Register to reply
Complex number
by Outrageous
Tags: complex, number
Share this thread:
Outrageous
#1
Nov7-12, 08:33 PM
P: 375
Find (2+6i)^(1/3). Then we need to let z=a+bi, then z^3....... Then we will get a=? And b=?
Why we can do z=a+bi assumption? Any prove show what we assume is correct and how do we know the answer come out is correct?
Phys.Org News Partner Mathematics news on Phys.org
Math journal puts Rauzy fractcal image on the cover
Heat distributions help researchers to understand curved space
Professor quantifies how 'one thing leads to another'
Outrageous
#3
Nov8-12, 01:04 AM
P: 375
Sorry, can you tell what is the subtopic of my question in the reference given. Thanks
HallsofIvy
#4
Nov8-12, 07:02 AM
Math
Emeritus
Sci Advisor
Thanks
PF Gold
P: 39,682
Complex number
Quote Quote by Outrageous View Post
I'm not sure what you mean by "z= a+ bi assumption". Typically that is NOT an "assumption", it is one way of defining complex numbers.
A more formal definition, from which you can then derive "z= a+ bi" is this:
The complex numbers is the set of all pairs of real numbers, (a, b), with addition defined by (a, b)+ (c, d)= (a+ c, b+ d), and with multipication defined by (a, b)(c, d)= (ac- bd, bc+ ad). One can then show that the usual "properties" of arithmetic (commutativity, associativity, etc.) hold. One can also show that the subset of all pairs in which the second member is 0 is "isomophic" to (identical to) the set of real numbers: (a, 0)+ (b, 0)= (a+ b, 0+ 0)= (a+ b, 0) and (a, 0)(b, 0)= (ab- 0(0), a(0)+ 0(b))= (ab, 0). We can "identify" complex numbers of the form (a, 0) with the real number, a.
One can also show that [itex](0, 1)^2= -1[/itex]: (0, 1)(0, 1)= (0(0)- 1(1), 0(1)+1(0))= (-1, 0) which, as above, we identify with the real number -1. We define "i= (0, 1)" so that [itex]i^2= -1[/itex]. And, then, we can write (a, b)= (a, 0)+ (0, b)= (a, 0)+ (b, 0)(0, 1)= a+ bi.
Outrageous
#5
Nov15-12, 08:29 PM
P: 375
Quote Quote by HallsofIvy View Post
Thank you.
Can I say all the number actually is the combination of real and imaginary number.
As you say" We can "identify" complex numbers of the form (a, 0) with the real number, a"
HallsofIvy
#6
Nov16-12, 07:48 AM
Math
Emeritus
Sci Advisor
Thanks
PF Gold
P: 39,682
Yes, that is write. By any definition of "complex" number, we can write any complex number in the form z= a+ bi for some real numbers "a" and "b". That form is also "unique" that is, if z= a[sub]1[sub]+ b1i and the same z= a2+ b2i, we must have a1= a2 and b1= b2.
Now, in this problem, attempting to find (2+ 6i)1/3, they are suggesting that you write the answer as "a+ bi", find (a+ bi)3 and set the "real" and "imaginary" parts equal. For example, (a+ bi)2= (a+ bi)(a+ bi)= a2+ 2abi+ b2i2= (a2- b2+ 3abi. If we wanted to find (1+ i)1/2, we could now set s2- b2= 1 and ab= 1, giving two equations to solve for a and b.
Outrageous
#7
Nov16-12, 08:17 AM
P: 375
Thanks a lot
Register to reply
Related Discussions
Taking a number to a complex number power General Math 3
Complex number Precalculus Mathematics Homework 4
About complex number Precalculus Mathematics Homework 2
Complex number Precalculus Mathematics Homework 14
Complex number General Math 8
