| New Reply |
How capacitor blocks dc current? |
Share Thread | Thread Tools |
| Nov1-12, 11:51 PM | #69 |
SunnyboyNY,
Ratch |
| Nov2-12, 05:29 AM | #70 |
Umm. I'm not sure what current flowing "physically" means. Let's ignore the electrons bit because that just clouds the issue. A current flows in one end and out of the other end of a resistor or a capacitor. Kirchoff's laws work perfectly well in most circuits. How are the two cases different? Is it really worth labouring the point that 'charging a capacitor' is not the same thing as 'charging' a comb by rubbing it? Capacitors and batteries are what we discuss in circuit theory - not isolated / insulated objects.
I think we agree that 'yer actual DC' does not exist, because that would involve infinite time for it to be established. So, if DC is a pragmatic term for 'constant value for long enough', then the reactance (let's just call it Impedance, in fact) to DC is just as meaningful as at any frequency of AC. At our newly defined version of DC frequency (<0.0001Hz, say), the impedance is (to all intents and purposes) infinite. But I still don't see why you guys don't want to use Maths (or at least refer to it) to describe what goes on. The exponential charge / discharge of a CR network describes exactly what goes on and that can be re-stated in terms of frequencies and Impedance. The results of experiment agree so well with that simple theory and it isn't difficult to approach the 'ideal case' in practice. That's why we can design filters and other circuits to work in such a predictable way. Discussing "what's really happening" is not really getting one any closer to an understanding unless you really want to get into QM and how materials behave. |
| Nov2-12, 10:18 AM | #71 |
sophiecentaur,
Ratch |
| Nov2-12, 11:03 AM | #72 |
| Nov2-12, 12:55 PM | #73 |
sophiecentaur,
Ratch |
| Nov2-12, 01:34 PM | #74 |
Is there a "right angles' (I think you actually mean 90 degree phase, in this context) in the time domain? In fact, of course, the term Orthogonal has many other connotations than just "at right angles". I guess this flurry of attempted pedantry is due to a perceived slight concerning "current flow". In fact, if you read back, you'll see that I was picking up on someone else's post and not yours so you can calm down. |
| Nov2-12, 02:06 PM | #75 |
sophiecentaur,
Ratch |
| Nov2-12, 05:42 PM | #76 |
| Nov2-12, 07:00 PM | #77 |
sophiecentaur,
Ratch |
| Nov3-12, 06:02 AM | #78 |
The term "storage element" is a bit too non-specific, to my mind. After all, you can make a simple chemical battery with virtually no reactive impedance (certainly no inherent reactance). Why not just use the term 'Reactive'?
And, incidentally (I expected you to pick me up on this one so I looked in wiki and other places, to make sure I got it right) X stands for reactance and is measured in Ohms. Impedance is a complex quantity and is R+jX. So the reactance of a Capacitor is -1/ωC, with no j. I was correct to quote a reactance of -753Ω. If it were not this way, we would write Z = R + X Pedantry can turn round and bite you. I suggested that you may have a problem with zeros because, on two occasions, you have treated a zero value (Reactance or Frequency) as somehow different from finite values. |
| Nov3-12, 10:23 AM | #79 |
sophiecentaur,
Ratch http://www.st-andrews.ac.uk/~www_pa/...lex/react.html |
| Nov3-12, 10:33 AM | #80 |
A battery could be simply modeled as a huge capacitor such that the associated eigenvalue would be so small that all other pertinent transients would be long finished before the battery energy changes ever-so-slightly. Since poles in typical RLC circuits are rather fast, we could reduce the order of the system by modeling a battery by a constant voltage source. |
| Nov3-12, 10:56 AM | #81 |
SunnyBoyNY,
Ratch |
| Nov3-12, 11:17 AM | #82 |
The approximation of a battery as a large capacitor would be valid for analysis where the run time is much shorter than the resonant frequency of the battery model and the smallest galvanically connected inductance coil in the circuit. How else would you model a charge-dependent voltage source? Say ones wants to model a battery powering a dc/dc converter that has an LC output filter and a resistive load. The battery voltage (=capacitor voltage with an initial condition) will drop over time because there is no other initial energy in the system. The converter will go through a number of cycles that will not be affected by the additional capacitive element at all. |
| Nov3-12, 11:32 AM | #83 |
SunnyboyNY,
For the reasons I gave before, a battery is not a universal linear substitute for a capacitor. Ratch |
| Nov3-12, 11:54 AM | #84 |
Anyway, is this much ado about nothing? |
| Nov3-12, 12:08 PM | #85 |
It's not just wiki. It is everywhere. X stands for reactance. The Impedance of a reactance X is jX. Check it out. I agree in principle but I don't think that there is much of a problem in the 'limits' in these cases, though. |
| New Reply |
| Thread Tools | |
Similar Threads for: How capacitor blocks dc current?
| Thread | Forum | Replies | ||
| Calculating Current With Capacitor | Engineering, Comp Sci, & Technology Homework | 3 | ||
| Capacitor (Instantaneous current) | Introductory Physics Homework | 9 | ||
| current through capacitor | Introductory Physics Homework | 7 | ||
| current through capacitor | Engineering, Comp Sci, & Technology Homework | 7 | ||
| how does current flow through a capacitor? | Introductory Physics Homework | 4 | ||
