New Reply
How to go about solving this first-order nonlinear differential equation..?
Share Thread Thread Tools
Sep23-12, 02:22 PM   #1
I saw this post at stackexchange:
The fact that curve length is fixed amounts to a functional constraint. So we need to use both the Euler-Lagrange equation and Lagrange multipliers. The functional to minimise is [itex]\int^a_{-a}(2\pi y-\lambda)\sqrt{1+y'^2}dx[/itex], where λ is a Lagrange multiplier. For this functional, the first integral of the Euler-Lagrange equation gives a different ODE from what I got above, which has the solution [itex]y(x)=k(\cosh\frac{x}{k}-\cosh\frac{a}{k})[/itex] for some k depending on l, as required.
I ran across this post when trying to solve a homework problem. But I have no idea how he got that solution for that. When I use the Euler-Lagrange, I get this diff eq below.
Here is the simplest form I have managed to get it in:
[itex]\frac{\alpha}{2\pi}=\frac{\eta \quad \dot{\eta}^2}{\sqrt{1+\dot{\eta}^2}}-\sqrt{1+\dot{\eta}^2}[/itex]
Where [itex]\alpha[/itex] is a constant. For the simplification, [itex]\eta = (y-y_0)[/itex] & [itex]λ \equiv -2\pi y_0[/itex] is used from the quote above.
I don't know where to even begin to solve this. Any help would be good.
Thanks.
-edit
Some details that I thought I should add.
Since [itex]h=f+\lambda g≠h(x)[/itex], I used the special case of the E-L equation:
[itex]\dot{y}\frac{\partial h}{\partial \dot{y}}-h=const.[/itex]
But after the substituions to trim it up the special E-L turns into this:
[itex]\dot{\eta}\frac{\partial h}{\partial \dot{\eta}}-h=const.=\alpha[/itex]
Where [itex]h[/itex] now is: [itex]h=2\pi\eta\sqrt{1+\dot{\eta}^2}[/itex]
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Sep24-12, 07:33 AM   #2
Quote by Yondaime5685 View Post
That should be [tex]
\frac{\alpha}{2\pi}=\frac{\eta \dot{\eta}^2}{\sqrt{1+\dot{\eta}^2}}-\eta\sqrt{1+\dot{\eta}^2} = \eta [\frac{\quad \dot{\eta}^2}{\sqrt{1+\dot{\eta}^2}}-\sqrt{1+\dot{\eta}^2}]
[/tex]
Then you square the equation: [tex]
(\frac{\alpha}{2\pi})^2= \eta^2 [\frac{\quad \dot{\eta}^4}{1+\dot{\eta}^2} -2 \dot{\eta}^2 + 1 + \dot{\eta}^2] = \eta^2 [\frac{\quad \dot{\eta}^4}{1+\dot{\eta}^2} -\dot{\eta}^2 + 1]
\\ (\frac{\alpha}{2\pi})^2= \eta^2 \frac{\quad \dot{\eta}^4 -\dot{\eta}^2(1+\dot{\eta}^2) + (1+\dot{\eta}^2)} {1+\dot{\eta}^2}
= \eta^2 \frac{\quad \dot{\eta}^4 -\dot{\eta}^2 - \dot{\eta}^4 + 1+\dot{\eta}^2} {1+\dot{\eta}^2}
= \eta^2 \frac{1} {1+\dot{\eta}^2}[/tex]
I assume you can continue from here.
Sep24-12, 03:19 PM   #3
Thanks a lot! That made the problem a lot simpler.
I can't believe I didn't carry that [itex]\eta[/itex] over.
New Reply
Tags
calculus, revolution, sphere, surface, variations
Thread Tools
Similar Threads for: How to go about solving this first-order nonlinear differential equation..?
Thread Forum Replies
Nonlinear Differential Equation solving help please! Calculus & Beyond Homework 4
need help for solving a 2nd order nonlinear differential equation Differential Equations 8
1st order nonlinear differential equation Calculus & Beyond Homework 14
2nd order nonlinear differential equation Differential Equations 20
Solving a first-order nonlinear differential equation. Differential Equations 11
