New Reply
Integration question again
Share Thread Thread Tools
Feb23-13, 11:02 AM   #1
1. The problem statement, all variables and given/known data
A goldfish bowl is a glass sphere of inside diameter 20cm. Calculate the volume of water it contains when the maximum depth is 18cm.
The attempt at a solution
I don't really have an idea of how to attempt this, all I did so far was a draw a little sketch of the bowl and put in the dimensions
Hmm.. should I just find the volume of the sphere, sketch the cross-section of it, and then try to use the principles of solids of revolution to find the volume?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Feb23-13, 11:26 AM   #2
Recognitions:
Homework Helper Homework Help
Quote by lionely View Post
Consider the vertical cross-section of the bowl. Let the centre of the bowl be the origin (0,0). y-coordinates range from -10 to +8.
Now consider the horizontal circular cross section of a disc of water taken at a certain y-coordinate. Find its radius via Pythagoras theorem, and hence its area.
Hence figure out the volume of an infinitesimally small cylinder having that cross-section and a vertical height dy.
Now do the integration, imposing the correct bounds for y.
Feb23-13, 11:39 AM   #3
Umm wouldn't the radius be 10cm, because the diameter of the bowl is 20cm?
Cause maybe I drew my diagram badly I'm not seeing how I can use Pythagoras ' theorem.
:S
Feb24-13, 12:00 AM   #4
Recognitions:
:S
Right through the centre (at y = 0), yes the radius of the cross-section would be 10cm.
But what about other y values. Hint: think of a right triangle, the hypotenuse being the constant radius of the bowl (10cm), the vertical height being y and the horizontal base being the radius of the cross-section.
Feb24-13, 11:23 AM   #5
Is the radius 6cm?
Feb25-13, 12:40 AM   #6
Recognitions:
Is the radius 6cm?
Huh? The radius of the horizontal cross-section varies continuously depending on the level you're taking it at.
Did you make a proper sketch?
Feb25-13, 06:22 PM   #7
Hm... Maybe I didn't on my diagram 10 is the hypotenuse and 8 is the perpendicular height.
Feb26-13, 03:48 AM   #8
Recognitions:
10cm is always the hypotenuse.
y varies from -10 (bottom) to +8 (top of water level). Do you understand this?
8cm is only the height when you're considering the area of the top surface of the water (y = 8). At that point, the radius is ##\sqrt{10^2 - 8^2} = 6cm##. Agree?
At the bottom of the bowl (y = -10), the radius is zero, because the bottom is just a point, not a circle. Agree?
The radius of the cross-section right through the level of y = 0 (center of the sphere) is 10cm (simply the radius of the sphere). Agree?
Now you can take the cross section of water at *any* water level between the bottom and the top, not just those "special" levels. Your job is to find an expression, in terms of y, for the radius of this cross-section. Can you do this?
Remember, what you get will be in terms of y - it'll have a y in the expression, not just a number.
New Reply
Thread Tools
Similar Threads for: Integration question again
Thread Forum Replies
Integration question Calculus 0
Integration question Calculus 1
Integration question Calculus 4
Question arrising from integration homework (advanced integration i guess?) Calculus 9
Integration Question General Math 3
