| New Reply |
Times New Roman font in Latex |
Share Thread | Thread Tools |
| Nov20-12, 12:35 PM | #1 |
Hello,
I need to change the font in my latex file to Times New Roman, and I used this in the preamble to do that: Code:
\usepackage{fontspec}
\setmainfont{Times New Roman}
Thanks |
| Nov20-12, 06:19 PM | #2 |
Recognitions:
How are you doing the compilation and what are the errors?
| Nov20-12, 09:24 PM | #3 |
| Nov21-12, 12:54 AM | #4 |
Recognitions:
In order to turn a .tex file into a .ps file, you had to use a computer program - there are lots that do this: which one did you use. Likewise for doing the .ps to a .pdf.
You can turn a .tex directly into pdf using the program "pdflatex" for example, or from ps to pdf using "ps2pdf". The errors are important for figuring out what went wrong. i.e. perhaps the font does not have some of the characters you are trying to use - the errors will tell you that. |
| Nov21-12, 10:33 AM | #5 |
| Nov21-12, 10:50 PM | #6 |
Recognitions:
Yep, XeLatex bundles the stuff commonly needed and has good online support.
I still use CLI latex and pdflatex with a text editor. For anything besides pdf I'd export to dvi but tiks figures won't do that will they? Of course you could have imported the ps using Adobe Acrobat ... but you may be using Linux or only free/gratis software. In future - remember that this sort of question is meaningless without the names of the software used and the exact error messages (copy and paste). |
| Nov22-12, 08:16 AM | #7 |
Recognitions:
Code:
\sepackage{fontspec}
| Nov22-12, 12:08 PM | #8 |
Yet there is another problem, which is that my document is now written in two fonts after using the above package: Not all my document appear the same. Some fonts are the default (which is bright), and some fonts are Times New Roman (which is dark). Why? |
| Nov22-12, 12:32 PM | #9 |
Recognitions:
If you make a SMALL document that shows the problem and attach it, somebody might be able to help.
Otherwise, we are just guessing. You haven't told us anything about what you did except "it didn't work". |
| Nov22-12, 12:49 PM | #10 |
Thanks |
| Nov22-12, 05:14 PM | #11 |
Recognitions:
When I said "attach the file" I meant the tex input file, not just the output, so anybody who is interested enough can play around with it in their version of TeX.
I'm not convinced you have two different fonts. I can see what you describe when I look at the PDF with Adobe Reader 11, but when I zoomed in on the same word on pages 1 and 2, made two screen dumps, and pasted them side by side, I can't see any difference at all. (Open the attachment in a separate window to see it "full size"). Using "properties" in Adobe reader the only fonts in the PDF are Times Roman, Times Roman Bold (probably used for the headings) and a lot of the Computer Modern fonts for the math. Computer Modern text fonts don't look anything like Times Roman, so can't be one of those. This is probably some weird artefact of way the the PDF viewer is rendering the font, not a TeX problem. It's possible you have done something (e.g. when creating the figure?) that changed the "weight" (i.e. blackness) of the font slightly, and didn't change it back again. Try deleting the figure and see if that gets rid of the problem. |
| Nov22-12, 06:40 PM | #12 |
I tried to do the same as in my document, but the result was not the same:
Code:
\documentclass[a4paper,oneside,12pt]{report}
\usepackage{amsmath}
\usepackage{tikz}
\usetikzlibrary{positioning}
\usetikzlibrary{shapes,arrows,fadings, shadows}
\begin{document}
A major design parameter here is the accuracy of the factor $a$, and the residual Doppler the tolerated by an adaptive equalizer, where a residual Doppler of the order $10^{-4}$ is needed to a ... equalizer to track the changes, otherwise, it diverge .... In ... it was shown that the preprocessing resampling converts the wide-band signal to a narrow-band signal, where ... can be used to eliminate the residual Doppler effect resulting from the estimation error of the factor $a$.
\tikzstyle{block} = [draw, top color=blue!40,
bottom color=blue!5, rectangle, minimum height=3em, minimum width=6em, shade, rounded corners,drop shadow]
\tikzstyle{sum} = [draw, top color=blue!40, bottom color=blue!5, circle, node distance=1cm, shade,drop shadow]
\tikzstyle{input} = [coordinate]
\tikzstyle{output} = [coordinate]
\tikzstyle{pinstyle} = [pin edge={to-,thin,black}]
\begin{figure}[h!]
\begin{center}
\begin{tikzpicture}[auto, node distance=2cm,>=latex']
%\begin{tikzpicture}[scale = 0.6]
% We start by placing the blocks
\node [input, name=input] {};
\node [block, right of=input,node distance=3cm] (Map) {Mapping};
\node [block, right of=Map,
node distance=4cm] (IDFT) {IDFT \& $+$CP};
\node [block, right of=IDFT,
node distance=4cm] (ch) {$\{h_l\}$};
\node [block, below of=ch,
node distance=3cm] (DFT) {-CP \& DFT};
\node [output, right of=ch,node distance=3cm] (output1) {};
\node [sum, below of=output1,node distance=1.5cm] (sum) {$\Sigma$};
\node [block, left of=DFT,
node distance=4cm] (FDE) {FDE};
\node [block, left of=FDE,
node distance=4cm] (Dec) {Detection};
\node [output, left of=Dec,node distance=3cm] (output2) {};
\node [input, right of=sum,node distance=2cm] (input2) {};
%\node [output, name=output, right of=IDFT] {};
% We draw an edge between the controller and system block to
% calculate the coordinate u. We need it to place the measurement block.
%\draw [->] (controller) -- node[name=u] {$u$} (system);
%\node [block, below of=u] (measurements) {Measurements};
%% Once the nodes are placed, connecting them is easy.
\draw [draw,->] (input) -- node {$\{b_k\}$} (Map);
\draw [draw,->] (Map) -- node {$\{X_k\}$} (IDFT);
\draw [draw,->] (IDFT) -- node {$\{x_n\}$} (ch);
\draw [draw,->] (ch) -| node {} (sum);
%\draw [draw,->] (sum) -- node {} (output1);
\draw [draw,->] (sum) |- node [pos=0.8]{$\{y_n\}$} (DFT);
\draw [draw,->] (DFT) -- node {$\{Y_k\}$} (FDE);
\draw [draw,->] (FDE) -- node {$\{\tilde{X}_k\}$} (Dec);
\draw [draw,->] (Dec) -- node {$\{\hat{b}_k\}$} (output2);
\draw [draw,->] (input2) -- node {$\{z_n\}$} (sum);
%\draw [->] (sum) -- node {$e$} (controller);
%\draw [->] (system) -- node [name=y] {$y$}(output);
%\draw [->] (y) |- (measurements);
%\draw [->] (measurements) -| node[pos=0.99] {$-$}
%node [near end] {$y_m$} (sum);
\end{tikzpicture}
\caption{OFDM block diagram}
\label{Fig:OFDMBD}
\end{center}
\end{figure}
A major design parameter here is the accuracy of the factor $a$, and the residual Doppler the tolerated by an adaptive equalizer, where a residual Doppler of the order $10^{-4}$ is needed to a .. equalizer to track the changes, otherwise, it diverge .... In ... it was shown that the preprocessing resampling converts the wide-band signal to a narrow-band signal, where ... can be used to eliminate the residual Doppler effect resulting from the estimation error of the factor $a$.
\end{document}
| Nov22-12, 08:07 PM | #13 |
| Nov22-12, 09:32 PM | #14 |
Recognitions:
OK, the "good" news is I can reproduce it, but understanding it might take longer (and I don't have much time tomorrow).
It seems to be affecting all the text on the page with the figure on it (both before and after the actual figure). The preceding and following pages all seem to be in the "light" typeface. IMO that's a "should not happen" situation - it suggests something is incompatible with something else, but it's not at all obvious what. |
| Nov22-12, 09:37 PM | #15 |
Thanks for your help. |
| Nov23-12, 02:33 PM | #16 |
Recognitions:
FWIW I got a warning in the .log file saying Package pgf Warning: Your graphic driver pgfsys-xetex.def does not support fadings. Googling various TeX forums, it seems like the only workround is to make a separate tex file for each figure, create a PDF for each one, then use \includegraphics to merge them into the complete document. You will have to play around with the "bounding box" options of \includedgraphics to crop the images down to their "actual size". Of course an easier workround is to decide that you don't really need boxes with shadows! |
| Nov23-12, 03:15 PM | #17 |
| New Reply |
| Thread Tools | |
Similar Threads for: Times New Roman font in Latex
| Thread | Forum | Replies | ||
| LaTeX Font Different from Usual? | Forum Feedback & Announcements | 3 | ||
| bold font in latex | Math & Science Software | 6 | ||
| what font does latex use? | General Math | 6 | ||
| LaTex font size | Forum Feedback & Announcements | 2 | ||
