Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
image Venus Perihelion Share It Thread Tools Search this Thread image
Old Mar28-05, 04:57 AM                  #1
smokie
smokie is Offline:
Venus Perihelion
Why is it so hard to measure the perihelion advance of Venus?
Old Mar28-05, 07:17 PM                  #2
tony873004
tony873004 is Offline:
Recognitions:
PF Contributor PF Contributor
Maybe because Venus' orbit is very round. It's almost a perfect circle, and a perfect circle would have no perihelion (or would it be correct to say that the entire orbit would be perihelion and apihelion at the same time?)
I'm just guessing here, but as Venus gets tugged around by other planets, its perihelion might almost instantly jump from one part of its orbit to another without actually advancing smoothly to that point. This being because in an almost perfect circle, a point even 180 degrees from perihelion just barely misses being the perihelion itself.
So it's kinda like the calculus problem, what is the slope at a cusp? Undefined, it can point in many different directions. For Venus, with its almost round orbit, which point is the Perihelion, and would the smallest little change affect which point would be considered Perihelion?
Something with a higher eccentricity such as Mars would never have this "perihelion identity crisis", and its perihelion advances in a periodic fashion.
Just my guess since I've never heard that it was hard to measure.
Old Mar29-05, 03:59 AM                  #3
smokie
smokie is Offline:
Well to be honest, I never heard that it was hard to measure either.
The prof was teaching us about Mercury's perihelion and how it baffled scientists for so long. Then Einstein's GR came along and solved the mystery. However, I never really understood the problem with Mercury's perihelion, so maybe if someone could clear that up that would be nice...
But so anyway, he then asked us for an assignment question, "Why is Venus's perihelion difficult to measure?"
The more I searched on the net, the more I found information regarding Mercury. The closest information I got towards Venus was that, "Mercury, Venus and Earth have a perihelion advance".
I'm actually quite lost with what they mean by perihelion advance too. Man I sound stupid today.
Well thanks for any input.
Old Mar29-05, 01:13 PM                  #4
tony873004
Recognitions:
Mercury drifted a small amount from where it was predicted to be. Early theories suggested that a planet interior to Mercury was causing this. But Einstein's theory says that time runs at a different rate in the presence of a strong gravitational field. Mercury is close to the Sun, and Einstein's theory was all that was needed to clean up the slight discrepancy.
As far as advance of Perihelion:
Draw a long ellipse on a piece of paper. Make it point up and down. Then draw another one, same size and shape, but make it point sideways. Now picture all the positions inbetween. For the orientation of the orbit to get from the vertical drawing to the horizontal one, it precesses or advances. Not just the perihelion, but the whole thing. Perihelion is just a convinent point in the orbit to use as a reference. So in your vertical ellipse, if you place the Sun in the bottom focus, your perihelion is at the 6 o'clock position, and in your horizontal ellipse, your perihelion is at the 3 o'clock or 9 o'clock position depending on which way it advanced.
With Venus, the orbit is round. Every point on the orbit is almost perihelion. One point will be the closest to the Sun, but it won't be much closer than the furthest point. The smallest little change can cause this point to drift chaotically and quickly to another part of the orbit.
Old Mar30-05, 06:06 AM                  #5
smokie
smokie is Offline:
Thanks a lot tony!
Old Apr5-05, 08:35 AM                  #6
Ian
Ian is Offline:
Smokie,
As a matter of interest, try calculating the 'length of advance' of perhelion of all the planets in the solar system, as opposed to the 'angular advance' Einstein used. Try and determine the length of the arc subtended by the angle of advance and you might realise something very interesting.
You can do this by either removing the correction term for the ellipticity of orbit from Einstein's equation ( r(1-e^2) ), or by using 6PiGM/c^2. Either way will give you dimensions of length, but the length will be the same for all planets regardless of distance from the sun.
Ian.
image image
Reply
Thread Tools
Similar Threads for: Venus Perihelion
Thread Thread Starter Forum Replies Last Post
Question on advance of perihelion. Ian Special & General Relativity 9 May9-07 09:53 PM
perihelion drift in SR and in GR lalbatros Special & General Relativity 1 Nov19-06 04:02 PM
precession of perihelion RandallB Astrophysics 15 Dec16-05 04:34 PM
Why is it difficult to measure the perihelion advance of the planet Venus? Help! kiwikiwi79 Astrophysics 7 Apr8-05 01:10 AM
Classical mechanics and perihelion of Mercury? Harry General Physics 6 Feb4-05 12:41 PM
Powered by vBulletin Copyright ©2000 - 2010, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
