| New Reply |
A question about particle mass |
Share Thread | Thread Tools |
| Nov29-12, 06:40 PM | #1 |
If you were to rearrange the equation E=mc^2 into m=E/c^2 and for E you used reduced planck's constant (joules) would it be a mass of some unknown/known particle?
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Nov29-12, 08:58 PM | #2 |
Mentor
If by "reduced Planck's constant" you mean ##\hbar##, its units are joule-seconds, not joules.
| Nov29-12, 10:01 PM | #3 |
I know, but I'm assuming 1 sec
| Nov29-12, 10:12 PM | #4 |
Recognitions:
| Nov29-12, 10:28 PM | #5 |
Why are people like this on the forums.
| Nov29-12, 10:55 PM | #6 |
Recognitions:
| Nov29-12, 11:25 PM | #7 |
I just wanted the *base* energy. And so one times that equals well... H-bar
| Nov29-12, 11:27 PM | #8 |
Recognitions:
In physics, the question is just as meaningful as an answer. If you are going to ask a question that makes no sense, people are going to call you on that, and it's not our fault. Now, I am always happy to explain why a particular question is meaningless. Whether I can explain it in a way you would understand, I don't know. And that's as much limitation of my abilities as yours. If something still isn't clear and you want a more detailed explanation, ask away. Try to be specific. If you simply want to pretend that every question you make up has meaning and must be answered as such, then you are in the wrong place. |
| Nov29-12, 11:36 PM | #9 |
Recognitions:
You cannot answer a bad question. A false assumption can be used to derive absolutely anything. The only good answer to a bad question is explanation why it's a bad question. Any other ideas you have on the topic are objectively wrong.
| Nov29-12, 11:37 PM | #10 |
Not 1... 1 second.
| Nov30-12, 12:34 AM | #11 |
Recognitions:
| Nov30-12, 01:38 AM | #12 |
Recognitions:
Worse yet, h-bar times one second doesn't give you joules either. The units of h-bar are joules-seconds, not joules/second. You have to multiply by something with units of inverse time. |
| Nov30-12, 06:51 AM | #13 |
If you were to divide h-bar by one second wouldn't the seconds cancel out?
| Nov30-12, 10:48 AM | #14 |
Recognitions:
It would, but it does not have any special physical meaning. It is an arbitrary energy which depends on the length of a day on earth (as this was originally used to define "1 second").
| Nov30-12, 02:23 PM | #15 |
Recognitions:
What is legitimate is to take a collection of universal constants and combine them: h-bar/c2 will give you something apparently interesting in units of mass*time. |
| Nov30-12, 03:46 PM | #16 |
I really wish I could post stuff here without being bashed for mistakes and explained POLITELY why it's wrong and not with sarcasm and rudeness.
| Nov30-12, 09:07 PM | #17 |
Recognitions:
There is no sarcasm. You were told several times by several different people that there is nothing special about 1 second as a unit of time. That's all there is. Why do you insist to divide by 1 second and not by 1 day? Can you explain that? If there is nothing special about it, then why should there be anything special about associated energy?
| New Reply |
| Thread Tools | |
Similar Threads for: A question about particle mass
| Thread | Forum | Replies | ||
| whenever we increase the velocity of a particle, the mass of he particle also... | Special & General Relativity | 3 | ||
| A particle of rest mass m_0 and kinetic energy and sticks to a stationary particle wi | Advanced Physics Homework | 1 | ||
| Charge to Mass Ratio of a Particle to Electron - Mass | Introductory Physics Homework | 2 | ||
| Particle physics - invariant mass question | Advanced Physics Homework | 2 | ||
| Transit time of particle in a particle accelerator question | Classical Physics | 4 | ||
