New Reply
Efficient way to find which element of Z*n has largest order?
Share Thread
Feb13-13, 07:26 AM   #1
Hey, I had two separate questions. (When I say Z*(n) I'm denoting the multiplicative group of integers mod n, namely, the units of Z(n))
First off, I know that if n is prime, that Z*(n) is cyclic. But this is not a biconditional statement. Is there any theorem which tells me conditions under which Z*(n) is not cyclic? I can't just say n is not prime so Z*(n) is not cyclic. Right?
Second question - if I know that Z*(n) is cyclic, then I know it has a generator. But other than going through each and every element and multiplying them out, is there an efficient way to find out which elements are generators? Also, in the case that Z*(n) isn't cyclic (like say Z*(12)) is there a way to find which element has the highest order?
If anyone can point me to the proper theorems, I would be extremely grateful!
PhysOrg.com science news on PhysOrg.com
>> New language discovery reveals linguistic insights
>> US official: Solar plane to help ground energy use (Update)
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
Feb13-13, 12:16 PM   #2
Math 2012
Recognitions:
Start by thinking about the case where n = pq where p and q are both prime. (For example, n = 6)
When you see what is going on, generailze it to the case where n has more than two prime factors.
Feb13-13, 03:36 PM   #3
Recognitions:
Homework Helper Homework Help
Aleph Zero makes a good suggestion. It is not so trivial in general however, when there are repeated factors. There is a discussion starting on p. 48. of these notes, of when the group is cyclic:
http://www.math.uga.edu/%7Eroy/844-2.pdf
In fact your question as to precisely how to identify generators is perhaps even less trivial. There may even be some open questions surrounding that matter, as I recall.
Feb13-13, 06:57 PM   #4
Thank you guys for the links and the responses!
I also found this:
"Zn*, the multiplicative group modulo n, is cyclic if and only if n is 1 or 2 or 4 or pk or 2pk for an odd prime number p and k ≥ 1."
But I did not see a proof provided for it. I think this might tie in with what you were saying AlephZero
Feb13-13, 10:25 PM   #5
Recognitions:
if you look at the links i provided you will find complete proofs of these facts.
Feb13-13, 11:27 PM   #6
Yeah I have spent the last couple hours looking at the doc you provided and some other documents I've hunted down. Very helpful! I need to purchase a good number theory text book to have on hand it seems! Thank you again!
New Reply
Similar discussions for: Efficient way to find which element of Z*n has largest order?
Thread Forum Replies
An efficient way to find perfect squares? Linear & Abstract Algebra 15
A group of order 6 that has no element of order 6 is isomorphic to S_3 Calculus & Beyond Homework 4
Group of order 100 with no element of order 4? Calculus & Beyond Homework 3
find the largest mass that can sit on an incline without accelerating Introductory Physics Homework 1
A group of order 2n conatins an element of order 2 Calculus & Beyond Homework 11
