How Do you Calculate how many x rays are coming off a fusion reaction?
The discussion centers on calculating the amount of x-ray radiation produced by nuclear fusion reactions, particularly in a hypothetical small-scale fusion reactor. Participants explore the factors influencing this calculation, including the amount of deuterium, voltage, and resistance in the system.
  • Exploratory, Technical explanation, Debate/contested
  • One participant suggests that the calculation of x-ray radiation from a fusion reaction depends on the amount of deuterium, voltage used, and resistance in the mesh through which electricity flows.
  • Another participant emphasizes the need for a specific setup to provide meaningful insights, indicating that without details, any response would be speculative.
  • A later reply reiterates the necessity of having a defined scenario, mentioning that theoretical calculations require knowledge of the fusion processes, material distribution, and heat dissipation.
  • One participant expresses uncertainty about what specific information is needed to calculate x-ray radiation, indicating a desire for clarity on the parameters involved.
  • Another participant warns against attempting to build a fusion reactor without understanding the associated risks and evaluation methods.
Participants generally agree that specific details about the fusion setup are crucial for any meaningful calculation, but there is no consensus on the exact parameters or models needed for the calculation.
The discussion highlights limitations related to vague descriptions of the fusion setup, which affects the ability to provide precise answers. There is also an acknowledgment of the risks involved in practical applications of fusion technology.
black phantom
Hello,
I'm trying to figure out how to calculate how much energy is being released in a nuclear fusion reaction from x rays. I think it will have to do with how much deuterium is in the vacuum chamber, how many volts I am using and the amount of resistance of the mesh the electricity is running through. I do not know though, can anyone help?
If you have a specific setup in mind, please tell us which. Otherwise it is pure guesswork.
And even then, I think you need some proper simulation.
Ok, sorry about being so vague, if i had a small scale fusion reactor in my garage, and I was using x amount of voltage, y amount of deuterium reacting, is there a way to calculate how much x ray radiation is being produced by the nuclear reaction?
Same as above.
I am sure it is possible to get a value, but without details it is impossible to say more.
Please do not try to build such a thing, if you have no idea how to evaluate and care about the risks.
Ok well right now this is all strictly theoretical, but then what exactly would i need to know to be able to calculate the amount of x ray radiation is coming off of a reaction?
You would need some model about your setup, about fusion processes, material distribution and heat dissipation. And if you stay so vague, the answers will stay vague as well.
  • · Replies 22 ·
17K
  • · Replies 19 ·
  • · Replies 16 ·
