Can Vector Units Be Simplified or Must Each Element Carry Units?
  • Context: Graduate
  • Thread starter Thread starter sandy.bridge
    Vectors
The discussion centers on whether vector units can be simplified by placing the unit outside the vector or if each element within the vector must carry its own unit. Participants explore this question in the context of notation and clarity in representing physical quantities.
  • One participant questions if units can be placed outside a vector, providing examples to illustrate the point.
  • Another participant argues for clarity, suggesting that units should be included with each component of the vector to avoid confusion.
  • There is a discussion about the differences in notation using various delimiters such as (, [, or <, with some participants providing their interpretations of these symbols.
  • Some participants reference external sources, such as the NIST publication and the International Vocabulary of Metrology, to support their views on unit representation in vectors.
  • One participant expresses skepticism about placing units outside the vector, despite acknowledging the existence of preferred methods in certain documents.
  • Another participant notes that the use of semicolons instead of commas is suggested in some contexts for clarity in listing vector components.
Participants express differing opinions on whether units should be placed outside of vectors or included with each component. There is no consensus reached, and multiple viewpoints remain active in the discussion.
Some participants reference specific standards and guidelines, but the applicability of these standards to the discussion remains unresolved. The conversation also highlights varying interpretations of notation conventions among different fields.
sandy.bridge
If I have a vector defining numerous quantities of the same units, can I merely place the units outside of the vector, or is it required to have units on every entity within the vector?
For example,
[tex](A, B, C)=(ae^{j\phi_1}, be^{j\phi_2}, ce^{j\phi_3}) H[/tex]
or
[tex](A, B, C)=(ae^{j\phi_1} H, be^{j\phi_2} H, ce^{j\phi_3} H)[/tex]
My two cents is for clarity place the units of measure inside. Its not a factor.
For example, a position vector r=<1.0m,2.0m,3.0m> is much clearer than <1.0,2.0,3.0> m as someone might think its some undefined constant.
Perfect. Since we are on the topic: in regards to notation, is there a difference between using (, [, or <?
I can't answer for mathematicians but ( ) are usually for expressions, <> for vectors and [ ] intervals.
But I did find this:
http://en.wikipedia.org/wiki/List_of_mathematical_symbols
which may answer your questions.
NemoReally said:
You can place the unit outside of the delimiter - see, for example, http://physics.nist.gov/Pubs/SP811/sec07.html section 7.7 (I believe the SP811 follows the ISO 31000 series in this respect)
Nice article, I would still question this for a vector although I did see a list of values in parens with the uom at the end as the preferred list method.
International vocabulary of metrology – Basic and general concepts and associated terms (VIM)
3rd edition
http://www.bipm.org/utils/common/documents/jcgm/JCGM_200_2012.pdf
1 Quantities and units
1.1 (1.1)
quantity
property of a phenomenon, body, or substance, where the property has a magnitude that can be expressed as a number and a reference
NOTE 5 A quantity as defined here is a scalar. However, a vector or a tensor, the components of which are quantities, is also considered to be a quantity.
1.19 (1.18)
quantity value
value of a quantity
value
number and reference together expressing magnitude of a quantity
NOTE 4 In the case of vector or tensor quantities, each component has a quantity value.
EXAMPLE Force acting on a given particle, e.g. in Cartesian components (Fx; Fy; Fz) = (-31.5; 43.2; 17.0) N.
... if it's good enough for the BIPM and ISO, it's good enough for me. :smile:
3rd edition
1.1 (1.1)
quantity
1.19 (1.18)
quantity value
value of a quantity
value
Yup, that nails it. Good to know. Thanks.
Also they suggest using ; instead of ,
Speaking for mathematicians, the real problem is that points are represented, in a Cartesian coordinate system, as (x, y, z), writing vectors as <a, b, c> is less confusing that using (a, b, c).
  • · Replies 17 ·
  • · Replies 18 ·
  • · Replies 146 ·
12K
  • · Replies 0 ·
