PSU Power and Heat: Understanding the Relationship
  • Thread starter Thread starter TSN79
    Heater
The discussion revolves around the relationship between power supply units (PSUs) and heat generation, particularly in the context of computer systems. Participants explore how much of the power consumed by a PSU translates into heat, the efficiency of PSUs, and the implications for energy usage in home environments.
  • Some participants propose that an 800W PSU running at full power generates heat comparable to an 800W heater, while others suggest that only a portion of that power is converted into heat, depending on efficiency.
  • One participant mentions that a PSU rated at 800W might actually produce around 270W of heat at 75% efficiency, with the rest of the power being used by the computer.
  • There are discussions about measuring actual power consumption using devices like the "Kill A Watt" monitor, which can provide insights into how much power various appliances consume.
  • Several participants share their experiences with power consumption measurements from their own setups, noting significant wattage and heat generation, especially during high-demand activities like gaming.
  • One participant humorously notes that their setup, which draws between 3-4 kW, effectively acts as a heater, highlighting the seasonal challenges of managing heat output.
  • Another participant clarifies that a PSU's rating indicates its maximum output capacity, not necessarily its constant power draw, which is typically lower during normal usage.
Participants express varying views on the efficiency of PSUs and the exact relationship between power consumption and heat generation. There is no consensus on how much of the power translates into heat, and discussions reflect differing experiences and interpretations of PSU performance.
Some limitations include assumptions about efficiency ratings, variations in actual power draw based on system demand, and the potential for different interpretations of how heat is generated and dissipated in computer systems.
TSN79
If my PSU is 800W and it runs at full power, does that equal a 800W heater standing in my room, or does just some of it turn into heat?
Computer science news on Phys.org
Is your power supply nearly as hot as a toaster?
Computer power supplies are tricky in that I don't think they are very accurately rated, but if it were accurately rated at 800W and were running at full power, it would generate probably 270W of heat (at about 75% efficiency) and whatever it was powering would generate 800W of heat.
There are little gadgets that you plug into the wall and then plug you appliance into the gadget. It then displays how many watts are actually being used. The "Kill A Watt electricity usage monitor" is one of those. Someone at the local public library got the idea of buying a few of those and making them available for checkout. Since the average person probably only needs one of these for a couple of hours that spreads out the cost of purchase over many many users. Perhaps you could coax your library to do the same.
I was a little surprised when I went around the house measuring power consumption of each of the appliances, computers, monitors, routers, cable boxes, modems, etc.
Almost all the watts going into the computer turn into electromagnetic radiation, heat, rf, light, they just vary in wavelength. If the power supply is less efficient then more of the watts turn into long wavelength infrared (heat) inside the power supply and less of the electricity is passed to the computer itself before being turned into heat.
I suppose the only exception might be the fans turning electricity into moving air rather than directly into heat. If you have a UPS or other rechargeable batteries then there can be a small amount of electricity temporarily turned into chemical energy before then being turned into heat when you use the battery power.
I have one. When plugged into my computer, which is relatively advanced, has a lot of hard drives and a 500W PSU it gave me:
140W during boot
120W when idle in windows
190W during a game w/3d graphics.
140W during boot
I have one too. I melted it a bit running too many watts through it... lol
This is what I was measuring though,
Lots and lots of watts so of course lots and lots of heat. The whole setup is between 3-4 kW IIRC. So basically its a 3.5 kW heater. Great in the winter, tough to keep under control in the summer.
Wow. Other than a heater what are you using that for?
$$$$ (mining bitcoins) Its been real profitable so far, I have very cheap electricity. The market is changing though and I will be selling it off soon.
Sounds like a neighbor hasnt yet noticed the extension cord running from his outdoor power outlet.
All the energy IS dissipated eventually as heat in the room, yes. Some from the power supply itself. The rest from the computer it is powering.
Heh, no... The setup uses 4 separate circuits.
I did read an article about an IT guy/gal at a community college who set up the computers in the computing commons to all mine bitcoins. He/she was caught when the electric bill came in.
Keep in mind that a PSU rated at 800W simply means that it can supply up to 800W if the components of the computer demand it. It doesn't mean that it will be pulling 800W all the time. It would be extremely uncommon for a modern system to pull more than about 100-150W during normal usage, perhaps up to a few hundred watts under heavy usage.
  • · Replies 25 ·
15K
  • · Replies 66 ·
9K
