New Reply
Does Decoherence Solve the Measurement Problem Completely
Share Thread Thread Tools
Nov21-12, 12:44 PM   #1
As the Title describes, Is the measuremet problem completely solved by the decoherence Program?
In specific I would like the following question addressed.
Is there is clear explanation as to what it means to Record Infromation?
Can it explain the behaviour of a photographic plate?
What happens to the appratus after measurement?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Promising doped zirconia
>> New X-ray method shows how frog embryos could help thwart disease
>> Bringing life into focus
Nov21-12, 03:12 PM   #2
Some believe it solves it, others say it works only for all practical purposes (i.e. technically the state of the system+apparatus+enivornment is in superposition).
Roland Omnes is a proponent of the decoherence approach, not just as a practise of solving the measurement problem, but also in principle. See "The Interpretation of Quantum Mechanics" pages 304-309.
Nov22-12, 11:21 AM   #3
I think this link argues quite nicely why decoherence does not solve the philosophical issues:
http://plato.stanford.edu/entries/qm...nce/#SolMeaPro
Money quote:
In the special case of measuring apparatuses, it would explain why we never observe an apparatus pointing, say, to two different results, i.e. decoherence would provide a solution to the measurement problem of quantum mechanics. As pointed out by many authors, however (e.g. Adler 2003; Zeh 1995, pp. 14–15), this claim is not tenable.
See also here
http://arxiv.org/abs/quant-ph/0312059
Nov22-12, 03:17 PM   #4
It's even hard to argue that decoherence solves any aspect of the measurement problem. All the measurement related features are implicitly imported through the backdoor by using the measurement postulate to define density operators. Any argument for decoherence giving insight into measurement is therefore circular.
Nov23-12, 08:11 AM   #5
Quote by StevieTNZ View Post
Exactly.
You will find a good discussion of the issue in Schlosshauers book on decoherence:
http://www.amazon.com/Decoherence-Cl.../dp/3540357734
The measurement problem has a number of parts. There is the preferred basis problem ie why a particular basis is singled out. It solves that. Then there is the issue of why a particular outcome occurs and indeed why any outcome occurs at all. It doesn't solve that in a fundamental way but does for all practical purposes meaning you can assume it does, that the outcome exists prior to observation, and no experiment can say you are wrong. If that is satisfactory depends purely on your interpretation.
Yes decoherence incorporates the Born rule and assumes it but refines it so some of its 'weirder' features are no longer an issue eg you can assume the system is in the state prior to observation which you cant do without decoherence - the reasoning is not circular. Interpretations that include decoherence such as decoherent histories call probabilities calculated without reference to an actual observational apparatus pre-probabilities - they are not manifest until decoherence occurs in an apparatus.
Depends on what you accept as clear. If you mean it explains the why of a particular outcome then no.
Depends on what you accept as explain - for all practical purposes it does but if you want more than that - sorry - you are out of luck.
Nothing - the observation selected an outcome - that's it - that's all.
Thanks
Bill
Nov24-12, 04:26 PM   #6
Quote by Jazzdude View Post
I'm not sure how familiar anyone is with the specifics of this approach but in the paper below Zurek goes to great lengths to derive the Born rule without any use of density operators and related concepts in order to avoid the circularity mentioned above:
Probabilities from Entanglement, Born's Rule from Envariance (Zurek, 2005)
I'm really not equipped to analyze the subtleties involved with his approach but when I read through it the following caught my eye (p.19):
Quote by Zurek View Post
To demonstrate Lemma 5 we need one more property
– the fact that when a certain event U (p(U) = 1) can
be decomposed into two mutually exclusive events,
U = κ ∨ κ⊥, their probabilities must add to unity:
p(U) = p(κ ∨ κ⊥) = p(κ) + p(κ⊥) = 1 , (29)
This assumption introduces (in a very limited setting)
additivity. It is equivalent to the statement that “something
will certainly happen”.
Could someone accuse him of an act of "smuggling" here?
Also, as far as decoherence in general I quite enjoyed working my way through this:
Decoherence, the measurement problem, and interpretations of quantum mechanics (Schlosshauer, 2004)
David Wallace has written on this topic extensively, I believe.
Nov25-12, 10:00 AM   #7
Quote by eloheim View Post
Zurek doesn't really argue in the context of decoherence, and he postulates additional structure that allows him to derive the Born rule from something that is pretty close to the Born rule already.
David Wallace' own arguments are mostly focused on decision theory based approaches to deriving the Born rule in an Everett context. This is also not decoherence and it also requires additional postulates.
Nov25-12, 12:50 PM   #8
I'm pretty sure that he's talking about the work Wallace has done on explaining the emergence of worlds and preferred basis through decoherence. Like in his FAPP paper (http://arxiv.org/abs/1111.2189)
Nov25-12, 01:03 PM   #9
Quote by Quantumental View Post
This is Everett, which of course makes use of decoherence. The OP was asking about just decoherence however, which is a different thing than MWI.
Nov25-12, 01:16 PM   #10
Well the claim of Wallace is that Everett really just is the QM formalism + decoherence
Nov25-12, 01:38 PM   #11
Yes, but it's still not what people mean when they say decoherence. Decoherence on its own is agnostic of the concept of worlds.
Nov25-12, 04:04 PM   #12
Recognitions:
Gold Membership Gold Member
I found this piece by Leifer disussing decoherence useful:
In conclusion, decoherence theory has done a lot for our understanding of the emergence of classicality from quantum theory. However, it does not solve all the foundational questions about quantum theory, at least not on it’s own. Further, its importance may have been overemphasized by the physics community because other less-developed approaches to emergence could turn out to be of equal importance.
What can decoherence do for us?
http://mattleifer.info/2007/01/24/wh...nce-do-for-us/
Nov25-12, 04:40 PM   #13
Quote by bohm2 View Post
But look at Matt Leifer's comment in the comment section from 2010.
It seems he has been won over by Wallace too.
Nov25-12, 04:42 PM   #14
Sure, but I think the more interesting debate is whether decoherence can give us a preferred basis and emerge a classical world.
According to a recent paper by Jan Scwhindt which was briefly discussed here, it cannot.
There is yet another paper that was released recently by a physicist named Oleg Lychkovskiy: http://arxiv.org/abs/1210.4124
I don't grasp this paper though, but you might.
Nov25-12, 06:47 PM   #15
Recognitions:
But look at Matt Leifer's comment in the comment section from 2010. It seems he has been won over by Wallace too.
I don't get that from the 2010 quote. Here is what he writes in the 2007 blog:
However, the point here is that the work is not being done by decoherence alone, as claimed by some physicists, but also by a nontrivial ontological assumption about the state-vector. As I remarked earlier, the latter is itself a point of contention, so it is clear that decoherence alone is not providing a complete solution.
And this is what he wrote in his 2010 post:
To do this, you need to add an ontology, but it turns out that most of the ontologies that have been considered end up relying on precisely these formal derivations to get emergence. Perhaps the best worked out example is in the Everett interpretation where you can look at the long papers by David Wallace to find out how decoherence leads to emergence in that case. There is no new maths in these papers, but it provides the necessary philosophical support that you are looking for in that case. Bohmian mechanics is somewhat similar in that it needs decoherence in order to make the trajectories follow their classical counterparts in a stable manner and again there is no new maths involved in understanding this. Therefore, I guess what I was trying to say is that we seem to understand the broad outline of how classicality emerges, with the proviso that the meaning attached to that understanding is ontology dependent.
So, unless I'm misunderstanding Leifer is still arguing that decoherence, by itself, cannot solve the measurement problem.
Nov25-12, 07:06 PM   #16
It doesn't - what it allows is for a minimalist interpretation like decoherent histories that does.
Thanks
Bill
Nov25-12, 08:15 PM   #17
I think the important part is where he says:
" Perhaps the best worked out example is in the Everett interpretation where you can look at the long papers by David Wallace to find out how decoherence leads to emergence in that case. There is no new maths in these papers, but it provides the necessary philosophical support that you are looking for in that case. "
New Reply
Tags
measurement, quantum mechanics
Thread Tools
Similar Threads for: Does Decoherence Solve the Measurement Problem Completely
Thread Forum Replies
Problem about quantum environmental decoherence Quantum Physics 13
Decoherence and measurement Quantum Physics 18
Decoherence and the measurement problem Quantum Physics 0
Does decoherence solve the measurement problem? (was:How probable General Physics 25
The Quantum Measurement Problem and Decoherence Quantum Physics 5
