New Reply
Same Areas of Trapezoid within Triangle, why?
Share Thread Thread Tools
Dec25-12, 07:12 AM   #1
Good day,
while reading up on an elementary math study book, i have encountered that a proof is build upon the following (see attachment for the figure).
Are the Areas CDE and BED really the same? I tried to calculate this from abstraction, not sure where I could have made a mistake..
g1 is the falling diagonal, g2 the rising, referenced to the start (0,0), the intercepts c1 is yielded when g1(x=b); c2 when g2(x=0).
The formula for the area is constructed via (two triangles at the points: [C-(b,c1)-D) and (b,c1)-D-E]) the other vice versa):
CDE: (h-c1)*b*0.5 + 0.5*h*r*m - 0.5*c1*r*m
BDE: (h-c2)*b*0.5 + 0.5*h*r - 0.5*c2*r
I made the whole figure and the formula, so it could all be wrong!
Although I calculated the intercepts with the drawn perpendicular and they came out correct with quite a big figure and m number, I think the rug is in the surface area formula..
Also upon rough calculation I think formula for BED is correct! so CDE must be revisited!!
Thank you for your response!
PhysOrg.com
PhysOrg
mathematics news on PhysOrg.com
>> Mathematicians analyze social divisions using cell phone data
>> Can math models of gaming strategies be used to detect terrorism networks?
>> Mathematician proves there are infinitely many pairs of prime numbers less than 70 million units apart
Dec25-12, 09:34 AM   #2
mfb
Newcomer 2012
Recognitions:
Homework Helper Homework Help
They have the same base (DE) and the same height (h), so they have the same area 1/2 b h.
I don't see the reason for that complicated calculation.
How do you get (b+r,0) as coordinate for C? In general, the difference in x-direction between D and C is not r. This would require that BA and CA have the same length.
Dec25-12, 10:43 AM   #3
Quote by mfb View Post
Hi!
You are right! I' might have used a different letter for it. Actually it should be root[(e*m)^2-h^2] .. i will calculate it accordingly!
Dec25-12, 11:01 AM   #4
I have now replaced the wrong x-coordinate value for the point C but my formula still was phrased correctly, I just made a transfer typo..some other ideas why this seems wrong?
Does it suffice when the base and height is the same? the angle isn't so it shouldn't be so obvious? Or do I overcomplicate this simple exercise?
Dec25-12, 12:22 PM   #5
mfb
Newcomer 2012
Recognitions:
I still don't see the reason for that complicated calculation.
How did you get the area CDE with g1(x)?
Mar18-13, 12:59 PM   #6
Sadly I had no time to properly end this seedless quest.
To answer your question:
The intercepts of the linear equations (diagonals) are needed and then one can split up the triangles (upwards from the diagonal / beneath the diagonal) in two triangles with right angles.
The reason for this complicated formula is following: I only want to use the segments stated in the picture, so as few information as possible.
@ mfb: why is it obvious that they the same base/height? One side they share right! but the angles are different and the other side needed has different length..for me it's not at all obvious..
Mar21-13, 09:49 AM   #7
mfb
Newcomer 2012
Recognitions:
Quote by chrisoutwrigh View Post
I don't see what you mean.
Easy: Both triangles have the area 1/2 b h. Nothing else was required.
They share the same base, and their height is the same (h) as well. Use the standard formula for the area of a triangle, and you are done. This general formula can be derived from the formula of the area of a right triangle in two simple steps, if you like.
New Reply
Tags
intercept theorem, proportion, surface area, trapezoid
Thread Tools
Similar Threads for: Same Areas of Trapezoid within Triangle, why?
Thread Forum Replies
Can fluids flow naturally from areas of lower pressure to areas of higher pressure? General Physics 7
Using Trapezoid Rule Twice...huh? Precalculus Mathematics Homework 3
Maximizing a Trapezoid Calculus & Beyond Homework 1
Integral, Triangle areas? Calculus 16
