How to create a eletromagnetic field with frequency?
by mitocondrio
Tags: eletromagnetic, field, frequency, radio
mitocondrio
mitocondrio is offline
#1
Feb6-13, 09:19 AM
P: 8
Let's say I wanna create an eletromagnetic field with a 13.56Mhz frequency... How do I proceed it with a circuit? I don't need a large explanation, but please tell me how do I learn about it. Thanks :)
Phys.Org News Partner Physics news on Phys.org
Physicists design quantum switches which can be activated by single photons
'Dressed' laser aimed at clouds may be key to inducing rain, lightning
Higher-order nonlinear optical processes observed using the SACLA X-ray free-electron laser
berkeman
berkeman is offline
#2
Feb6-13, 10:39 AM
Mentor
berkeman's Avatar
P: 39,628
Quote Quote by mitocondrio View Post
What is the overall goal? What do you want to do with this EM radiation?
mitocondrio
#3
Feb6-13, 11:01 AM
P: 8
I want to do some RFID emulation, but I would like to learn how to create this frequency. I already learned the modulation part. I want to learn by parts. I will thank you so much if you can help me!
berkeman
berkeman is offline
#4
Feb6-13, 11:05 AM
Mentor
berkeman's Avatar
P: 39,628
What country are you in? What government agency controls the RF spectrum there? How much power are you allowed to transmit in that band, and what are the regulations on harmonics of the fundamental transmit frequency?
Is this a school project? Or for work or for a personal project?
mitocondrio
#5
Feb6-13, 11:23 AM
P: 8
I'm studying RFIDs and how they work. I would try to do an RFID emulator just to learn better how things work. It's nothing under the government specifications, I will just use this to emulate an RFID tag for like 10 centimeters away form the reader. The tags I want to emulate uses the 13.56Mhz frequency, wich is the frequency I wanted to create with a coil.
Thanks!
berkeman
berkeman is offline
#6
Feb6-13, 11:28 AM
Mentor
berkeman's Avatar
P: 39,628
Thanks!
The issue is that any time you transmit RF signals, you are interacting with other receivers in your area. So if you make a bad transmitter, or transmit too much power, you can cause harmful interference with other radio receivers, which is a bad thing.
The easiest way for you to do this is to use a signal generator that can go up to your frequency. Do you have access to signal generators and oscilloscopes?
mitocondrio
#7
Feb6-13, 12:22 PM
P: 8
I don;t have an osciloscope, I would like to know how to build a circuit that can generate the signal. Could you help me? Thank you :)
Khashishi
Khashishi is offline
#8
Feb6-13, 01:20 PM
P: 832
Search google for "rf oscillator" and you get a bunch of links. For example,
www.sm0vpo.com/blocks/osc7m00.htm
There's the circuit right there. Then you just need to attach some kind of antenna.
sophiecentaur
sophiecentaur is offline
#9
Feb7-13, 12:56 PM
Sci Advisor
PF Gold
sophiecentaur's Avatar
P: 11,353
I assume that you have very little experience of electronics and virtually no test equipment. If this is the case then I suggest that you are heading for failure if you leap into this project so ill equipped. How would you know your circuit was working once you turned it on?
ZapperZ
ZapperZ is offline
#10
Feb7-13, 01:09 PM
Mentor
ZapperZ's Avatar
P: 28,801
Silly question. If you don't have any ability to measure the signal generated, how in the world are you going to know you've generated such a signal?
{scratching head}
It appears that from reading this thread, you haven't thought of things through enough.
Zz.
Register to reply
Related Discussions
How did Tesla create such high frequency currents? General Physics 3
Does a straight non-time-dependent E field create a circular B field? Classical Physics 4
Materials and Eletromagnetic Waves General Physics 3
Digital Fourier Transform - create frequency axis Calculus & Beyond Homework 0
Finding a frequency to create a given amplitude in a spring Introductory Physics Homework 11
