Can I Connect a Garden Hose to a Round Bath Tube Spike?
  • Thread starter Thread starter biferi
    Water
The discussion revolves around the feasibility of connecting a garden hose to a round bath tube spike, particularly in the context of filling or draining a water bed. Participants explore various methods and tools related to this connection, including adapters and alternative attachment points.
  • One participant inquires about connecting a garden hose to a round bath tube spike, seeking clarification on the method.
  • Another suggests that attaching the hose to a shower head might be a possible solution.
  • A participant mentions that water beds typically come with adapters for connecting hoses to sinks, emphasizing the need for specific adapters for different faucet types.
  • Another contributor shares their experience with water beds, noting that adapters are generally required for both ends of the garden hose, depending on the faucet type.
  • One participant speculates that the T connector mentioned might be an aspirator, which is used for draining the water bed, and clarifies that it cannot be used for filling the bed.
Participants express varying opinions on the methods available for connecting the garden hose, with no consensus reached on the best approach or the necessity of specific adapters.
Participants reference the need for adapters and the potential for different faucet types to affect the connection process, but do not resolve the specifics of these requirements.
biferi
I have a water bed and I have a t connector that let's me connect a garden hose to my bathroom sink.
But I wanted to know if there is a w any to connect my garden hose to my bath tube spike?
The bath tube spike is round and about 2 inch round.
If I am not asking in the right way please let me know?
you might be able to attach your hose to the shower head if you have one.
I don't know where you live, but in the US when you buy a water bed, it generally comes with adapters. One adapter let's you attach a hose to the water bed to fill it, and the other adapter let's you connect the other end of the hose to a sink faucet. Typically, you have to unscrew the aerator from a kitchen or bathroom sink faucet, so you can thread that adapter on. I hope this helps. Good luck.
i have a waterbed and had it for better than 2 decades.
there are little plastic adapters for both ends of the garden hose. if you attach the garden hose to a standard faucet outside or a similar faucet inside (usually in a utility room), you won't need the adapter on that end. but for a typical kitchen sink faucet or spigot you do.
the adapter for the bed end of the hose is generally always needed, whether you're filling or draining.
if you don't have these adapters, go back to the store where you bought the waterbed. if you obtained it directly from an owner/user, and that person has lost the adapters, i don't know where to find them. i guess check out the web. if you know another waterbed owner, maybe you can ask to borrow the hose adapters. they will want the adapters back, for sure.
You mentioned that the object you have looks like a T connector. I think you may have the aspirator. This is a device that let's you drain the waterbed. It actually uses the force or running water to pump the water out of the bed. If it's the aspirator, one of it's legs will have no threads on it and should have some sort of hood over the thing to disperse the water when draining. You can't use the aspirator to fill the waterbed.
https://www.sciencemadness.org/whisper/viewthread.php?tid=8666
  • · Replies 40 ·
  • · Replies 32 ·
14K
  • · Replies 26 ·
  • · Replies 39 ·
17K
