New Reply
calculate torque/power needed to lift a 4 kg load
Share Thread Thread Tools
Dec29-12, 05:39 AM   #1
Hi All.
I am looking to determine the torque/power/rpm. needed to lift a 4 kg. load
150 mm vertically in 10 seconds.
I need to use a 6 volt dc. gear motor mounted vertically and connected to a 12 mm
dia. acme lead screw ( steel ) with a 3 mm pitch and 48 % efficiency.
The lead screw nut witch the load is connected to is also steel.
The load guide is a steel tube with a brass bearing.
Please see attached drawing.
Best regards and thanks in advance.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Dec29-12, 09:29 AM   #2
Recognitions:
Homework Helper Homework Help
The following article supplies what you need:
http://en.wikipedia.org/wiki/Leadscrew#Mechanics
Dec29-12, 10:35 AM   #3
Mentor
All of the needed information is in that post. Start with the definition of work to find the work required to lift the weight. then divide by time to find the power. Then divide by efficiency to get the input power needed.
The pitch of the screw tells you how far the weight moves every time the shaft rotates once, from which you can find rpm.
With power and rpm, you can find torque.
Just give it a try with what you already know.
New Reply
Thread Tools
Similar Threads for: calculate torque/power needed to lift a 4 kg load
Thread Forum Replies
Calculate the power of a the lift motor Biology, Chemistry & Other Homework 3
Efficence - Calculate the Force needed to life this load... Introductory Physics Homework 1
Length of bar needed to lift a crate(Torque, static equilibrium problem) Introductory Physics Homework 1
electric power for lift and torque Classical Physics 11
Calculate the force needed to lift General Physics 9
