New Reply
Waveguide standing wave pattern
Share Thread Thread Tools
Nov20-12, 11:09 PM   #1
Hi everybody, that's my question, I have been measuring the standing wave pattern within a waveguide (X band) using a slotted line, I put a short circuit termination and the theory said that we expect a rectified sine, but I don't get that, my result is in the picture
I can't explain my results and I have tried with two different microwave sources (10.5 GHz).
I appreciate your help.
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Company pioneering new types of material for 3-D printer 'ink'
>> Student-built innovations to help improve and save lives
>> Researchers use light projector and single-pixel detectors to create 3-D images
Nov21-12, 04:57 AM   #2
Recognitions:
Gold Membership Gold Member
Quote by JuanCarlos View Post
That looks more like the phase variation along a line than the amplitude variation. Is that possible?
Nov21-12, 04:59 AM   #3
Recognitions:
How does that pattern change when you change the load on the end (good match / fair match / short circuit) ?
Nov21-12, 07:07 AM   #4
I have measured the standing wave pattern in the air using the same source and the results looks better, of course that's not a short circuit but the wave is not inclined.
I've been thinking if it is about the propagation mode.
Nov21-12, 07:12 AM   #5
Quote by sophiecentaur View Post
The picture is a short circuit, and when the load is changed, the swr and the phase changes, but the wave is still inclined.
That's an arbitrary load pattern.
Nov21-12, 10:52 AM   #6
Recognitions:
You need someone with more experience with waveguide, I think. My actual work was all on UHF and coax feeder.
If I were chasing stange things like that, I think I'd put a 3dB attenuator (resistive) in the source to improve that match and put a good terminating load at the end. If I couldn't get a flattish line then, I would be scratching my head. I could suggest that harmonics in the signal source could be setting up another standing wave which adds to the one you want? (Not relevant if you are using a 'proper' receiver but could be, if you are just using a simple detector.) Solution: filter the output of the signal source.
New Reply
Tags
experimental, pattern, slotted line, standing wave, waveguide
Thread Tools
Similar Threads for: Waveguide standing wave pattern
Thread Forum Replies
experimentally observe waveguide mode pattern Classical Physics 0
Standing Wave pattern on an open circuited transmission line with length λ/4 Electrical Engineering 3
radiation pattern in waveguide Electrical Engineering 0
circular waveguide wave-equation Advanced Physics Homework 4
Maxwell Equations and Waveguide: why only TE or TM wave and not TEM? Classical Physics 10
