How many laptops can be plugged into a desk outlet without blowing the fuse?
  • Thread starter Thread starter jaxnnux
    Circuits
The discussion revolves around the feasibility of connecting multiple laptops to a classroom desk outlet without exceeding the fuse's capacity. Participants explore electrical concepts related to current, voltage, and power consumption, with a focus on practical applications in a classroom setting.
  • Phil states the classroom outlet provides 120 V and a maximum current of 20 A, concluding that a maximum of 5 laptops can be plugged in based on their estimated current draw of 4 A each.
  • Another participant questions the understanding of current, suggesting that the 20 A refers to the maximum capacity of the circuit rather than the current drawn by the laptops.
  • One participant challenges the laptop current figure, arguing that laptops typically draw much less than 4 A from the outlet, suggesting that the actual draw might be around 1 A or less when accounting for efficiency.
  • Another participant proposes measuring the current when a laptop is connected to determine how many can be safely plugged in.
  • A different viewpoint calculates the total power available from the outlet (2400 W) and estimates that up to 37 laptops could be connected based on a typical laptop power consumption of 65 W.
  • Discussion includes details about laptop power supplies, noting that high-end laptops may draw up to 1.5 A, while most draw less than 1 A.
  • Phil raises a further question about the number of outlets in the classroom and whether the total number of laptops that can be connected would be 37 per outlet or a cumulative total across multiple outlets.
  • Another participant advises determining which breakers control the outlets to understand the load distribution better.
Participants express differing views on the current draw of laptops and the implications for connecting multiple devices to a single outlet. There is no consensus on the maximum number of laptops that can be safely connected, as estimates vary significantly based on assumptions about power consumption and circuit capacity.
Limitations include assumptions about laptop power consumption, the efficiency of power supplies, and the specific configuration of electrical circuits in the classroom. The discussion does not resolve these uncertainties.
Individuals interested in electrical engineering, product design, or classroom technology setups may find the insights relevant to their work or studies.
jaxnnux
Hello,
I'm a chemical engineering major who's taking a product design class. Hating all the different classroom desk/chair arrangements in my building, my group chose to redesign classroom desks/chairs (it has nothing to do w/ ChemE, I know). Being a ChemE, I only know about circuits from my Phys II course that I took 2 years ago.
Here's the deal: my groups wants to run circuits through the desks to allow people to plug in their laptops. There will either be one long desk or blocks of desks that can be electrically connected together. Here's what I know (or so I hope):
1) The volage from the classroom's outlet is 120 V
2) The current is about 20 A
3) The maximum current a laptop uses is about 4 A
Of course, the circuits will be connected in parallel to equally share current.
Therefore, my group concluded that the maximum number of computers plugged into the desk outlet before the fuse is blown is 5. Does this seem reasonable?
Also, does anyone know anything about the plug of a laptop? Will it convert the 120 V to the amount that the laptop uses ~ 22 V? Like I said, I know very little about circuits.
Thanks,
Phil
Yea it would.That plug you may be referring to is called the adapter. It steps down the voltage.
Let me ask you a quick question, how do you know the current is 20A. The current would only increase when you add a load (in this case a laptop). Are you referring to the maximum current flow the wire can handle before it starts to get hot an poses a threat
? Well in that case, yes. This fuse has to break the circuit to prevent a fire for example.
What's wrong here is the laptop current figure. 20A for the 120V mains seems reasonable for the fuse, but a laptop will not draw ~500w. That is completely crazy. It might draw 5A from the power supply at 12V, the power supply is not drawing 5A from 120V to get that. Probably more like <1A, when the efficiency is accounted for.
Thus, the circuit will be fine with even 20 laptops plugged in, assuming you don't pass 20A through a skinny wire at some point.
What I would do is measure the current on the 120 VAC source when one laptop is attached. Then figure how many you can hook up.
If you don't have a AC current meter, then look at the power (watts) the laptop consumes then find the current. i.e. I = P/V
Total power avialable from the outlet is 20A * 120 V = 2400 W, my laptop uses 65 W, so if you divide 2400/65 = 37 laptops
Most laptop power supplys (the transformer block in the middle of the wire) say what their input amperage is. High-end laptops could pull up to about 1.5A, but most are less than 1. The output tends to be pretty high - 19V or so, so that's where the figure of 5A comes in, giving a maximum of about 95W.
Hey guys,
Thanks for responding to my concerns. I have one more question about circuits. Is there only one fuse that I can blow for a classroom?
For instance, if I have 3 outlets in the classroom, is the maximum number of computers that I can have connected to the desk, going by what's calculations, 37 or 3x37=111?
Thanks,
Phil
By the way, if you have any comments about features you hate or love about classroom desks/chairs, please let me know :)
You have to determine which breakers control which outlets. If there's any decency in the world, the breakers will be labelled as to what loads are assigned to them.
  • · Replies 33 ·
14K
  • · Replies 29 ·
20K
17K
  • · Replies 18 ·
