How Do You Use Lagrange Multipliers to Find the Closest Points to the Origin?
The discussion focuses on using the Lagrange multiplier method to find the closest points to the origin on the surface defined by the equation 3xy - z² = 1. The user initially attempted to apply the method but arrived at an incorrect solution of (-3/2, 0, -1). The correct approach involves minimizing the function f(x, y, z) = √(x² + y² + z²) subject to the constraint g(x, y, z) = 3xy - z² = 1. The solution process reveals that z must equal 0, leading to the conclusion that the correct points are not extraneous and lie on the specified surface.
  • Understanding of Lagrange multipliers
  • Familiarity with multivariable calculus
  • Knowledge of gradient vectors
  • Ability to solve constrained optimization problems
  • Study the application of Lagrange multipliers in higher dimensions
  • Learn about gradient descent methods for optimization
  • Explore the geometric interpretation of Lagrange multipliers
  • Investigate other optimization techniques such as KKT conditions
Students and professionals in mathematics, particularly those studying optimization techniques, engineers working on constrained optimization problems, and anyone interested in advanced calculus applications.
Weatherkid11
LaGrange Multipliers! Help!
Use the Lagrange multiplier method for 3 variables to find the points on the surface 3xy-z^2=1 that are closest to the origin.
I tried using the gradient= lamda(granient) and ended up getting (-3/2,0,-1). but i think i did it way wrong. Can someone please help? Thanks!
the gradient should be parallel to the radius vector, no?
Minimize [tex]f(x,y,z)=\sqrt{x^2+y^2+z^2}[/tex] subject to the constraint [tex]g(x,y,z)=3xy-z^2=1[/tex]
and note that the min of f is also the min of f^2, so the vector eqn is
[tex]2<x,y,z> = \lambda <3y,3x,-2z>[/tex] and [tex]3xy-z^2=1[/tex]
the z-component gives [tex]z=-\lambda z[/tex] and hence [tex]\lambda=-1[/tex] iff [tex]z\neq 0[/tex] and plugging [tex]\lambda=-1[/tex] into the vector eqn quickly gives both 2y=-3x and 2x=-3y so x=y=0, however this is an extraneous solution since (0,0,z) is not on the given suface (for real z anyhow). Therefore z=0 by contradiction and now it is easy.
Have fun,
-Ben
