New Reply
allowable load in short compression member
Share Thread Thread Tools
Nov7-12, 10:40 PM   #1
My apologies, I don't own a scanner or else I would show the 200 variations of formulas I've played around (my work) with all day to get these answers.
Question is this;
A short compression member is fabricated from 2 steel pipes. the pipe on the top has a cross sectional area of 3.17 in sq and is 4" long. The pipe on the bottom has a cross sectional area of 5.53 in sq and is 6" long.
Each pipe has a downward force at the centre-top of each pipe.
The allowable compressive stress in the steel is 21.6 ksi.
a) What is the allowable load in the bottom pipe if the load in the top pipe is 22 kips?
b) What is the allowable load in the top pipe if the load in the bottom pipe is 40 kips?
the answer for a) is 97.4 kips and b) is 68.5 kips.
I've tried most stress formulas but there must be something I am missing. If you're able to show guidance, I'd appreciate the help. Thanx
-M
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> NASA: Austin, calling Austin. 3-D pizzas to go
>> Research suggests modular design competence can benefit new product development
>> Army ground combat systems adopts tool for choosing future warfighting vehicles
Nov8-12, 12:11 AM   #2
Recognitions:
Homework Helper Homework Help
Draw a free body diagram of your problem and add the given forces. (Hint: with such short pieces of pipe, buckling instability can be ignored.) Use the allowable stress to determine the unknown load.
Nov8-12, 08:34 AM   #3
for b, I get 21600 x 317 = 68.5 which is good
for a, I get 21600 x 5.53 = 119.4 which is no good
Nov8-12, 08:47 AM   #4
Recognitions:
Did you draw the FBD? Notice, the pipes with the unknown loads are in different locations for a) and b).
New Reply
Thread Tools
Similar Threads for: allowable load in short compression member
Thread Forum Replies
[FEM-problem] Defining max. allowable load Engineering, Comp Sci, & Technology Homework 0
Statics Allowable load problem. Engineering, Comp Sci, & Technology Homework 1
Finding the allowable uniform load Engineering, Comp Sci, & Technology Homework 6
find allowable axial compressive load Engineering, Comp Sci, & Technology Homework 4
Determine the maximum allowable weight of a load supported by chains. Engineering, Comp Sci, & Technology Homework 1
