise convergence of discrete PDFs to convergence in distribution of associated CDFs.
  • A participant expresses a misconception about the applicability of Scheffe's Theorem, indicating a need for clarification on its scope.
Participants express differing views on the implications of convergence in PDFs for CDFs, with no consensus reached on the sufficiency of the arguments presented. The discussion remains unresolved regarding the conditions under which convergence in distribution is established.
Participants highlight the need to specify the type of convergence being discussed, and there are references to mathematical theorems that require further proof, indicating limitations in the current understanding of the topic.
jojay99
Hey guys,
In class, I was shown that the Binomial prob density function converges to the Poisson prob density function. But why does this show that the Binomial distribution converges in distribution to the Poisson dist. ? Convergence in distribution requires that the cumulative density functions converges (not necessarily the prob density functions).
Is it because both are non negative and start at zero --> therefore convergence in prob. density functions implies converges in cumulative density functions?
Thank you.
Hey jojay99 and welcome to the forums.
For this example, you should let the number of events in an interval go to infinity but keep the independence property of the binomial that each event is independent and this translates into the property that they do not overlap.
So in the binomial we considered getting so many successes which can be thought of as the number of times an event happens within an interval. But each interval is completely disjoint from every other.
So we take a limit where we consider the distribution of an infinite number of events being possible in that particular interval. In the binomial we had n+1 possibilities ranging from 0 to n, but now we are letting that become infinitely many in one single non-overlapping interval.
The identity to get the exponential relates to the limit form of (1 + 1/n)^n.
I did a google search that does it much better than me, but hopefully the above gives you a non-mathematical explanation of what is going on.
http://www.the-idea-shop.com/article/216/deriving-the-poisson-distribution-from-the-binomial
So convergence in the probability density functions implies that the cdfs converges?
The CDF is uniquely determined by the PDF so there is a one to one correspondence with a PDF to the CDF. We also assume the PDF is a proper PDF satisfying the Kolmogorov Axioms.
There are several types of convergence defined for sequences of functions and there are several types of convergence defined for random variables. So you'd have to say what type of convergence you're talking about before I'd believe that implication.
I think this PDF deals with you question: http://www.google.com/url?sa=t&rct=...sg=AFQjCNGYITECDXIxnnXU7geHq5-VIJQQLw&cad=rja On page 2, it cites "Scheffe's Theorem" as proving that "pointwise" convergence of a sequence of discrete PDFs to a discrete PDF implies convergence "in distribution" of the associated CDFs.
You are correct that what was shown in your class was not a sufficient proof. And, of course, Scheffe's theorem itself requires a proof.
Thank you guys for your help.
Yeah, I was referring to point wise convergence of the pdfs.
I always thought that Scheffe's Theorem only applied to continuous random variables. I guess I'm wrong.
