| New Reply |
Current Transformers on each core of a 3 phase line |
Share Thread |
| Sep20-12, 03:25 PM | #18 |
J_B
The configuration is called "open delta"- and can be used to transform 3 phase from 2 transformers. Use Google Images to to see a number of examples. |
| Sep21-12, 01:33 AM | #19 |
NascentOxygen,
Now what? Now I will try to calculate what torque I can achieve from this secondary micromotor to see if I can do anything with it. Or what force I can generate from a linear actuator (lead screw torque calc) Windadct, Thanks for this - good info. J_B |
| Sep22-12, 05:26 PM | #20 |
"Something like this: http://schumo.ch/products_motors.htm" is for single phase actuators.
One current transformer on one line would kinda work. When the line current got above some value, the actuator would activate and when the line current got below some level the actuator would de-activate. Of course when the line current got too high, the actuator would burn up. What are you trying to do? |
| Sep23-12, 09:25 AM | #21 |
I'm trying to see if I can open and close a flow valve. Just need to work out how much force I can get out of an appropriate linear actuator run off 2 or 3 CT's.
| Sep23-12, 12:58 PM | #22 |
Operating on 1 current transformer will probably work as well as operating on 2 or 3 current transformers.
You should select a solenoid valve and then select or design the current transformer. Select solenoid valve based on required flow rate. Select valve with low power requirements. If you do a throrough Google search, there may be a valve that will do what is required without a current transformer. And again there may not be any such valve. Good Luck Carl |
| New Reply |
| Tags |
| 3-phase, induction, motor, transformer |
Similar discussions for: Current Transformers on each core of a 3 phase line
| Thread | Forum | Replies | ||
| Line current and phase current in a 3 phase 3 wire system. | Electrical Engineering | 1 | ||
| Line Current for 30kW 3 phase motor | Engineering, Comp Sci, & Technology Homework | 2 | ||
| How to make a three-phase transformer system using two single-phase transformers? | Electrical Engineering | 3 | ||
| 3-Phase Circuit - Line Current Calculation Question | Electrical Engineering | 1 | ||
| 3 Phase Machine Line Current problem | Engineering, Comp Sci, & Technology Homework | 2 | ||
