| New Reply |
Planning to buy a first telescope? |
Share Thread | Thread Tools |
| Nov29-12, 01:11 PM | #154 |
The ideal wide field would be around 30mm with at least a 68 degree apparent field of view. Unfortunately, ep's of this description are pricey and the choices are pretty limited in the 1.25" size. I would check out ebay, sometimes you can snag one on the cheap. Just make sure it has a 1-1/4 barrel and not 2".
| Nov29-12, 04:46 PM | #155 |
The first thing I would get is this variable polarizer filter. I don't know of any 30mm 68 degree eyepieces in the 1.25" form factor. The only ones I'm familiar with in the 1.25" barrel size are the 24mm ones like the Explore Scientific and the now discontinued Meade Series 5000 SWA 24mm which you can still pick up used for $90-$100. I think you should pick up a nice 3X Barlow and keep using the 25mm plossl. A 3X barlow will give you ~150X which is pretty good magnification for that telescope.
| Nov29-12, 07:19 PM | #156 |
The telescope that I have coming in already has a 2x Barlow, so I'm wondering if a 3x Barlow would be a little overkill. With the 25mm Plossl I'll have 48x magnification, and with the 2x Barlow + the 25mm, I'll have 96x magnification, whereas with the 3x Barlow it would be 144x. Is that significant enough to be a worthwhile investment? I'm thinking that a more powerful eyepiece would be more beneficial, if I'm just trying to zoom in farther. As for the filter, that looks like a good investment. |
| Nov29-12, 07:39 PM | #157 |
Magnification isn't as big of an issue as one might think. Your resolution on planets will be limited by your scopes diameter and for most deep sky objects less magnification may be better than more, as you concentrate the light and make them easier to see.
| Nov29-12, 08:07 PM | #158 |
Orion stratus also has a 24 mm wide field, but, it runs about $150. Konig has a 20 mm for about $60 and Knight Owl has one for $34, but, 20 mm is not terrible. With a 68 degree FOV you should have a true field of view a little over 1 degree and 60x magnification, which is about where you want to be. A 3x barlow would be a waste of money, IMO. You will rarely have nights where you can effectively use more than 25-30x your aperature in magnfication. An inexpensive 6 or 8mm super plossl or ortho will be enough for those rare occassions.
| Nov29-12, 09:03 PM | #159 |
Thanks for the help, everyone. I'm sure that I would've made at least one stupid purchase had I not checked here first. I'll pick up the Knight Owl 20mm along with that variable polarizer filter.
Although, if I were to be using the 20mm with the wide FOV, and then slap on my 2x Barlow, that wouldn't affect the FOV at all, would it? I'm thinking not, but want to make sure it doesn't because I would like to get up to 10mm with a nice, wide FOV. EDIT: I also found a $15 new Super Plossl 10mm EP on ebay, but I'm hesitant to do anything because my 2x Barlow would essentially turn my 20mm Night Owl into a 10mm as well. Is the quality of a view between an actual eyepiece, and an improved-through-using-a-barlow EP significantly different? EDIT #2: So I figured out that using the Barlow on the 20mm Night Owl with a 68 degree FOV will decrease its FOV. My new question is how that decreased FOV would compare to a 52 degree FOV of a Meade Super Plossl 10mm, seeing as how I'm not sure how to do the math behind this. |
| Nov29-12, 10:37 PM | #160 |
If you don't want to invest much, you might consider an inexpensive extension to get your 2X barlow up to about 3X. A barlow lens is like a projector lens in that the farther away you place your eyepiece, the larger the magnification. This would definitely not be overkill and would represent a significant increase in magnification vs. the 2X barlow + 25mm (96X). |
| Nov29-12, 11:00 PM | #161 |
http://www.telescope.com/Articles/Cu...94/p/99822.uts http://en.wikipedia.org/wiki/Eyepiece#Field_of_view |
| Nov29-12, 11:05 PM | #162 |
edit: Jimmy beat me to it. |
| Nov29-12, 11:20 PM | #163 |
That extension piece actually seems interesting. It doesn't explicitly state that it increases the the magnification of a Barlow lens, but if they work as you claim they do, then I would be all for it. "The power of an adjustable Barlow lens is changed by adding an extension tube between the Barlow and the eyepiece to increase the magnification." - Wikipedia. They do mention an "adjustable" Barlow lens, but would a regular, Shorty Barlow 2x lens be acceptable as well? And from what I've gathered, if I were to increase the distance between the eyepiece and the Barlow lens by the length of the Barlow lens one time, then I would bump up its magnification from 2x to 3x. If I were to increase the distance by the length of the Barlow lens again, it would go from 3x to 4x. So the Shorty Barlow 2x lens is 3" long, whereas the eyepiece extension tube can increase the distance between the EP and the Barlow by 2", so I should be increasing the magnification of my Barlow from 2x to ~2.67x magnification. That would give me potentially 160x magnification with my 20mm lens (with my scope having a 1200mm focal length), which is, I think, as much as I'll be getting out of my scope, aside from any crystal clear viewing conditions. That actually seems like the perfect solution, thanks for the idea! EDIT: About the corrections, thanks for clearing that up. I think I was a little confused about the difference between the AFOV and FOV. I should've known that zooming in on something obviously doesn't allow me to see as much of it.... |
| Nov30-12, 12:40 AM | #164 |
So I'm done with all of my purchases now.
In the instance that someone else seems to be in a situation similar to mine, with a budget similar to mine, with interests similar to mine, I'll list what I've purchased, from where, and how much the total cost was for it all: - This telescope (Costs $349.99, but note that I was able to snag a Cyber Monday deal and ultimately got it for $299.99). - This 20mm eyepiece (costs $33.95). - This Variable Density Eyepiece Moon Filter Set (was $19.95 at the time; you'll have to scroll down a bit to see it). - This eyepiece extension tube (costs $19.99). The telescope also included a 2x shorty barlow, so take that into account with it all as well. The total price comes out to $373.88 (with the deals that were present at my time of purchase). Considering the fact that I'm getting the telescope and the accessories that come with it for Christmas, I spent well under $100 of my own money, got some very nice equipment, and am very pleased with my purchases. Once again, thanks for all the help that everyone has provided me; I probably won't need to stop by here again until it's time to unwrap presents
| Nov30-12, 01:00 AM | #165 |
AFOV is the apparent field of view. When you increase magnification, your AFOV is unchanged, but, true field of view [TFOV] decreases commensurately. Your choices look reasonable. The extension tube is probably a waste of money, but, I've wasted a lot more money than that on dubious purchases.
| Nov30-12, 01:11 AM | #166 |
Believe me, the extension tube works as described with the shorty barlow. I've been using mine now for 6 years and it works fine. Eye relief at short focal length is very tight but use a longer FL EP with a barlow and it's nice and comfortable. You can take your time and really concentrate on what you see. You will note that a barlow is built in to every Nagler eyepiece ever made for just that reason.
Use the variable polarizer filter on the end of the barlow, equip it with the extension tube and view comfortably through the 20 or 25 mm EP on the Moon. I can't imagine a better way to spend an evening in the back yard. |
| Nov30-12, 06:21 AM | #167 |
| Dec3-12, 02:33 AM | #168 |
So after a quick google search, I found a pretty legitimate, professional, and interesting local astronomy club. There's a membership fee ($20), but they have their own observatory with a 20" telescope, with its own location in a park.
Most of the members seem to be older guys, but I'm still applying. It should be fun. |
| Dec17-12, 03:37 AM | #169 |
How useful are collimation eyepieces? I wouldn't shell out the money for a laser collimator, but some of the eyepieces (like this one) are as cheap as $30, and appear to work very well.
My scope came with a collimation cap, but even after trying to collimate my telescope, I'm still not sure if it's properly collimated. |
| Dec17-12, 05:21 AM | #170 |
| New Reply |
| Thread Tools | |
Similar Threads for: Planning to buy a first telescope?
| Thread | Forum | Replies | ||
| Death and tax planning | Current Events | 0 | ||
| need help planning my future | Academic Guidance | 8 | ||
| help with thermocouples! (A2 planning) | Introductory Physics Homework | 0 | ||
