New Reply
Calculation Based on Yield strength and Ultimate strength
Share Thread Thread Tools
Feb22-13, 03:21 AM   #1
Hello Gurus,
I am new to mechanical design calculations.
Since I have came across one interesting fact there are two methods using for finding the shear capacity of the components. Yield Strength and Ultimate strength.
Shear yeild strength=1/√3* Yield strength
Ultimate shear strength= .75 of of Ultimate strength
Up on these shear capcacity calculations are made.
What is the signficance of the using two methods for the design calculations? Either one is enough?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Feb22-13, 02:35 PM   #2
The first is (the limit of) elastic behaviour and helps you decide what to do at working loads. But it says nothing about safety. The second tells you about safety but nothing about working load behaviour.
Feb25-13, 12:40 AM   #3
Pongo,
Thanks for the reply.
can you be little elaborate?
I assumed that mutliplying the yield and ultimate strength with 0.577 and 0.75 respectively are matters of saftey.
I also believed that considering yield strength is for safty purpose, as it never consider plastic region in the calculation part.
Regards
S~
Feb25-13, 04:44 PM   #4
Quote by shinoysivan View Post
Pongo,
Regards
S~
See my post in this thread: http://www.physicsforums.com/showthread.php?t=521969
The .577 is not a safety factor.
The .75 on the other hand, is probably a safety factor.
Feb25-13, 06:48 PM   #5
Shear yield strength:
At the onset of yielding, the magnitude of the shear stress in pure shear is 3^0.5 times lower than the tensile stress in the case of simple tension.
When something fails in yielding, the result is plastic deformation of the part.
New Reply
Tags
design calculation, mechanical design, methodology, shear strength
Thread Tools
Similar Threads for: Calculation Based on Yield strength and Ultimate strength
Thread Forum Replies
Need Help with Yield Strength for FEA Engineering Systems & Design 3
Ultimate Tensile Strength Engineering, Comp Sci, & Technology Homework 5
Ultimate strength Introductory Physics Homework 1
Yield strength Materials & Chemical Engineering 2
Yield strength Materials & Chemical Engineering 8
