Throttling Process & Joule Thomson Effect
  • Thread starter Thread starter ahmad.hasan
    Process
The discussion centers on the throttling process and the Joule-Thomson effect, exploring their definitions, implications, and applications in various contexts, including gas expansion and pressure regulation.
  • Homework-related
  • Some participants define the throttling process as isenthalpic, noting that enthalpy remains constant (h1 = h2) during the process.
  • One participant mentions that in a throttling process, a drop in pressure leads to an increase in internal energy, though this relationship may depend on specific conditions.
  • Another participant explains that the Joule-Thomson effect typically results in a temperature drop during gas expansion, with the exception of hydrogen, which can gain temperature under certain conditions.
  • A participant questions whether the pressure drop in a CNG kit pressure regulator constitutes a throttling process, noting that temperature also drops.
  • Responses confirm that the described process is indeed a throttling process, although there is some clarification needed regarding the nature of the expansion (whether through a nozzle or valve).
  • One participant inquires about the value of the Joule-Thomson coefficient for methane, indicating interest in specific thermodynamic properties.
Participants generally agree on the definition of the throttling process and its relation to the Joule-Thomson effect, but there is some uncertainty regarding specific applications and the behavior of different gases during expansion.
Some claims about the relationship between pressure, internal energy, and temperature changes may depend on additional assumptions or specific gas properties that are not fully explored in the discussion.
This discussion may be useful for students and professionals interested in thermodynamics, particularly those studying gas behavior under varying pressure and temperature conditions.
ahmad.hasan
dear all
What is the throttling Process?
what is Joule homson Effect?
A throttling process is a process that is isenthalpic. Thus, [tex]h_1 = h_2[/tex]. This means that the following is also true, [tex]u_1 + P_1 v_1 = u_2 + P_2 v_2[/tex]. So if you drop pressure in a throttling value, you increase the internal energy, and vise versa.
The Joule -thomson- effect deals with the fact that as you expand a gas it looses temperature. Note that for hydrogen; however, it gains temperaturee as it expands. This makes hyrdogen particularly dagnerous.
Pressure drops in CNG kit Pressure regulator from 300 bar to 4 bar in 1st chamber due to expansion is it throttling process? temperature also drops in it.
Yes, that is exactly what it is.
Edit: wait, what do you mean by expansion? Is it going through a nozzle?
no it is going throug valve (sloninoid valve) from storage cylinder through high pressure pipe into solinoid valve and then in the 1st stage chamber of pressure regulator.
Yes, it is a throttling valve.
what is the value of joule-thomson coefficient for methane
  • · Replies 16 ·
  • · Replies 22 ·
