How can I determine the limits of integration for an Archimedian spiral?
  • Thread starter Thread starter CAF123
    Area Spiral
The discussion revolves around determining the limits of integration for calculating the area of an Archimedean spiral. Participants are exploring the setup of integrals in polar coordinates and questioning the appropriateness of their chosen limits and methods.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the integration limits and the dependence of the integration variable on θ. There are attempts to clarify the boundaries of the shaded regions and the implications of using polar coordinates for area calculation.
Some participants have offered insights into the nature of the spiral and the integration process, suggesting the need for a double integral approach. There is recognition of ambiguity in the original problem statement, and various interpretations of the limits of integration are being explored.
Participants note that the area calculation in polar coordinates requires careful consideration of the relationship between r and θ, and there is discussion about the potential for overlapping areas in the integration process.
CAF123
See the attached link
I considered each shaded part separately. For the one between ##2\pi ## and ##4\pi##, I set up: $$\int_{2\pi}^{4\pi} ((4\pi +\frac{\pi}{2})- (2\pi + \frac{\pi}{2}) d\theta$$ I used a similar method for the other portions and for each portion, I end up with ##4\pi^2##. This does not seem right because some of the shaded sections look larger than the others.
Where is the fault with my method?
Thanks!
I would expect that your integration variable depends on θ in some way. You just integrate over 2 pi (why?).
In considering the first shaded section (between 2pi and 4pi), I say that the curves ##r = \theta_1 = (4\pi + \pi/2) ## and ##r = \theta_2 = (2\pi + \pi/2)## bound this section.
I see what I have done wrong. ##\theta## is continually changing so indeed there should be a theta dependence. How do I get the curves that bound each section then?
I think you you integral gives the area between two concentric circles of radii [itex]2\pi+ \pi/4= 9\pi/4[/itex] and [itex]4\pi+ \pi/2= 9\pi/2[/itex].
The two arms of the spiral, at the start where [itex]\theta= 0[/itex], a ray starts at [itex]2\pi[/itex] and ends at [itex]4\pi[/b], but as [itex]\theta[/itex] increases, so does the distance from the origin to those endpoints. On has [itex]r= 2\pi+ \theta[/itex]<br /> <br /> I confess that at first, I thought you were, in fact, using an integral that would give the distance between two concentric circles, but what you are doing is, basically, correct. At the beginning, [itex]\theta= 0[/itex], the x-axis cuts the first loop of the spiral at [itex]2\pi[/itex] and the second at [itex]4\pi[/itex] so its length is [itex]4\pi- 2\pi= 2\pi[/itex]. As [itex]\theta[/itex] increases, a ray crosses the first loop at [itex]2\pi+ \theta[/itex] and the second at [itex]4\pi+ \theta[/itex] but, to my surprise, the difference is still [itex]2\pi[/itex]- there is NO [itex]\theta[/itex] dependence. I don't see where your [itex]2\pi[/itex] terms come from. And I certainly cannot imagine why you are <b>multiplying</b> them!<br /> <br /> Since we make one complete loop around the center, the integral does go from [itex]\theta= 0[/itex] to [itex]2\pi[/itex]. Since area, in polar coordinates, is given by [itex]\int rd\theta[/itex], the area you want here is given by<br /> [tex]\int_{\theta= 0}^{2\pi} 2\pi d\theta= 2\pi \int_{\theta= 0}^{2\pi} d\theta[/tex][/itex]
HallsofIvy said:
I don't see where your [itex]2\pi[/itex] terms come from. And I certainly cannot imagine why you are multiplying them!
Where am I multiplying them about?
Why do we consider theta from 0 to 2pi? this does not correspond to a shaded section?
Thanks.
The integral itself does not work. In polar coordinates, area is given by r dr dθ. You can perform the integration over r first (this is a good idea), but the result is not just the difference in radius, due to the additional factor of r inside. You will get expressions with the squared radius.
So we consider a double integral here? why? Would the limits of r and θ be the same?
You want to calculate an area - it is two-dimensional. In a cartesian coordinate system, many problems have a trivial integral in one coordinate - you can simplify the two-dimensional integral to one dimension without calculating anything.
In polar coordinates, this can work for θ, but it cannot work for r, as the area element depends on r.
The limits for r and θ are fine.
The polar area between the origin and ##r = f(\theta)## for ##\theta## between ##\alpha## and ##\beta## is$$
A=\frac 1 2\int_\alpha^\beta f^2(\theta)\, d\theta$$The tricky thing about your problem is some of the area gets repeated as ##\theta## varies. If you let ##\theta## go from ##4\pi## to ##6\pi## you would get all the area that is shaded plus the white center area. Then it looks to me like you could subtract that white area by going from ##2\pi## to ##4\pi##, unless I'm overlooking something.
Would you not subtract from ##0## to ##4\pi##?
Could you explain a bit more what you mean here? I have done integrals that represent areas as single integrals, (I.e at high school level).
That counts some of the white area more than once, no? If you shade that inside area for ##\theta## sweeping from ##0## to ##2\pi##, that same area is swept out again as ##\theta## goes from ##2\pi## to ##4\pi##.
I see. Your method gives the correct answer.
Thanks!
For one thing, your reference to the shaded part "between ##2\pi ## and ##4\pi##" is at best ambiguous and at worst it makes no sense.
The spiral from θ = 2π to θ = 4π forms the "inner" boundary of the shaded region.
You can do this nicely with an iterated (double) integral in polar coordinates. (I assume we don't want that approach here.)
Consider a washer with inner radius, r, and outer radius, R. The area, ΔA, of this washer between θ and θ + Δθ is [itex]\displaystyle \Delta A=(1/2)R^2\Delta\theta-(1/2)r^2\Delta\theta[/itex]
For the spiral in this problem, let r = θ and R = θ + 2π .
Integrate from θ = 2π to 4π .
Consider a washer with inner radius, r, and outer radius, R. The area, ΔA, of this washer between θ and θ + Δθ is [itex]\displaystyle \Delta A=(1/2)R^2\Delta\theta-(1/2)r^2\Delta\theta[/itex]For the spiral in this problem, let r = θ and R = θ + 2π .
Thanks for this method. Yes, I agree that what I wrote in the OP is nonsensical since θ is continually changing. I wouldn't mind seeing the double integral approach, I just don't see why it is necessary? Thanks!
As I said, one integral there was trivial.
If you want to calculate the area under the curve f(x) from a to b, you can express this as $$\int_a^b dx \int_0^{f(x)} 1 dy = \int_a^b dx (f(x)-0) dy= \int_a^b f(x) dx$$ which is the usual one-dimensional integral.
"1" comes from the cartesian coordinate system. It allows to perform the inner integral without writing it down, as it is simply the difference between the upper and lower bound.
In polar coordinates, you cannot do this with the integral over r.
$$\int_{2\pi}^{4\pi} d\theta \int_\theta^{\theta+2\pi} r dr = \int_{2\pi}^{4\pi} \frac{1}{2}\left((\theta+2\pi)^2 - \theta^2\right)d\theta = \int_{2\pi}^{4\pi} (2\pi\theta+2\pi^2)d\theta = 4\pi^3 + 2 \pi (16\pi^2 - 2\pi^2) = 32\pi^3$$
Hmm, looks quite big. Maybe I made an error somewhere.
Of course, it's not necessary.
Do you really want to see it?
Hi SammyS,
What I meant by 'why is it necessary' was why the need for a double integral? Although mfb has cleared that up. Is the double integral approach what mfb showed? If not, yes, I would like to see it.
Thanks.
@mfb the answer is ##16\pi^3##. But I do see your error. Thanks.
Oh, the last 16 should be 8, right.
Right.
mfb said:
Where did you find the error?
##\pi \theta^2 + 2\pi^2 \theta## evaluated between ##2\pi## and ##4\pi## is $$16\pi^3 + 8\pi^3 - 4\pi^3 - 4\pi^3$$
CAF123 said:
Hi SammyS,
Thanks.
That's what I thought you meant ... and the answer is that this can be done without a double integral, so using a double integral is not necessary.
Since you want to see the double integral solution, here it is:
[itex]\displaystyle \int_{2\pi}^{4\pi}\int_{\theta}^{\theta+2\pi}r\,dr\,d\theta[/itex]
You just do the first integration step ("area, ΔA, of this washer") before writing down the integral over θ.
Actually, could you explain how you get those limits: I think the θ limits are from 2π to 4π because that is the 'inner' curve that bounds the shaded section. Correct? Why is r from θ to θ + 2π ?
θ=r is the inner part of your spiral (starting at 2pi and increasing to 4pi), and the outer part is the next winding 2 pi away, so θ=r+2pi (starting at 4pi and increasing to 6pi).
You can change the limits, if you like, for example like this:
$$\int_0^{2\pi} d\theta \int_{2\pi+\theta}^{4\pi+\theta} r dr$$
The θ limits are indeed from 2π to 4π. That's the outer integral.
As for
"Why is r from θ to θ + 2π ?"
Look at your figure. r goes from the inner boundary to the outer boundary. The inner boundary is at r = θ . To get to the outer boundary, r = θ + 2π .
