New Reply
Radial pulsation of stars problem
Share Thread Thread Tools
Nov2-12, 12:12 AM   #1
I am trying to do the problems in this set:
http://farside.ph.utexas.edu/teachin...es/node13.html
They seem quite hard, but I think I've managed to get to #4.
The statement of the problem is at Problem 4 in the above link.
My attempted solution is the following:
The gravitational field at a point inside the sphere can be calculated using Gauss' law for gravitation, so that 4πr2g = -4∏G ∫rdV (V is a sphere of radius r)
= -4∏GMr3-α/R3-α. (M and R have the meanings given in the problem statement, and the integral is done in spherical coordinates).
so g = -GM/R3-α*r1-α, and its potential is GM/(2-α)*r2-α/R3-α since its negative gradient gives g.
By integrating the potential with respect to the density in the whole sphere, where density is proportional to r, I get that U, the potential energy of the system, is :
4∏/(2-α) * GM/(5-2α) * R2-α and its moment of inertia around the origin is 4∏R5-α/(5-α) so that U = 1/(2-α) * (5-α)/(5-2α) * GM/R3 and plugging this in the Virial equation, and recognizing the second order linear differential equation, we find that the angular frequency should be
(2/(2-α) * (5 - α)/(5 - 2α) * GM/R3 )1/2.
This has an additional factor of 2/(2-α) which is not in the problem statement, so I wonder whether I made a mistake or something is wrong.
Thank you for your help
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Nov2-12, 02:52 PM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Quote by Boorglar View Post
By integrating the potential with respect to the density in the whole sphere, ...
The potential that you want to integrate with the density is the potential at the surface of a sphere of the material of radius r (with the material between r and R removed). Thus, V(r) = -Gm(r)/r where m(r) is the total mass contained within the sphere of radius r.
This is not the same as the anti-derivative of the acceleration g(r) at location r within a sphere of radius R.
It's as though you're building up the sphere layer by layer. When you bring in the next layer of mass, dm, from infinity and place it on the sphere of radius r, the work requred is dm*V(r) where
V(r) = -Gm(r)/r.
Nov2-12, 05:01 PM   #3
Yes, this makes sense, and I think the answer works that way. Thank you!
But then why isn't the acceleration vector the negative gradient of the potential? I thought this was one of the definitions of a potential... I'll have to think more about it.
EDIT:
since U will be negative and the equation is I'' = -2U + c, doesn't this mean that it will grow exponentially?
U = -(positive constant)I so I'' = 2(positive constant) I + c which is unbounded??
I also realize I made a few typos in the original post. But it's the question of U being negative that bothers me
Nov3-12, 11:30 AM   #4
Recognitions:
In finding the total U by building the sphere layer by layer, you only need the expression for V at the surface of the sphere as its radius grows. If [itex]\bar{r}[/itex] is the current radius during the build up, then V at the surface is ## -Gm(\bar{r})/\bar{r}##. For a point outside the sphere at radius ##r>\bar{r}##, the potential would be ##V(r) = -Gm(\bar{r})/r##. The negative gradient of this function would be the acceleration for points outside the sphere.
I don't think that U = -(positive constant)I. Let ##r_{i\:o}## be the equilibrium position of the ##i^{th}## particle during the pulsation. For small radial oscillations in which the amplitude is proportional to the distance from the center of the star, you can write [itex]r_{i}(t)= r_{i\:o} + r_{i\:o} \epsilon \: cos(\omega\:t)[/itex] where ##\epsilon << 1## and ##\epsilon## is the same for all particles. You can then write I and U as functions of time to first order in ##\epsilon##. See if that helps.
Nov4-12, 01:51 PM   #5
ri(t)=rio+rioϵcos(ωt) where ϵ<<1 and ϵ is the same for all particles.
But how do you know that?
Here's my reasoning:
The moment of inertia around the origin that I found is
[tex] I = \int\int\int_{V} r^{2} d\rho = 2\pi\int_{-\frac{\pi}{2}}^{\frac{\pi}{2}}\int_{0}^{R}r^{2}r^{-\alpha}r^{2}\cos{\theta} dr d\theta = \frac{4\pi}{5-\alpha}R^{5-\alpha} [/tex]
To calculate the potential energy, first find the mass inside a sphere of radius R:
[tex] m(R) = \int\int\int_{V} r^{-\alpha} dV = 2\pi\int_{-\frac{\pi}{2}}^{\frac{\pi}{2}}\int_{0}^{R}r^{-\alpha}r^{2}\cos{\theta} dr d\theta = \frac{4\pi}{3-\alpha}R^{3-\alpha} [/tex]
then [tex] U = -\int_{0}^{R}\frac{G(\frac{4\pi}{3-\alpha}r^{3-\alpha})(4\pi r^{2}r^{-\alpha})dr}{r} = -\frac{16}{3-\alpha}\pi^{2}G\frac{R^{5-2\alpha}}{5-2\alpha}[/tex] (the potential is -Gm(r)/r where m(r) is the mass inside the sphere of radius r, and the mass of the next layer is 4∏r2*ρdr = 4∏r2*rdr.)
so [tex] \frac{U}{I} = -\frac{4\pi}{3-\alpha}R^{3-\alpha}*\frac{5-\alpha}{5-2\alpha}\frac{G}{R^{3}} = -\frac{5-\alpha}{5-2\alpha} \frac{GM}{R^{3}}[/tex]
Due to the fact that the oscillations have small amplitudes compared to the (very large for a star) equilibrium radius, R doesn't vary much and can be approximated by it. So U is -(positive constant)*I.
Nov4-12, 01:58 PM   #6
Although I must have made a mistake somewhere since a factor of 1/2 is missing to cancel with the 2 in the Virial equation...
As an additional clarification, when I say that m(r) = -4/(3-a)R^(3-a) (which seems to be a volume) it is understood that there is a unit of density attached to the constants (so that units work out) but it will cancel in the division of U with I anyways.
Nov4-12, 02:45 PM   #7
Recognitions:
The equation [itex]r_{i}(t)= r_{i\:o} + r_{i\:o} \epsilon \: cos(\omega\:t)[/itex] is the way I think you would mathematically express “small amplitude radial pulsations of the star (in which the radial displacement is directly proportional to the radial distance from the center)”.
During the pulsations, ##U## and ##I## will be time dependent. It’s true that for the instants of time where the pulsation is passing through the equilibrium position you would have [itex]r_{i}(t)= r_{i\:o}[/itex] and ##U_o = -KI_o## where ##K## is the positive constant that you derived. But for arbitrary times during the pulsations, it will not be true that ##U(t) = -KI(t)##.
However, using the expression [itex]r_{i}(t)= r_{i\:o} + r_{i\:o} \epsilon \: cos(\omega\:t)[/itex] I think you can show that to first order in ##\epsilon##, the "distortions" from equilibrium of ##U## and ##I## satisfy ##U(t) – U_o = +\frac{K}{2}(I-I_o)##.
Nov4-12, 03:35 PM   #8
I must admit I didn't quite understand what they meant by that phrase... I couldn't see the relevance to the question. But I'll try what you suggested.
Just to make sure: will it be true that U(t)=−K(t)I(t), where K now varies due to the R3(t) which is the time-varying radius of the star? I think that in the derivation I didn't assume it was at equilibrium.
EDIT:
Ok, here's what I get with r(t) = R(1+εcos(ωt)).
I(t) is proportional to R5-α and U(t) is proportional to R5-2α.
So I(t) = I0(1+εcos(ωt))5-α ≈ I0[1+(5-α)εcos(ωt)].
and U(t) = U0(1+εcos(ωt))5-2α ≈ U0[1+(5-2α)εcos(ωt)].
Plugging into the differential equation:
I"(t) = -ω2I0(5-α)εcos(ωt) = -2U0(5-2α)εcos(ωt) - 2U0 + C
[2U0(5-2α)-ω2I0(5-α)]εcos(ωt) = C - 2U0.
in order for the LHS to be constant, the coefficient before cos must be 0 (and even then the RHS might not be 0). Moreover, solving for ω gives a different answer.
Nov4-12, 04:26 PM   #9
Recognitions:
Not only will R vary, but the mass density function will also change. Otherwise the total mass of the star would change.
Of course, you could always define a time varying K(t) such that U(t) =-K(t)I(t) by letting K(t) = -U(t)/I(t) (I know that's not what you meant.)
Nov4-12, 05:21 PM   #10
I just edited my previous post.
I didn't think of that! But then in what way is the density changing? It should be something like ρ(t) = k(t)*r since the problem says the density is proportional to r. So [itex] k(t) = (\frac{R}{r(t)})^{3-\alpha} [/itex] and [itex] U(t) = -(\frac{R}{r(t)})^{3-\alpha}K(t) I(t) [/itex] where K(t) is the "time varying constant" .
Wow this problem really got me stumped. And I don't see how this will lead me anywhere, since we still get I" = -2U + C and U being -(positive, time varying coefficient)*I so the system is still unbounded
Nov4-12, 05:49 PM   #11
You must be a genius if you can make sense of this, because seriously this problem confuses me the more I think about it.
Nov4-12, 06:30 PM   #12
Recognitions:
OK, I think you were right about how ##K(t)## would vary with time: ##K(t) = [(5-\alpha)/(5-2\alpha)]*GM/R(t)^3##.
I was thinking at first that maybe the pulsations would alter the mass density in such a way that ##\alpha## would also change. But you can show that if the density varies with ##r## as ##\rho(r) = \rho_o r^{-\alpha}## when there is no pulsation, then with the pulsations the density will vary with ##r## and ##t## as ##\rho(r,t) = \rho_o(t) r^{-\alpha}## where now ##\rho_o## varies with time but the exponent of ##r## is still the same. At any given time the ratio of ##U(t)## to ##I(t)## will not depend on ##\rho_o(t)##, it will only depend on the total mass ##M##, the total radius ##R(t)##,and ##\alpha##. So, the only time dependence of [itex]K(t)[/itex] will be due to the change in radius, as you were saying. Good.
So, back to the issue of deriving the expression for the frequency of pulsation. Were you able to express ##U(t)## and ##I(t)## in terms of ##\epsilon\: cos(\omega t)##, where [itex]r_i(t) = r_{i o} + r_{i o} \epsilon \: cos(\omega t) = (1+\epsilon\: cos(\omega t))r_{i o}[/itex]? Once you have that, it should be fairly easy to get the frequency.
Nov4-12, 07:16 PM   #13
Yes, I edited one of my previous posts:
EDIT:
Also, I think that the correction factor k(t) won't cancel since U is proportional to the square of density, while I is proportional to the 1st power only.
Nov4-12, 08:03 PM   #14
Recognitions:
The easiest way to see how I(t) and U(t) vary with time is to go back to the basic expressions ##I(t) = \sum m_i \: r_i(t)^2## and ##U(t) = \sum_{ij} G \: m_i \: m_j/|r_i(t)-r_j(t)|## and use the fact that each ##r_i(t) = r_{io}(1+ \epsilon \: cos(\omega t))##.
[ Hey, I just made my 1000 post! But, man, you've really made me sweat for it! Actually, I'm enjoying this problem ]
Nov4-12, 09:58 PM   #15
Recognitions:
The reason that this is not giving the right answer is that it leaves out the time dependence of the density function.
##I(t)## is proportional to ##\rho_o(t)R(t)^{5-\alpha}## where ##\rho_o(t)## is the time dependent factor in ##\rho = \rho_0(t)r^{-\alpha}##.
You can eliminate the ##\rho_o(t)## factor in ##I(t)## using the the expression ##M = \frac{4\pi}{3-\alpha}\rho_0(t)R^{3-\alpha}(t)## to solve for ##\rho_o(t)## in terms of the constant mass ##M## and ##R(t)## and substitute into the expression for ##I(t)##. Similar remarks for ##U(t)##.
But you can avoid all of this by going back to the basic expressions for ##I(t)## and ##U(t)## in terms of summations over the particles.
Nov5-12, 06:53 PM   #16
When you speak of summation, you mean the integral over a volume?
[tex] I(t) = \int\int\int_{V(t)} r^{2}\rho(r,t)dV [/tex]
and [tex] U(t) = \int\int\int_{V(t)} -\frac{Gm(r,t)}{r}\rho(r,t) dV [/tex]
where V(t) is the time varying sphere of radius R(1+εcos(ωt)) and m(r,t) is the mass of a sphere of radius r at time t?
Nov5-12, 07:08 PM   #17
Recognitions:
See what happens if you go back to ##I(t) = \sum m_i \: r_i(t)^2## and ##U(t) = \sum_{ij} G \: m_i \: m_j/|r_i(t)-r_j(t)|## and use the fact that each ##r_i(t) = r_{io}(1+ \epsilon \: cos(\omega t))##.
You should be able to express ##I(t)## in a simple way in terms of ##I_o## and ## \epsilon \: cos(\omega t)## and likewise for ##U(t)##. Then you can sub these into I'' = -2U +C.
New Reply
Thread Tools
Similar Threads for: Radial pulsation of stars problem
Thread Forum Replies
Physics problem: Radial acceleration, forces, and work & energy problem Introductory Physics Homework 13
Show that the radial component of the wave function satisfies the radial equation Advanced Physics Homework 2
Pulsation in Liquid Bubble Classical Physics 0
Mass of stars companion from radial velocity Introductory Physics Homework 9
Pulsation damping in a heat engine Mechanical Engineering 0
