| New Reply |
Blackbody Heat Shields/Metal Sheets |
Share Thread | Thread Tools |
| Sep21-12, 03:28 AM | #1 |
A “blackbody heat shield” is used to reduce radiant heat loss in situations where standard low conductivity insulation (i.e. normal insulation) cannot be used. The shield is constructed using a set of parallel metal sheets, each with emissivity 1.0.
Explain how/why this “heat shield” works and determine how many sheets of metal are required to reduce the heat loss to less than 20% of the unshielded value. (Hint: think about the radiation absorbed by each sheet and how this energy will be re-radiated.) Diagram: ![]() I really need help with this xD I don't even know where to begin. |
| Sep21-12, 07:36 AM | #2 |
Mentor
Here are some ideas:
- assume that the whole problem is 1-dimensional - begin with 1 heat shield: Where does it receive/emit radiation? - assuming that the environment has a temperature of ~0, calculate the temperature of that heat shield in equilibrium |
| Sep21-12, 09:33 AM | #3 |
ummmm I still don't get it xD
do I use the equation: Q = mC deltaT? |
| Sep21-12, 09:46 AM | #4 |
Mentor
No, that looks like regular conduction.
##P_{emitted}=\sigma A T^4## (Stefan-Boltzmann) |
| New Reply |
| Tags |
| heat shield, radiant, thermal |
| Thread Tools | |
Similar Threads for: Blackbody Heat Shields/Metal Sheets
| Thread | Forum | Replies | ||
| Magnets sliding down metal sheets (slower then non metals) | Advanced Physics Homework | 2 | ||
| Heat Transfer, Blackbody Radiation | Introductory Physics Homework | 1 | ||
| Metal heat | General Physics | 10 | ||
| Heat shields? | Introductory Physics Homework | 2 | ||
| Ablative Heat Shields | Mechanical Engineering | 3 | ||
