Thread Closed
A delayed choice experiment with a paradox. What did I do wrong?
Share Thread Thread Tools
Feb19-05, 09:37 PM   #1
Mentor
Some time ago I read some stuff about delayed choice and quantum eraser experiments, but rather than reading the articles thorouhgly, I just glanced at them quickly, picked up a few ideas, and then tried to design a gedanken experiment of my own. Now I seem to have run into a bit of a problem. My gedanken experiment seems to either contain a paradox or violate the principles of quantum mechanics. I'm sure I'm making some sort of mistake, but so far I haven't been able to find it. Perhaps someone here can can help me figure this out.
Look at the attached drawing. A "down converter" is a crystal that that emits two photons, each with half the energy of the original, when it's hit with just one. According to what I read, such crystals actually exist. I imagine that it would be difficult, if not practically impossible to build a down converter that always emits the two photons in the directions I've drawn in the picture, but I don't think it's impossible in principle.
Imagine that we have carefully adjusted the lengths of the paths in this experiment so that the lower right detector never clicks, because of destructive interference. All the photons that reach the half-silvered mirror below the detectors will go to the left detector.
If we imagine the same setup, but without the half-silvered mirror at the upper right, there wouldn't be any interference at the lower detectors. They would both detect the same number of photons. This is because the upper detectors would give us "which-way information" about the original photon. For example, the detector at the top of the picture will only click if the original photon was reflected at the first half-silvered mirror.
The purpose of the half-silvered mirror at the upper right (and the mirrors at the upper left and lower right), is to eliminate the possibility to obtain which-way information that would destroy the interference. There's no way, even in principle, to determine if a photon that's been detected by one of the detectors at the upper right went through the last half-silvered mirror or was reflected by it.
Let's move on to the paradox. Suppose that we sometimes remove the half-silvered mirror at the upper right, after one of the lower detectors has clicked. This will make it possible to determine which way the original photon went at the first half-silvered mirror, and this should destroy the interference at the lower two detectors. If the interference really is destroyed, then the lower right detector should detect a photon 50% of the times we do this (instead of 0%).
This is retro-causation. The effect precedes the cause. The detector will click because someone at a later time removed a half-silvered mirror. If that isn't strange enough, suppose that we immediately after the lower right detector has detected a photon decide not to remove the half-silvered mirror. Then we have a paradox. If we never remove the half-silvered mirror, that detector should never click.
Maybe it's just impossible to destroy the interference by removing the half-silvered mirror after one of the lower detectors has already clicked. But in that case, we can obtain which-way information about the original photon and still get interference. Doesn't this violate the principles of quantum mechanics?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Feb20-05, 10:45 AM   #2
Mentor
I had to shrink the image to upload it. That made it rather unpleasant to look at. If you'd like to see a version of that picture that's a bit easier on the eyes, you can use this link.
Feb20-05, 10:47 PM   #3
I spent a little time today trying to get my head around this. I need to spend some more.
Feb21-05, 03:30 AM   #4
Hello Fredrik,
I tried to follow your gedanken-experiment. It would be nice if you could give
a link to the article you read, so we'd have background knowledge and understand your idea better.
Quote by Fredrik
I don't agree with this part. Even if you remove the H-mirror (right top)
and know which way the photon took at the first H-mirror, then, in my opinion, you would still get interference at the middle detectors.
For example:
Suppose we have no H-mirror (right top) and detect a photon at the right top
detector. This means: We know the photon was NOT reflected at the first H-mirror, but it went through it.
So, the photon goes straight through the first H-mirror, is downconverted,
and then is incident on the H-mirror in the center. Because this mirror in the center is half-silvered, you don't know which way it takes (in the center) and hence still get interference.
I think what you are considering has something to do with two-photon-interference, where you look if there's COINCIDENCE between the detectors in the center and on the top. Polarization plays a role there.
http://www.bu.edu/qil/pdf/PRL-09-02-96.pdf
Feb21-05, 06:15 AM   #5
Mentor
Quote by Edgardo
Unfortunately I don't remember where I got most of the ideas. I know it started with an article by a guy named Ulrich Mohrhoff that I read about a year ago... I will do some googling when i get home today and see if I can find the articles I've read about similar experiments.
Quote by Edgardo
For example:
I wouldn't call that interference. The interference I'm talking about will cause the left detector to click 100% of the time and the right detector to click 0% of the time (assuming that the path lengths have been carefully adjusted to make sure that happens). When things happen the way you describe, the left detector will click 50% of the time and the right 50% of the time. This happens because there's no interference between two different ways that a photon might reach the right detector (or the left detector).
Note that after the first half-silvered mirror, every line drawn in the diagram represents a photon that's in a superposition of existence and non-existence. In the language that's often used in discussions about similar experiments, each line represents a "half" photon. The interference I'm talking about is interference between two "halves" that have the last part of their paths to the detector in common. If we know that the original photon went through the first half-silvered mirror, then there was never any "half" photons around that could interfere with each other.
Quote by Edgardo
Thank you for your comments. I haven't had time to read that article yet. I will check it out later today.
Feb21-05, 06:16 AM   #6
Mentor
Quote by caribou
I appreciate comments like this too. It's good to know that someone is at least reading my post and thinking about it. Some people might choose not to read it, because it's rather long, but they don't know what they're missing. I believe that anyone who is even slightly interested in quantum mechanics will find this experiment very interesting.
Feb21-05, 07:33 AM   #7
Quote by Fredrik
I wouldn't call that interference. The interference I'm talking about will cause the left detector to click 100% of the time and the right detector to click 0% of the time (assuming that the path lengths have been carefully adjusted to make sure that happens). When things happen the way you describe, the left detector will click 50% of the time and the right 50% of the time. This happens because there's no interference between two different ways that a photon might reach the right detector (or the left detctor).
You're absolutely right. I wrote some bs there. I don't know how I got to that idea. The situation with 100% to click and 0% is the same as in the Mach-Zehnder-Interferometer http://www.upscale.utoronto.ca/Gener...chZehnder.html
I have to admit that I've understood for the first time, why this 100% and 0% situation occurs, the site above really gives a good explanation.
I have to think about your gedankenexperiment.
Feb21-05, 08:05 AM   #8
Quote by Fredrik
Ok, I think I fully understood your paradox. My thought:
If you don't remove the H-mirror in the right top, only detector 1
in the center will click due to interference (like in the Mach-Zehnder-interferometer). I don't think that you can destroy
the interference afterwards. I can't imagine how that would look like.
So I agree with your comment:
Quote by Fredrik
But on the other hand:
Quote by Fredrik
That is a good question. I'd say let the Gedankenexperiment become real
and test it in the lab.
Feb21-05, 08:17 AM   #9
I think for the detectors in the right top the probabilities
should also be 100% and 0%, because the outer mirrors also
represent a Mach-Zehnder interferometer.
I just noticed that your experimental setup
consists of two Mach-Zehnders, an inner and an outer interferometer.
Feb21-05, 09:30 AM   #10
Mentor
Quote by Edgardo
I think for the detectors in the right top the probabilities should also be 100% and 0%
We can choose those percentages to be whatever we want them to be, simply by making the right path a little bit longer than the left path.
Feb21-05, 09:36 AM   #11
It's an interesting addition to the experiments to have as Edgardo says, and I also noticed, essentially two interferometers in inner and outer loops.
I've been drawing the experiment as a superposition of two alternative histories which interfere.
After the first H mirror, one of my drawings is the history which follows the path of photon up and then the paths of the two photons created this way, while the other drawing is the history which follows path of the photon right and then the paths of the two photons created that way.
I'm imagining the drawings as then interfering and seeing if that gives me some clues.
I'd guess the photon goes around the inner loop by two paths in superposition has inteference effects with itself whatever else happens.
What is happening to the photon in the outer loop is what I'm wondering now.
Feb21-05, 10:30 PM   #12
Recognitions:
Fredrik-- the quote below greatly puzzles me.
My instinct is to say "higher detectors" should replace "lower detectors" in the first sentence, there's a typo in other words.
But, perhaps not. In which case note that you have a 'sort-of" standard interferometer with the lower detectors. That is to say, interference will be alive and well at the lower detectors no matter the state of the upper apparatus. This is certainly true for classical E&M, and for QM as well. the Basic idea can be shown by looking at thr quantum fields at the measurement points. Both classical and quantum fields share the same spatial form. So at Lower Detector 1 (left), or LD1, have for 2 photons, with momentum k, a wave function (poor nomenclature)
EXP (-k{x11 + x21}) where x11 and x21 are the photon coordinates at LD1, fully symmetric in the two photons. Interference is demonstrated by varying x11 + x21. If the sum is pi/2 there is full destructive interference, and so on. Two channels feeding a detector guarantees interference. After the fact causality? I don't think so.
Regards,
Reilly Atkinson
Feb22-05, 01:58 AM   #13
Mentor
Quote by reilly
Nope, that's not a typo. It's rather obvious that there will be no interference between "half" photons at the upper detectors without the half-silvered mirror at the upper right, but that's not the point. The point is that if that mirror is gone, the detector at the top of the picture can only click if the orignal photon was reflected by the half-silvered mirror near the bottom of the picture. If the original photon is reflected there, rather than going into a superposition of being reflected and passing through, then there can't be any interference at the lower detectors.
Quote by reilly
I'm not against the idea of "after the fact causality", but in this case it seems to lead to a paradox, and I'm against paradoxes.
Feb23-05, 03:31 PM   #14
Hello Fredrik,
I've read about quantum erasers. And read these websites:
http://www.lns.cornell.edu/spr/1999-03/msg0015208.html
and especialy this one:
http://grad.physics.sunysb.edu/~amarch/
It mentions, that the which way information is erased AFTER it made click. (at least that's how I understood it) In your gedankenexperiment I now think that the interference is destroyed, that is you don't get any interference although you take away the mirror AFTER it made click (at the center-detectors). However, that's my first thought after having read about these quantum erasure experiments.
I will let you know, if I get any new insight into this.
Regards
Edgardo
P.S. Check out this program about quantum erasure.
http://www.physik.uni-muenchen.de/di...interfere.html
Note that you can rotate the polarizers, which I at first didn't get.
Feb23-05, 06:40 PM   #15
Talking of erasing the past, in Roland Omnes's Understanding Quantum Theory, he mentions the ideal von Neumann experiment.
A particle is emitted and can go down one of two channels. There is a detector in one channel. If, after a certain time, the particle is detected then you know it went along the channel with the detector and if the particle is not detected then you know it went along the channel without the detector.
So far, so simple.
Now here comes the interesting part as, if you arrange it so that the two channels curve and later join up into the same direction, then when the particle reaches the point at which the channels join up then the detector result will go from "detected" or "not detected" into a superposition and "don't know" Schrodinger Cat state even if the particle is now a huge distance away from the detector!
It's EPR and Schrodinger's Cat in one simple, fun package.
Decoherence keeps this lunacy from happening in the real world, thankfully.
Feb24-05, 02:10 AM   #16
Mentor
Quote by caribou
So far, so simple.
This doesn't seem correct to me. The detector should go into a superposition of "detection" and "non-detection" even if you don't join the channels.
Feb24-05, 04:33 AM   #17
This thought experiment has captured my interest, and I have been thinking about it for some days now. I do not know much about "quantum erasure" and ((S)P)DCs, and so I have only been able to take the setup at face value on the basis of heuristic considerations.
The following "rule" appears to remove all elements of inconsistency:
Interference effects will occur in the signal only if the 'decision' to erase the "which-way" information occurs a spacetime event which lies in the causal past of the signal detection event.
If one would like to argue that this "rule" does not apply, namely that interference effects in the signal exist even when
(i) the 'decision' to erase and signal detection are spacelike separated
or, much more drastically,
(ii) the 'decision' to erase lies in the causal future of signal detection ,
then, in case (i) we can arrange for faster-than-light signaling, and in case (ii) we can arrange (with some abuse of the term 'decision') for an action performed now to 'undo' an event which has already taken place (... whatever that could mean).
I think that this "rule" and the ramifications of its violation for cases (i) and (ii) above apply quite generally to all erasure-type scenarios, and not just to the thought experiment at hand.
Thread Closed
Thread Tools
Similar Threads for: A delayed choice experiment with a paradox. What did I do wrong?
Thread Forum Replies
Wheeler's delayed choice gedanken experiment Quantum Physics 6
Really delayed choice quantum eraser Quantum Physics 2
Delayed Choice exp and Cause-Effect Quantum Physics 12
delayed choice experiment Quantum Physics 6
Delayed Choice Quantum Physics 0
