New Reply
Orientation Forms in Different Codimension.
Share Thread Thread Tools
Oct15-12, 06:41 PM   #1
Hi, Everyone:
A way of defining an orientation form when given a codimension-1 ,
orientable n-manifold N embedded in R^{n+1} , in which
the gradient ( of the parametrized image ) is non-zero (I think n(x)
being nonzero is equivalent to N being orientable), is to
consider the nowhere-zero normal vector n(x), and to define the
form w(v)_x : = | n(x) v1 , v2 ,...,v_n-1| (**)
Where {vi}_i=1,..,n-1 is an orthogonal basis for T_x N , written
as column vectors, and n(x) is the vector normal to N at x , so that we write:
| n_1(x) v_11 v_21..... v_n1|
| n_2(x) v_12 v_22......v_n2|
|n_n(x) v_1n v_2n.......v_nn|
For vi= (vi1, vi2,....,vin )
Then the vectors in (##) are pairwise orthogonal, and so are
Linearly-independent.
*QUESTION* : How do we define a form for a curve of codimension-1,
and, in general, for orientable manifolds of codimension larger-
than 1 ? I have seen the expression t(x).v , meaning <t(x),v> ,for the curve. But the
tangent space of a curve is 1-dimensional, so, how is this a dot product?
Also, for codimension larger than one: do we use some sort of tensor contraction?
Thanks.
Thanks.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Nov30-12, 07:09 AM   #2
Recognitions:
If the normal bundle to the submanifold is trivial then you can get an orientation form by contracting the orientation form of the ambient manifold by a smooth set of lineally independent normal vector fields.
In Euclidean space you contract the standard volume element.
If the normal bundle is not trivial i am not sure off of the top of my head but let's see if we can figure it out. It shouldn't be hard.
The normal bundle of a hypersurface (closed without boundary, codimension 1) of Euclidean space is always trivial but I do not know a direct proof and again would like to work on it with you. I do know a nasty indirect proof if you would like to see it.
Nov30-12, 05:10 PM   #3
Quote by lavinia View Post
Sure, I'll work on it with you. Do you have any suggestions/format in mind?
Dec1-12, 08:53 AM   #4
Recognitions:
Quote by WWGD View Post
Just looking at ideas plus some reading. My first thought is to see if there is something that can be dome with the Thom class of the normal bundle to the submanifold.
Dec2-12, 09:05 AM   #5
Recognitions:
I think you can Just contract the volume element of the ambient manifold by a local orthonormal basis for the normal bundle over each coordinate chart. Over each chart you get a local volume form for the submanifold and since the coordinate transformations are in SO(n) they should piece together to give you a global orientation for on the submanifold. Is this right?
Dec2-12, 12:38 PM   #6
Recognitions:
BTW: it follows that if the normal bundle is orientable then the submanifold must be orientable as well.
Dec2-12, 01:09 PM   #7
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
I think this is correct. Well done lavinia!
Dec2-12, 01:12 PM   #8
Recognitions:
More generally, I think if a vector bundle E splits as a direct sum of two subbundle F and G, then 2 of them are orientable iff the third one is.
New Reply
Thread Tools
Similar Threads for: Orientation Forms in Different Codimension.
Thread Forum Replies
Orientation of Receiver Antennas given orientation of transmitter Introductory Physics Homework 1
codimension k stratum Differential Geometry 2
Example of Codimension-1 Manifolds that are not Isotopic.? Differential Geometry 2
The Codimension of a singularity Differential Geometry 4
Field theory and valuations of codimension 2? Linear & Abstract Algebra 0
