| New Reply |
Pressure / temperature realtionship in polymers |
Share Thread |
| Aug21-12, 06:58 AM | #1 |
Hi, these is possibly a dumb question but...
I know that with regards to gases: (P1*V1)/T1 = (P2*V2)/T2 However does this still apply to polymers in liquid state? In an injection moulding machine if I increase the pressure will you get an increase in temperature if the volume of material is constant? Thanks. |
| Aug21-12, 07:13 AM | #2 |
No it's not a dumb question
No solid and semi solid materials do not obey the gas laws but yes they will increase in temperature if you pressurise them whilst at the same time confining them. The ultimate example of this is what happens to rocks at great depth (and pressure) in the earth. There is I'm sorry to tell you, no simple relationship between temperature and pressure for these materials. |
| Aug21-12, 08:06 AM | #3 |
Safety comment, Plastics need to be VERY dry when heated and used in compression
molding or extrusion. The water vapor does obey the gas law, and will at best create foamed plastics. |
| Aug21-12, 10:18 AM | #4 |
| New Reply |
Similar discussions for: Pressure / temperature realtionship in polymers
| Thread | Forum | Replies | ||
| Work While Temperature Change and Heat while pressure and/or temperature change | Classical Physics | 0 | ||
| High temperature polymers | Biology, Chemistry & Other Homework | 0 | ||
| Subset Realtionship | Calculus & Beyond Homework | 4 | ||
| High Temperature Polymers? | Materials & Chemical Engineering | 2 | ||
| Pressure And Temperature | Introductory Physics Homework | 8 | ||
