| New Reply |
"cold shutdown" that doesn't require coolant circulation? |
Share Thread |
| Sep27-12, 10:08 PM | #1 |
I was wondering what is preventing a plant being built that can be truly shut down and not require coolant circulation.
Is it that efficiency would be reduced to unacceptable levels? |
| Sep28-12, 01:38 AM | #2 |
Recognitions:
You mean design a reactor so the fuel can be completely removed?
What makes you think this does not already happen? |
| Sep28-12, 05:27 AM | #3 |
Admin
It is the decay (or residual) heat that must be removed from the core. Normally there is a residual heat removal (RHR) system, which is tied into the primary system, but is only used after shutdown. There is also an emergency core cooling system (ECCS), which is also tied into the primary system, but only used if the primary cooling system fails. The RHR and ECCS are active systems in that they have valves and pumps, which usually require power. Some systems can be driven from steam, otherwise electrical motors are required. Modern plant design have far fewer valves, piping and pumps/motors, and usually some large volume of cooling water for passive cooling - which usually means gravity and natural convection. In general, natural convection uses much lower flow velocities, and hence lower heat transfer coefficient, than force convection. Lower heat transfer coefficient means higher temperatures. It is necessary to keep the fuel temperature sufficiently low to ensure that internal gas pressure in conjunction with cladding temperature and corrosion do not lead to failure. |
| Sep28-12, 06:10 AM | #4 |
"cold shutdown" that doesn't require coolant circulation?Nothing prevents IC designs with larger tanks and/or with more trains (Fukushima had 2). So yes, fully passive cooling is possible. As far as I understand, other units don't have IC for a quite appalling reason: for units with bigger design power, IC also needs to be bigger. Active systems can be made more compact. So IC was replaced by them. There goes "safety first" PR of nuclear industry... in practice, they did sacrifice safer systems for somewhat more compact active ones. |
| Sep28-12, 06:35 PM | #5 |
The AP1000 westinghouse design still requires circulation, but it uses natural forces, and can keep the reactor cooled for 72 hours with no human interaction or electrical power once the initiation signal fires off. Gen 4 designs are primarily passively cooled and require no active systems at all for extended periods of time (as low as a week or indefiniately)
Regarding nikkom's comment about the IC being removed, the IC is a great system in concept, but for the evolution of the BWR it was a bottleneck. The IC in BWR series plants only contains enough water for about 20-30 minutes per train (at 2 trains is about an hour at most). IC was replaced by RCIC. RCIC is a pump which is driven using steam from the reactor. It initially draws water from an outside tank and can function for up to 8 hours using external water before switching over to the suppression pool for cooling. It requires no AC power, only DC power to initiate and control. It can also be black started without DC power, but it requires manual control. RCIC has a much longer injection and cooling time than IC does. Additionally IC ONLY removes decay heat, it does not provide any injection. RCIC is capable of removing a fair amount of decay heat AND injecting. The RCIC system at Fukushima unit 2 ran for 70 hours. Unit 3 ran on RCIC for about 32 hours (not sure why it failed, probably loss of DC power coupled with no injection water to use and overheated suppression pool water flashing in the pump causing pump damage....but we wont know for a while. Without active cooling or an external water source, RCIC with no DC power will eventually overheat and fail, but it still lasts for drastically longer than the IC would have). If unit 1 had a RCIC system, the whole accident may have been less of an issue. The operators wouldnt have wasted so much time on trying to figure out if the IC was functioning or not and would have been able to prioritize real issues. They spent a disproportionate amount of time and resources trying to get the IC to work in unit 1. Personally I think IC plants should be shut down. RCIC all in all is the better system. IC requires an active feed pump to maintain it filled, while RCIC self powers and pumps using reactor steam. The plant I'm at was notorious for running for several days on RCIC after BOP scrams to maintain the reactor in hot standby and save a few hours off of their next restart. IC also contaminates the area outside the plant. It's low level, but the IC uses reactor grade water on the shell side, which contains small amounts of tritium and some other radioisotopes. Dresden plant in illinois (before security fences prevented this), they would have to decon the first 2 or 3 rows of cars outside the reactor building after running the IC. |
| Sep28-12, 08:03 PM | #6 |
| Sep28-12, 09:11 PM | #7 |
I just pulled the FSAR for a plant which contains an IC [Dresden http://pbadupws.nrc.gov/docs/ML0719/ML071910096.pdf Same model as unit 1. Go to section 5.4.6]. The IC is made up of 304 SS tubes, and contains enough water inventory for about 20 minutes prior to boil-off. The IC's accredited makeup source is the condensate storage tank (CST), via diesel driven transfer pumps. The condensate transfer pumps, fire protection system, and probably some other stuff, can be used to get water into the IC. The valves for the IC still require AC power for the MOV and control power to be actuated (so if they were potentially closed, like when the tsunami hit unit 1, it's useless). I'm not sure if they fail close on loss of power.
When you look at the water in the CST, there is more than enough for 8+ hours of IC for decay heat removal. But the shell of the heat exchanger only has 20 minutes of water. (If you want more evidence of this, go to the NRC teleconferences the day of Fukushima. They are available through the FOIA links. They state it in there, each IC has 20-30 minutes of water in it. I think its in the first of like the 7 teleconferences posted.) >Pump is an active system. It can break, it can't function if steam pressure is lost (say, a fissure in RPV's top). RCIC and IC are not ECCS systems, and are not required to function for a primary system line break. The RCIC pump is powered passively (decay steam) which gives it some inherent advantages to something which fails after 20 minutes. If you had a line break, HPCI(high pressure coolant injection)/HPCS(high pressure core spray) are accredited for high pressure injection. Assuming single failure of HPCI or HPCS, then on level 1 water level (low-low-low alarm water level), the ADS (automatic depressurization system) activates to blowdown the vessel and inject with all three LPCI (low pressure coolant injection) systems and the LPCS (low pressure corespray) system. Neither RCIC nor IC are accredited for loss of primary loop integrity accidents. >That's exactly why we want to see passive systems, which don't need DC to work. Additionally, RCIC's main limit is suppression pool temperature, as it uses that water to cool itself when it is in recirculation mode. During SBO, you lose RHR's ability to remove containment heat, and containment venting is the only heat removal you have to attempt to reduce suppression pool temperatures. >IC tank is at atmospheric pressure and can be refilled by a very ordinary equipment. A fire truck will do. Try using it to cool overheating suppression chamber. Good luck. IC doesn't inject water into the vessel or containment. It also does not cool containment. RCIC tank is at atmospheric pressure and can be refilled just as easily. Additionally RCIC injects, removes decay heat, and can help manage suppression pool and containment temperature/pressure (adding colder water into the vessel from the outside rather than recirculating suppression pool water). >And if operators would have even minimal training for SBO, and in particular, how to activate the IC during SBO, the disaster may be averted altogether. One of the identified issues (as can be seen in INPO IER 11-05 August 2012 addendum found here: http://www.nei.org/resourcesandstats...-power-station), is that Japan deviated from many decisions and lessons learned the US had after Three Mile Island. One of those lessons learned was that operators should train in a simulator that matches the plant they are working in. At Fukushima, operators trained in the Unit 2-4 simulator, as they did not have a unit 1 simulator, and as a result never had "hands on" experience with the IC. That lack of knowledge combined with no AC/DC instrument power or control power made figuring out if unit 1 had cooling near impossible. If unit 1 had a RCIC system, this wouldn't have been an issue, as RCIC does not need to be cycled to prevent violation of reactor vessel cooldown rate technical specifications like the IC does, and would have remained in service as it did in unit 2 and 3 when the tsunami hit. >WHAT??? Why a clear water can't be used in IC? Editing this section: Clean water or reactor grade condensate can be used for the IC. Clean water is much more expensive to make, and may not have been the preferred source 20+ years ago (which is where the stories I know of regarding contamination come from). Condensate contains low level contamination. The IC system does have radiation monitors which will isolate the atmospheric vents at high radiation levels, but this is intended to protect against a leak path from damaged fuel, out through a damaged heat exchanger tube, to the atmosphere. I do not believe there is filtering on the atmospheric vents. Personally I think the IC is a big danger. It requires active diesel pumps for more than 20 minutes, and you still need control power to line it up. It can't inject (so you are still reliant on HPCI if you are in hot-standby and need to inject), and it cools the vessel down faster than the 100 degree F per hour limit on BWR reactor vessels and requires operators to cycle it constantly. With RCIC, it will auto stop and start between reactor water level 8 (high high alarm) and level 2 (low low alarm) [respectively]. It has a flow controller and can be dialed to inject to match decay heat directly to prevent excessive cooldown, while injecting. It can inject outside water. It functions with no AC, and its pump does not require an active energy source (as decay heat is the energy source). Maybe I'm slightly biased, but I restate my point, at Fukushima, unit 1 was a huge concern, and it had no RCIC, while units 2 and 3 lasted 70 and 36 hours respectively. Side note: Great discussion/comments. |
| Sep29-12, 02:57 AM | #8 |
As nikkkom said, IC capacity of the order of 8 hours has been built e.g. at Fukushima Dai-ichi unit 1, as well as several other plants of the same generation. 20 minutes is obviously too short, but it doesn't mean the IC wouldn't - if designed properly wrt. capacity and valve fail safe modes - be a great device for passive shutdown cooling.
| Sep29-12, 08:24 AM | #9 |
I'm not sure if I understand, but again, the IC does not have 8 hours of capacity built in, it has 20 minutes, and requires active systems to function for longer than that. The IC as it exists in BWR/2 and /3 plants is pretty awful as it is limited capacity and requires active pumping systems, where RCIC can run for DAYS. Now in comparison, the IC as designed in the ESBWR, and the PXS heat exchanger in the AP1000 (basically an IC), are excellent, but that requires a full plant/containment design to support it. The IC as exists in older BWRs is a vulnerability in my professional opinion, and I thats what we saw at Fukushima. |
| Sep29-12, 09:29 AM | #10 |
But that's not what happened. In Fukushima after SBO, operators failed to keep valves from RPV to IC open and thus IC couldn't do its job. |
| Sep29-12, 10:17 AM | #11 |
| Sep29-12, 10:18 AM | #12 |
If the valves were lined up correctly and the diesel driven pumps were functioning and the makeup tank was still intact then yes, it would have helped a LOT at Fukushima. They still would have been limited to 8 hours, but that would have let them prioritize getting DC power and instrumentation restored. |
| Sep29-12, 10:39 AM | #13 |
Just posting another follow up, I likely made an error. While Dresden is nearly identical in design to Fukushima Daiichi, Dresden operates 2 reactors at over 800 MWe (over 2400 MWth), while Fukushima Daiichi unit 1 is a single unit which operates around 460 MWe (just over 1380 MWth most likely).
This difference in thermal output also directly correlates to a difference in decay heat, and would explain why Dresden only accredits their IC for 20 minutes while Fukushima Daiichi news posts claim up to 6 hours on shell side water inventory. My opinion is still the same regarding RCIC vs. IC, but I apologize if I made this confusing. |
| Sep29-12, 11:45 AM | #14 |
Admin
IIRC, Dresden and Quad Cities are the largest of the BWR/3 class with 724 assemblies in the core. The units have been uprated.
Dresden and Quad Cities Uprates - http://pbadupws.nrc.gov/docs/ML0100/ML010080047.pdf The proposed changes will allow the DNPS and QCNPS units to operate at an uprated power level of 2957 megawatts thermal (MWt). This represents an increase of approximately 17 percent rated core thermal power over the current 100 percent power level of 2527 MWt for DNPS and an increase of approximately 17.8 percent rated core thermal power over the current 100 percent power level of 2511 MWt for QCNPS. FK1-1 is a small core like Garona with 400 assemblies. Units 2, 3 and 4 were moderate-size cores of 548 assemblies. The IC, RCIC and ECCS are sized according to the core. Some systems can be challenged, i.e., are less effective, for larger cores. |
| Sep29-12, 06:09 PM | #15 |
As far as I understand both systems, RCIC is fully integrated into the PCV, therefore any pipe leak anywhere in the piping would vent coolant into the primary containment, but not into the environment. Contrary to that, the IC-piping naturally has to be at least partially outside the primary containment - since the coolant pool is there as well. Therefore in a reactor with an operating Isolation Condenser, there's a direct and unfiltered connection between the RPV and the environment, with the primary containment vessel being circumvented. If the IC piping outside the PCV would be damaged, the fuel would be directly connected to the atmosphere. And that's the reason why it had been constructed fail-safe. You absolutely don't want a backdoor in your containment you may not be able to close in case of accidents. Therefore make sure that it's closed on default. To go back to Fukushima: I'm not so sure anymore if constructing it fail-safe had been the wrong decision. Let's say it had been constructed fail-operational. Then Unit 1 would have survived for 8 hours with adequate cooling, after that the reactor would've boiled dry anyway, high pressure steam would have ruptured the IC-pipes outside the reactor and fission products released from the failing fuel rods would've found their way directly into the atmosphere. |
| Sep29-12, 06:19 PM | #16 |
The IC is not a direct unfiltered path, as the heat exchanger tubes are the RCS boundary in this case. The IC does have rad monitors which will isolate the IC should high radiation levels which could indicate an unfiltered release are detected, but that shouldn't be happening as the heat exchanger tubes shouldnt have leakage. The isolation system valves fail closed to ensure that if the IC would become part of the RCS, that there would not be a release path. Also the IC pipes should not rupture. They are ASME code, so they should be tested to withstand 3 times reactor pressure. Additionally, the safety relief valves prevent the RCS from exceeding 1300 PSI, so the IC would never have to deal w/pressures that high (in fact, the IC, even if it was open at unit 1, would never have had pressures above 1200 due to SRV lifts) |
| Sep29-12, 06:35 PM | #17 |
http://www.physicsforums.com/showpos...ostcount=12998 |
| New Reply |
Similar discussions for: "cold shutdown" that doesn't require coolant circulation?
| Thread | Forum | Replies | ||
| Meaning of "circulation" | General Math | 2 | ||
| General consensus on Cold Fusion better known as "Low Energy Nuclear Reactions" LENR? | High Energy, Nuclear, Particle Physics | 20 | ||
| "Spontaneous" reactions require activation energy? | Chemistry | 8 | ||
| Does quantum mechanical definition of momentum require "movement"? | Quantum Physics | 21 | ||
| Help me design my "carputer" to work in the cold (advice on building a heater) | Computing & Technology | 10 | ||
