New Reply
Resistance between parallel wires in an insulator?
Share Thread Thread Tools
Nov28-12, 12:12 PM   #1
Hi all,
New here...I was wondering if anyone knows a formula to calculate the (insulation) resistance between two parallel conductors buried in an insulator. For example say 2 copper pins of 1mm diameter spaced 2mm apart over a 20mm length in a plastic (ptfe). The numbers/material are not specific to what I want to do just for example purposes.
Any help would be great as I've seen stuff for concentric cylinders but nothing for parallel conductors.
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Nov28-12, 06:26 PM   #2
Recognitions:
Homework Helper Homework Help
Would it be the same diffusion equation as for heat flow?
New Reply
Thread Tools
Similar Threads for: Resistance between parallel wires in an insulator?
Thread Forum Replies
500amps in parallel wires -resistance change? General Physics 9
two parallel wires Introductory Physics Homework 2
Two Parallel Wires( in 2 hrs!) Introductory Physics Homework 14
Parallel Wires Introductory Physics Homework 1
Parallel wires Introductory Physics Homework 9
