New Reply
Hidden Markov Models - Likelihood of ...
Share Thread Thread Tools
Jan3-13, 04:10 AM   #1
Hi,
I try to teach myself Hidden Markov Models. I am using this text
www.cs.sjsu.edu/~stamp/RUA/HMM.pdf as Material. The Introduction with
the example was reasonable but now I have trouble in unterstanding
some of the derivation.
I can follow the math and use the formulars to get results but
I also want to understand the meaning behind it.
One question that arise at hidden markov models is to determine
the likelihood of the oberserved sequence O with the given Model
as written below:
b = probability of the observation
a = transiting from one state to another
[itex]\pi[/itex] = starting probability
O = observation
X = state sequence
[itex]\lambda[/itex] = hidden markov model
( Section 4, Page 6 in the Text )
[itex]P(O | X, \lambda) = b_{x0}(O_o)* b_ {x1}(O_o) *\cdots* b_{xT-1}(O_{T-1}) [/itex]
[itex]P(X|\lambda) = \pi_{x_0}a_{x_0,x_1}a_{x_1,x_2}*\cdots* a_{x_{T-1},x_{T-2}}[/itex]
[itex]P(O, X|\lambda) = \frac{P(O \cap X \cap \lambda)}{P( \lambda)}[/itex]
[itex]P(O | X, \lambda) *P(X|\lambda) = \frac{P(O \cap X \cap \lambda)}{P(X \cap \lambda)} \frac{P(X \cap \lambda)}{P(\lambda)}=\frac{P(O \cap X \cap \lambda)}{P(\lambda)}[/itex]
[itex]P(O, X|\lambda) = P(O | X, \lambda) * P(X|\lambda) [/itex]
[itex]P(O | \lambda) = \sum\limits_{X} P(O,X|\lambda)[/itex]
[itex]P(O | \lambda) = \sum\limits_{X} P(O | X, \lambda) * P(X|\lambda)[/itex]
My question is: Why do I get the likelihood of the oberserved sequence
by summing up over all all possible state sequences. Can someone please
explain it differently?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Jan3-13, 11:59 AM   #2
Recognitions:
Quote by SamTaylor View Post
You could start by thinking of a simpler situation. Think of the Venn diagram approach to probability spaces. You have the whole space of outcomes ("points') S, which is a big circle. Inside S, there is an event ( as set of points) defined by a smaller circle A. Create another set of events that partitions S into the subsets s1,s2,....,sN. ( You can imagine drawing an irregular grid on S and letting s1,s2,.. be the "squares" of the grid.)
[itex] P(A) = \sum_{i=1}^N P(A \cap s_i) = \sum_{i=1}^N p(A | s_i) p(s_i) [/itex]
The inconvenient thing about reading applied probability is understanding what spaces of outcomes are being discussed. Authors often don't make this clear. Usually several different spaces of outcomes are involved. Conditional probabilites in a given article refer to events in a different probability space than unconditional probabilities. In the above example, the probablity [itex] p(A | s_i) [/itex] is the probability of a set of outcomes, and this set contains the same outcomes ("points") as the set [itex] A \cap s_i [/itex] but we are considering this set of outcomes to be in a different probability space. The "whole space" for [itex] P(A | s_i) [/itex] is the set [itex] s_i [/itex] instead of [itex] S [/itex].
My guess about the article you linked is that you should think of the whole space of outcomes as all possible sequences of information that tell both the sequence of states of the Markov process and the sequence of observations. So a "point" in the whole space is a sequence (i.e. a vector) with both kinds of information. When you draw a circle A that represents a particular sequence of observations, it contains more than one point, because it contains all the vectors that agree with the sequence of observations and have otherwise arbitrary sequences of states of the Markov process.
Jan10-13, 09:15 AM   #3
That’s how I thought about it as well. I tried to think about it like
in total probability. When you look at the picture above you can
see the events [itex]S_n[/itex] which compose the universal set.
Like you said one can define a smaller set [itex]A[/itex] which comprises
outcomes in some or all of the events [itex]S_1[/itex] through [itex]S_n[/itex]
If the events [itex]S_i[/itex] are mutually exclusive and dont have outcomes
in common then [itex]S_i \cap A[/itex] have none in common you get:
[itex]Pr(S_i \cap A) + Pr(S_2 \cap A) + \cdots + Pr(S_n \cap A) = Pr(A)[/itex]
I tried to connect this with the formula for the likelihood. I hoped that
this would explain me why adding up over all x would result in [itex]P(O|\lambda)[/itex]
But as you mentioned above one single event represents here a sequence
rather than a single point. In the example with the total probability all events
compose the universal set which result in 1 .
Since [itex]Pr(S_1) + Pr(S_2) + \cdots + Pr(S_n) = 1[/itex].
So in return it makes sense that Pr(S) get eliminated.
But I can't associate this with the formula [itex]P(O|λ)=∑XP(O|X,λ)∗P(X|λ)[/itex]
since there are multiple dependencies
Jan10-13, 12:18 PM   #4
Recognitions:
I don't understand what you mean by multiple dependencies. Since all the terms in expressiong have the "[itex] | \lambda[/itex]" in them we can say that we are in the probability space defined by the subset [itex] \lambda [/itex] and , with that understanding, leave out the [itex] | \lambda [/itex] from the formula.
As I see the space, a point (an "outcome") in the space looks like [itex] (o_1,o_2,o_3,...,o_T, x_1,x_2,...,x_T) [/itex] where the [itex] o_i [/itex] give a sequence of observations and the [itex] x_i [/itex] give a sequence of states.
Asking for the probabiliy of an event [itex] O [/itex] asks for the probability of the set of outcomes which have the form [itex] (o_1,o_2,...,o_T, *,*,...)[/itex] where the [itex] o_i [/itex] are the particular observations that define the event [itex] O [/itex] and the '*' are any sequence of states. So it seems natural to me that you sum over all possible sequences of states.
Jan21-13, 02:12 PM   #5
Ok, that way its pretty clear to me. I dont know why it didnt come to my mind that way right away. However the [itex] \lambda [/itex] is still a bit confusion to me in the derivation. Looking at the quote above one could have written down the formular right away with out the derivation.
New Reply
Thread Tools
Similar Threads for: Hidden Markov Models - Likelihood of ...
Thread Forum Replies
Statistical models and likelihood functions Calculus & Beyond Homework 3
Using Hidden Markov Model Set Theory, Logic, Probability, Statistics 0
derivation of bayesian inference in Hidden Markov model Set Theory, Logic, Probability, Statistics 19
Hidden Markov Modeling and Background needed for Dynamical Systems Set Theory, Logic, Probability, Statistics 3
