| Thread Closed |
Loading win 98 |
Share Thread | Thread Tools |
| Aug12-03, 03:30 PM | #1 |
Loading win 98
Can someone tell me how to install win 98 please.
I have :- Partisioned the drive, Formated the drive, Done everthing it says in the book, up to runing setup from the win 98 cd, then pc resets itself.[:((] Can someone help me it s driving me nutts[g)] |
| Aug13-03, 02:55 AM | #2 |
Well, if that's everything you are willing to share with us, I'm afraid we can't help you.
What's your PC's configuration, CPU, memory, mainboard, etc? |
| Aug13-03, 03:12 AM | #3 |
and how did you partition your HDD? how many partitions? Fat16 Fat32?
| Aug13-03, 03:55 AM | #4 |
Loading win 98
Well i dont know much about these things but here goes.
Mother board: Gigabyte GA 7VRXP ATA133 Socket A CPU: AMD Athlon 1900+ Video: Nvidia 128 MB DDR Geforce 4 Ti 4200 Memory: 256 MB PC 2100 DDR 266 DIMM Drives: WD IDE 60 GB 5400rpm (which is set as single) Lite on IDE Rewriter (set to master) Floppy disk drive Cards: Sound blaster live 5.1 jetway 56k rockwell pci with 300W power supply. Does this help? I hope so [;)] |
| Aug13-03, 04:06 AM | #5 |
By the way the startup disk i am using was made on my other pc, does this matter?
I get up to typing in E:\setup (E is the cd drive the win 98 cd is in). Then it resets itself [:((] . I think this is the right drive letter because if i do E:\ (at the A:\ prompt) then type dir I can see the setup exe file in the list. Any ideas what I can try next? Thanks for any help [a)] |
| Aug14-03, 01:57 AM | #6 |
all that I can imagine is either the CD is bad, either change the source. AMDs use more power than the Intel
| Aug14-03, 05:31 PM | #7 |
1. Using a startup disk from another computer will not affect anything.
2. Boot your computer from the startup disk. Make sure to select the start with CD Rom drivers option. 3. After the computer boots enter "fdisk" (without quotes) at the A:\ 4. In Fdisk make sure to delete all partitions! Create a new 2GB partition for your system files. You can always make data partitions later with a windows program (partion magic, etc.) 5. Exit fdisk and return to the A:\ prompt. Type "fdisk /mbr" this wipes the slate clean on your master boot record. 6. Restart. 7. At the A:\ "format C:" after it has formated enter label and restart. 8. After computer boots with the CD option type E:\setup. This should start the process. First it will do a scan on your disk to make sure it has the correct file structure and then it will start to install. If all this doesn't work you may have a bad cd. They say that you can't use a OEM disk to install, but I have done it literally 50 times or so. Feel free to PM me if you have any more trouble, I would be more than happy to help you out. One more thing, if you have mismatched ram, a bad stick, or one is not seated properly it can cause problems in the install phase so double check. Good Luck! |
| Aug14-03, 06:07 PM | #8 |
I don't like to be nagged to enter the win98 CD when I make changes to my system so following the format I create a folder on the C: drive called win98, copy all the files from the win98 folder on the installation CD into it, perform a sys c: operation to make the hard drive bootable, then reboot the computer and run the setup.exe located inside the win98 folder on the hard drive. This is slick little trick you might want to give a try. Good luck |
| Aug17-03, 11:41 AM | #9 |
Thanks all. Changed the power supply and it now works! I think the 12V line was iffy[:((] [g)] [<:)] [s(] [:(]
| Aug17-03, 11:48 AM | #10 |
Alright !
How did you finally decide to partition the drive, and did you install from the CD or copy the win98 files to a folder on the hard drive first? |
| Aug17-03, 11:56 AM | #11 |
It is almost always something simple!
| Aug17-03, 01:22 PM | #12 |
Mentor
| Aug18-03, 01:43 AM | #13 |
slim: you should try Linux sometimes.....[:)] [;)]
| Aug19-03, 06:40 PM | #14 |
Recognitions:
hah, thats almost mean Guy.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Loading win 98
| Thread | Forum | Replies | ||
| Loading down a bus | Electrical Engineering | 5 | ||
| Loading Issues | Forum Feedback & Announcements | 25 | ||
| loading swf | Computing & Technology | 15 | ||
| Loading a File in C++ | Computing & Technology | 15 | ||
