What is phase velocity?
by mycotheology
Tags: phase, velocity
mycotheology
mycotheology is offline
#1
Nov20-12, 04:58 PM
P: 90
According to the wiki page, this diagram:
shows the phase velocity and group velocity moving in opposite directions. I think I understand what group velocity is, its the velocity of the overall wavepacket, in the diagram I can see a Gaussian wavepacket moving to the right so I'm guessing thats the group velocity. I can't see the phase velocity. I don't know what I'm looking for because I don't really know what phase means. I understand the concept of constructive and destructive interference and how 2 waves can be in or out of phase but I don't understand what phase means with respect to an individual wave. Does the word phase mean where the waveform is on the y axis, at a particular point on the x axis? Thats the idea I have of phase and with that in mind, I can't understand how phase can have a velocity.
Phys.Org News Partner Physics news on Phys.org
Physicists design quantum switches which can be activated by single photons
'Dressed' laser aimed at clouds may be key to inducing rain, lightning
Higher-order nonlinear optical processes observed using the SACLA X-ray free-electron laser
jtbell
jtbell is offline
#2
Nov20-12, 05:19 PM
Mentor
jtbell's Avatar
P: 11,231
Quote Quote by mycotheology View Post
Correct!
The phase velocity refers to the individual waves "inside" the wave packet, which are moving to the left in your example. Actually, what you're seeing is the average phase velocity of the individual waves that combine to produce the wave packet.
Simon Bridge
Simon Bridge is online now
#3
Nov20-12, 05:26 PM
Homework
Sci Advisor
HW Helper
Thanks ∞
PF Gold
Simon Bridge's Avatar
P: 10,973
I think the way to see the phase motion is to pick an individual peak and keep your finger on it.
mycotheology
#4
Nov21-12, 12:59 PM
P: 90
Quote Quote by jtbell View Post
So if I did a Fourier transform on the wavepacket and broke it down into its constituent sine waves, they'd be moving to the left. Still can't see it though. Are you able to see the individual waves inside the packet in that diagram?
Quote Quote by Simon Bridge View Post
Whats confusing me is the way each individual ripple is growing and shrinking as it moves from left to right. In other words, each peak is moving up and down the y axis as it traverses the x axis. I thought that phase depended on the position on the y axis. If I follow an individual peak, I do see it moving from right to left though, should I just forget about the y axis?
arildno
arildno is offline
#5
Nov21-12, 01:18 PM
Sci Advisor
HW Helper
PF Gold
P: 12,016
Group velocity is, essentially, the velocity by which ENERGY propagates. Energy is what effectively determines the actual AMPLITUDE of a given peak, whereas the peak itself moves with a different velocity. THAT velocity is what we call phase velocity.
DocZaius
DocZaius is offline
#6
Nov21-12, 01:37 PM
P: 287
In this image, the red dot is moving at phase velocity and the green dot at group velocity. In this image they both go in the same direction, unlike in your image.
Ignore the up and down motion. Just identify a peak - any peak - and consider its left-right velocity. That is the phase velocity.
mycotheology
#7
Nov21-12, 04:32 PM
P: 90
Quote Quote by DocZaius View Post
Ah right, that clears it up, thanks a lot.
Simon Bridge
#8
Nov22-12, 12:28 AM
Homework
Sci Advisor
HW Helper
Thanks ∞
PF Gold
P: 10,973
That's it :)
The phase is the angle that the phasor makes with the horizontal axis.
If the length of the phasor is constant, then that corresponds to the y-coordinate.
But if the length of the phasor is a function of time, then the same phase points may have different y-positions. All the peaks have the same phase - and they are easy to see - so...
http://en.wikipedia.org/wiki/Phasor (second diagram)
Register to reply
Related Discussions
Measure Phase velocity/group velocity of EM-wave Classical Physics 3
EM Group velocity & phase velocity in dispersive medium Classical Physics 5
How is it that phase velocity is usually faster than group velocity? Classical Physics 0
understanding for group velocity and phase velocity?? General Physics 10
questions about phase velocity, and group velocity Quantum Physics 11
